Circular Motion: Location & Speed at t=1s
  • Thread starter Thread starter xstetsonx
    Motion
The discussion focuses on calculating the location and speed of a reference dot on a computer disk with an 8.0 cm diameter after 1 second of acceleration and coasting. The disk accelerates to an angular velocity of 1480 rpm, which converts to approximately 2960π rad/sec. The initial angle is set at θ = +45°, and the formula used to determine the angle covered during acceleration is θ = θ₀ + ω₀t + ½αt². The final speed of the reference dot is confirmed to be 6.28 m/s.
  • Understanding of angular velocity and linear velocity relationships (v = rw)
  • Familiarity with rotational kinematics equations
  • Basic knowledge of radians and degrees conversion
  • Ability to perform calculations involving angular acceleration
  • Study rotational kinematics in-depth, focusing on angular displacement and acceleration
  • Learn about converting between angular velocity (rpm) and radians per second
  • Explore the relationship between linear speed and angular speed in circular motion
  • Practice problems involving circular motion to solidify understanding of the concepts
This discussion is beneficial for physics students, mechanical engineers, and anyone interested in understanding the principles of circular motion and rotational dynamics.
xstetsonx
1. A computer disk is 8.0 cm in diameter. A reference dot on the edge of the disk is initially located at θ = +45°. The disk accelerates steadily for second, reaching 1480 rpm, then coasts at steady angular velocity for another second. What are the location and speed of the reference dot at t = 1 s?
2. v=rw
3. i already got the 6.28 m/s for speed. and i thought since i have speed i can just do v=rw to get w and then draw a diagram to get the area under the curve. After i got the area just use delta theta/ 2pi=revolution. then minus the whole number and take the decimal to divide by 360 then plus 45 right? but appreantly i am wrong
2. v=rw3. i already got the 6.28 m/s for speed. and i thought since i have speed i can just do v=rw to get w and then draw a diagram to get the area under the curve. After i got the area just use delta theta/ 2pi=revolution. then minus the whole number and take the decimal to divide by 360 then plus 45 right? but appreantly i am wrong
We assume it is at rest at t=0 and accelerates until t = 1s at which time its speed [itex]\omege =2960\pi[/itex] rad/sec. To find the angle it covers in that first second, use:
[tex]\theta = \theta_0 + \omega_0t + \frac{1}{2}\alpha t^2[/itex]<br /> <br /> AM[/tex]
  • · Replies 44 ·
