E= Mx (C Squared) by why squard?
  • Context: Undergrad
  • Thread starter Thread starter Tony Batchelo
The discussion revolves around the mathematical reasoning behind the squared term in the equation E=mc², specifically questioning why it is c² and not c³ or c⁴. Participants explore the implications of this formulation in the context of physics, touching on concepts from Special Relativity and historical perspectives on energy and motion.
  • Some participants assert that the units of energy must match, which is why E=mc² is consistent while alternatives like mc³ or mc⁴ are not.
  • Others provide derivations from Special Relativity and Newtonian Mechanics, suggesting that context is crucial for understanding the formula.
  • A historical perspective is introduced, highlighting Emilie du Chatelet's contributions and her experiments that support the idea of energy being proportional to the square of velocity.
  • Some participants argue that questioning the formula is unnecessary, as it has been well-established through experimental evidence.
  • There is a discussion about the nature of kinetic energy and its relationship to speed, with some clarifying that mc² is not strictly a kinetic energy term.
  • A later reply emphasizes that the constant k in the energy-mass relationship could be questioned, but the squared term c² is seen as a natural consequence of dimensional analysis.
Participants express a mix of agreement on the validity of E=mc² while also presenting various interpretations and derivations. There is no consensus on the necessity of questioning the formula, with some viewing it as a productive inquiry and others considering it settled knowledge.
Some arguments rely on historical context and interpretations of energy that may not be universally accepted. The discussion includes references to specific derivations and experiments that may not be fully detailed, leaving some assumptions unexamined.
Tony Batchelo
we all accept the E=mc2 formula but what is the mathmatical proof for the c2, why for example is it not c3 or c4?
For one, the units don't match up.
Do a search for the countless number of threads that discuss this.
In Newtonian Mechanics we have F = ma; why not m², m³, ...?
Asking such questions is silly. No such formula can be understood w/o its context ... and from the context it becomes clear how to proof or at least why to introduce it.
If you start the Lorenz SR formula for mass and relate the mass change to the velocity and the difference in Energy input, you get an expression which, with a little bit of sloppiness / 'unrigorousness', more or less yields E = mc2.
Many of us do not just accept it but know its derivation- it can be found in any introductory text on relativity- and so understand why it is [itex]c^2[/itex]. I see Keven Axion has given a link to the derivation.
But, as penquino said, you don't have to know the derivation to see why it cannot be "[itex]mc^3[/itex]" or "[itex]mc^4[/itex]".
Any form of energy can measured in "Joules" which, itself, reduces to "kilograms meters^2/second^2" and any energy measurement, in any units, must reduce to those bases: mass times distance squared over time squared. Since m is a mass and c a speed which is measured by "distance over time", [itex]mc^2[/itex] gives precisely those units while [itex]mc^3[/itex] or [itex]mc^4[/itex] do not.
(This does not prove "[itex]e= mc^2[/itex]", it shows that it is consistent while the others you suggest are not.)
You could ask the same thing about absolutely any formula. I suggest you look for a derivation. Like HallsofIvy stated, we don't just accept it, we understand its derivation. It has been proven.
The answer lies with the discovery made by a brilliant French aristocrat, Emilie du Chatelet.
At the age of 23, du Chatelet discovered a talent for advanced mathematics which she relished. So much so that she began to formulate ideas of her own; ideas that challenged the great physicists, including Sir Isaac Newton.
Newton stated that the energy (or force) of a moving object could simply be expressed as its mass multiplied by its velocity. But while corresponding with a German scientist called Gottfried Leibniz, du Chatelet learned that Leibniz considered the energy of a moving object is better described if its velocity is squared. But how to test this? Du Chatelet tried an experiment that would prove her point – dropping lead balls into clay.
Newton's formula says that doubling the velocity of a ball would double its energy and so one would expect it to travel twice as far into the clay. But if the velocity is squared, as Leibniz and du Chatelet believed, the force should be four times greater, and the ball should travel four times the distance into the clay.
Du Chatelet conducted her lead ball experiment and sure enough, doubling the velocity of the ball (by dropping it from twice the height) resulted in the ball traveling four times further into the clay. This simple but brilliant experiment proved that when calculating the energy of moving objects, the velocity at which they travel must be squared. The energy of an object is a function of its velocity squared – it is for this reason that the speed of light in Einstein's equation must be squared.
This was a factor that profoundly changed the meaning of Einstein's equation – since c is already a large number, once squared it is vast. Thus, a vast amount of energy (E) can be associated with a very small amount of mass (m) because mass is always multiplied by the speed of light (c) squared – a vast number. Under these laws, even a tiny amount of mass will equate to a huge amount of energy.
Why are people still responding to this thread? There are many people who provided sufficient answers including a mathematical derivation. This is a formula that is used continually in technology and Theoretical Physics, why ponder and challenge it?
Nobody was challenging it, it has been put through many experimental rigours before. I think my answer will benefit the questioner a lot more because it gives some history to the problem. Therefore it makes accepting the magical equation a lot easier.
A ponder is fine.
To challenge is a waste of time.
Yes, pondering is fine, but pondering it and assuming it to be senseless without full disclosure to the Mathematics isn't.
People are responding to this thread because it is an interesting topic that people are contributing their portion of knowledge to. If anyone doesn't wish to participate then that is fine. Not everyone here is at the same level. I myself prefer to be supportive wherever possible.
From a previous instance of this question:
DaleSpam said:
Let's say that we begin with the supposition that mass has some intrinsic amount of energy, even when it is at rest, and we want to find the formula that determines how much energy is in a given amount of mass. First, we know that the units of mass and energy differ by a speed² so we can immediately write E=kmv².
So, what v can we use? The mass is at rest (v=0). So we cannot use its speed; it must be some sort of universal constant with units of speed. The only such constant is the speed of light, so we know E=kmc² just from consideration of units.
Determining that k=1 requires some actual derivation, so if anything you should ask why k=1 instead of k=1/2. But c² should be obvious: what else could it possibly be?
I ANSWERED THIS QUESTION GIVING A FULL HISTORY OF WHERE c^2 arrived from...
But your answer doesn't really make sense. Du Chatelet showed that the object's kinetic energy is proportional to its speed squared. But mc^2 is not a kinetic energy; c is not the speed of the object.
And kinetic energy being proportional to speed squared is only true for low, non-relativistic speeds.
Thank you, very interesting post of something I did not know.
there is no answer to this question, it is squared becouse the laws of nature tell us it is, it is squared so that the mathma\tical evidense adds up to it in e=mc2
The above comes from some BBC documentary which seems to relate a lot of garbage, at least in the written summary that I have read previously. The old link I had to the offending summary appears to be gone but a quote from an old post reveals it to have read:
At the age of 23, du Chatelet discovered a talent for advanced mathematics which she relished. So much so that she began to formulate ideas of her own; ideas that challenged the great physicists, including Sir Isaac Newton. Newton stated that the energy (or force) of a moving object could simply be expressed as its mass multiplied by its velocity. But while corresponding with a German scientist called Gottfried Leibniz, du Chatelet learned that Leibniz considered the energy of a moving object is better described if its velocity is squared. But how to test this? Du Chatelet tried an experiment that would prove her point ? dropping lead balls into clay.
Du Chatelet conducted her lead ball experiment and sure enough, doubling the velocity of the ball (by dropping it from twice the height) resulted in the ball traveling four times further into the clay. This simple but brilliant experiment proved that when calculating the energy of moving objects, the velocity at which they travel must be squared. The energy of an object is a function of its velocity squared ? it is for this reason that the speed of light in Einstein's equation must be squared.
A response of mine to this followed:
The problem is that the above bolded is a bunch of crap. The main offenders being the equivalence between force and energy and the supposition that 0.5mv^2 somehow means that people were on the right track to get mc^2. It ignores the fact that the relationship between kinetic energy and the square of velocity has been standard mechanics for centuries and that the relationship of mc^2 is completely different. E=mc^2 is the rest energy and is not part of the kinematics, as a constant offset it does not affect any classical mechanics. If we take the energy relation for a moving object, we can get the Newtonian physics energy relationship back out by a simple Taylor's expansion. The first term is the rest energy and the second is the classical kinetic energy.
So for classical kinematics, relativity does not change anything, in fact, it just reaffirms the original equations.
Looking at what they said about Newton's statement, I just got my requested copy of the Principia and while I am still going through the notes I believe that the statement is more of a misinterpretation. The Principia suffers from two problems. The first is that it is in Latin, the second is that it is largely devoid of equations, Newton talked out the relationships and both of these aspects can introduce gross misinterpretations. For example, the Cohen and Whitman translations specifies Newton's Second Law (Book 1 Law 2) as
A change in motion is proportional to the motive force impressed and takes place along the straight line in which that force is impressed.
If some force generates any motion, twice the force will generate twice the motion, and three times the force will generate three times the motion, whether the force is impressed all at once or successively by degrees.
This is open to a lot of interpretation even after its translation into English. What is meant by motion? An incorrect interpretation would think that it is velocity, thus Newton is saying that a force generates a velocity (ignoring his stipulation of change in motion in the heading for the law). Twice the force will generate twice the velocity and so on. Add in the incorrect assumption that force and energy are the same (which I do not think Newton supposed) and you get that Newton stated Force is proportional to Velocity. However, Newton is talking about a change in motion being proportional to the force. Newton's "motion" here is momentum. He is saying that the change in momentum (because he is talking about an impulse force here, not a continuous foce) is proportional to the impulse force that is applied. In addition, if we apply twice the impulse force, we get twice the change in momentum. Or, if we successively apply an impulse force we will successively add up the change in momentum. This is true and agrees with modern classical mechanics. Newton is saying that Force is proportional to the change in Mass*Velocity.
Another point is that the Principia was originally written around the idea of explaining the motion of the heavenly bodies, to put it poetically. The concept of kinetic energy was not developed here. So it is certainly correct to say that Leibnitz and others developed the idea of energy. However, the translators of my copy note that Newton did derive a value that would be equivalent to energy and his relationship is that it is equal to 0.5mv^2.
So, to reiterate, the connection of du Chatelet and Einstein is incorrect. As stated by a previous poster in this thread, the kinetic energy of an object and its relativistic mass-energy equivalence equation is something completely different. In fact, the kinetic energy is an additional term in this equation since the actual equation is
[tex]E^2 = (mc^2)^2 +(pc)^2[/tex]
So that is incorrect. Also stipulating that Newton incorrectly gave the relatonship of kinetic energy is incorrect as far as I have found. I have looked through the Principia and did not find this and I do not think that Newton even had a kinetic energy equation. He mainly worked with forces and the use of energy is not necessary to derive the results that he did in the Principia.
EDIT: I forgot the most glaring mistake of all. If you double the height of a dropped object it does NOT double the speed of the ball, it only increases it by \sqrt{2}. I really REALLY hated that bloody BBC documentary.
Aside from the full derivations (and simplifications from the full equation including momentum) spitting out E=m*c^2 as a simple result from mathematical rules, the alternatives don't make dimensional sense. The du Chatelet example claims Newton used an erroneous equation for kinetic energy of m*v, but m*v doesn't even give units of energy. The example also incorrectly equates energy and force.
As I recall, concepts of energy were not well defined at the time. Newton didn't get an equation for kinetic energy wrong, he just computed things in terms of momentum instead, which is a perfectly valid and often more convenient approach. du Chatelet didn't correct any of Newton's equations, she recognized that the quantity we call kinetic energy is useful but distinct from momentum. The ones who got it wrong were those who equated the vis viva of Leibniz with the momentum of Newton, and assumed that one of the two was incorrect.
As for the original question...energy as expressed in SI base units is m^2*kg/s^2. Force, m*kg/s^2. Velocity of course is m/s. m*c would give units of m*kg/s, which are units of momentum, not energy. m*c^3 would give m^3*kg/s^3...again, not units of energy, or anything else particularly useful. (watt-meters?)
Calculations for specific quantities will differ, but the dimensions must match up.
Potential energy in a uniform gravity field:
U = m*g*h, where m is mass, g is 9.81 m/s^2, and h is height. kg*m/s^2*m = m^2*kg/s^2 = joules of energy
Classical kinetic energy:
kE = 0.5*m*v^2, kg*(m/s)^2 = m^2*kg/s^2 = joules of energy
The similarity of E=m*c^2 to classical kinetic energy is not coincidence, but it's not of any deep meaning either.
  • · Replies 22 ·
  • · Replies 0 ·
  • · Replies 28 ·
14K
