Expectation Values of x & p for Wavefunction u(x,0)
The discussion revolves around the expectation values of position and momentum
for a given wavefunction of a particle at time t=0. The original poster seeks clarification on why the relationship
= m d/dt does not hold in this scenario.
  • Participants explore the definitions of momentum and its expectation value, questioning the applicability of the Ehrenfest theorem in this context. There is a focus on the distinction between the definitions of
    and p.
Participants are actively questioning the assumptions behind the relationship between
and the time derivative of . Some guidance has been offered regarding the definitions involved, but no consensus has been reached on the implications of the Ehrenfest theorem in this case.
The discussion highlights the specific definitions used for momentum and expectation values, as well as the constraints imposed by the wavefunction's form. There is an emphasis on the mathematical definitions rather than physical interpretations.
Geocentric
A particle is represented(at t=0) by the wavefunction
u(x,0) = A(a^2 - x^2) if -a<x<a
= 0 otherwise
Determine <x> & <p>.
It is given in the book that in this case <p> [tex]\neq[/tex] m*d/dt<x>. Could someone please tell me the reason for this?
because if you use <p> = m d<x>/dt, you would determine the expectation value of the momentum via that of x.
But <p> is given only by ∫u p u* dx - it's a definition.
What I don't understand is that according to Ehrenfest theorem,
<p> = m* d/dt<x>
Why is this not true in this case?
How does your book DEFINE p mathematically?
The integral is just the definition of <p>.
p and <p> are not the same thing, so you can't use the formula for p to find <p>.
