| Thread Closed |
Fluid Mechanics::'Deriving' Incompressible Flow Criteria |
Share Thread | Thread Tools |
| Nov11-09, 01:44 PM | #1 |
Here we go....
My text attempts to 'derive' an expression that explains when a flow is compressible or not: ... if there's anything I like better than making density approximations, it's playing 'fast and loose' with them. ![]() He then goes on to say: Any thoughts? Casey |
| Nov11-09, 03:47 PM | #2 |
Hi Casey!
![]() ∂(ρu)/∂x = u∂ρ/∂x + ρ∂u/∂x, so if u∂ρ/∂x << ρ∂u/∂x, we can ignore it, and then ∂(ρu)/∂x ~ ρ∂u/∂x. ![]() (2) to (3) is simply rearrangement (and changing u to V for some reason which escapes me) |
| Nov11-09, 04:07 PM | #3 |
Oh...that darned chain rule!
Thanks tiny-tim.Also, silly question, but why did we change the ∂'s into [itex]\delta[/itex]'s ? Is it because the (∂x)'s 'canceled' and thus it is no longer a derivative, but just a relation between 'changes?' |
| Nov11-09, 04:09 PM | #4 |
(2) to (3) is based upon the fact that this argument must be repeated for the v and w-components as well, and hence, that the relative infinitesemal change in density must be much less than the relative infinitesemal change in the maximal velocity component, and hence, much less than the relative infinitesemal change in the fluid speed.
| Thread Closed |
| Thread Tools | |
Similar Threads for: Fluid Mechanics::'Deriving' Incompressible Flow Criteria
| Fluid Mechanics: Inviscid flow v.s. Laminar flow | Engineering, Comp Sci, & Technology Homework | 1 | ||
| Difference between incompressible viscous and incompressible inviscid flow. | General Physics | 1 | ||
| Fluid Mechanics: streamlines for a flow | Advanced Physics Homework | 0 | ||
| incompressible fluid flow. | Mechanical Engineering | 7 | ||
| Fluid Mechanics - Pipe Flow | Mechanical Engineering | 11 | ||
