What is the spectrum of a signal sampled at 10KHz?
  • Thread starter Thread starter frenzal_dude
    Signal Spectrum
The spectrum of the signal s(t) = sin(400πt) + 0.5cos(12000πt) sampled at 10KHz reveals critical insights into frequency components. The Discrete Fourier Transform (DFT) is applied with N=10 samples, leading to a signal duration of 0.001 seconds. The analysis confirms that the 200Hz component is preserved due to the Nyquist theorem, while the 6000Hz component is not recoverable and is aliased to 4000Hz. This demonstrates the importance of sampling frequency in accurately capturing signal characteristics.
  • Understanding of Discrete Fourier Transform (DFT)
  • Knowledge of Nyquist theorem and aliasing
  • Familiarity with signal sampling concepts
  • Basic proficiency in trigonometric functions and their properties
  • Study the implications of the Nyquist theorem in signal processing
  • Learn about aliasing and its effects on signal reconstruction
  • Explore advanced DFT techniques and their applications
  • Investigate sampling strategies for different types of signals
Students in electrical engineering, signal processing professionals, and anyone interested in understanding the effects of sampling on signal frequency components.
frenzal_dude
Hi, I need to find the spectrum of [tex]s(t)=sin(400\pi t) + 0.5cos(12000\pi t)[/tex] when sampled at 10KHz.
Using the Discrete Fourier Transform:
[tex]G_{k}=\sum_{n=0}^{N-1}s_{n}e^{\frac{-j2\pi kn}{N}}[/tex]
where N is the amount of samples taken in the signal duration which is [tex]NT_{s}=\frac{N}{10000}[/tex] and [tex]s_{n}=s(nT_{s})[/tex]
I decided to take 10 samples, so N=10, therefore the signal duration is 0.001 seconds
Therefore: [tex]G_{k}=\sum_{n=0}^{9}s_{n}e^{\frac{-j2\pi kn}{10}}[/tex]
[tex]G_{k}=\sum_{n=0}^{9}[sin(400\pi nT_{s}e^{\frac{-j2\pi kn}{10}}+0.5sin(12000\pi nT_{s})e^{\frac{-j2\pi kn}{10}}][/tex]
[tex]G_{k}=\sum_{n=0}^{9}[sin(\frac{4\pi n}{100})e^{\frac{-j2\pi kn}{10}}+0.5sin(\frac{12\pi n}{10})e^{\frac{-j2\pi kn}{10}}][/tex]
[tex]G_{k}=\frac{1}{2}-0.28e^{\frac{-j\pi k}{5}}+0.403e^{\frac{-j\pi k2}{5}}+0.523e^{\frac{-j\pi k3}{5}}+0.077e^{\frac{-j\pi k4}{5}}+1.09e^{\frac{-j\pi k5}{5}}+0.28e^{\frac{-j\pi k6}{5}}+0.93e^{\frac{-j\pi k7}{5}}+0.999e^{\frac{-j\pi k8}{5}}+0.5e^{\frac{-j\pi k9}{5}}[/tex]
I'm not sure what this all actually means, how can we find the frequency components based on all those exponentials? I know that exponentials in the time domian give a delta in the frequency domain, but these exponentials are already in the frequency domain.
Any help would be greatly appreciated!
Frenzal
Hey I think I worked it out, you don't need to use the DFT.
The 200Hz component will be present after sampling because 200Hz is less than half the sampling frequency 10000Hz, however the 6000Hz component will not be present after sampling because 6000Hz is not less than half the sampling frequency, ie you need to sample at at least 12000Hz to recover the whole signal (Nyquist theorem). Instead the 6000Hz component will be shifted to 0.5Fs – (6000Hz-0.5Fs )=5000Hz-(1000Hz)=4000Hz.
