Probability of exactly x heads in n tosses
  • Context: Undergrad
  • Thread starter Thread starter moonman239
    Probability
The probability of obtaining exactly five heads in a series of 300 coin tosses is calculated to be approximately 2.64 x 10^-680 using the Poisson approximation to the binomial distribution. The initial probability of exactly five heads is about 8.8 x 10^-66, which is then adjusted for the factorial arrangement of outcomes, yielding a final result. The binomial distribution formula, n!/(x! * (n - x)!), is noted for its inefficiency with large n and small x, making the Poisson distribution a more practical alternative in such cases.
  • Understanding of binomial distribution and its formula
  • Familiarity with Poisson distribution and its application
  • Knowledge of factorial functions and their computational limits
  • Basic probability theory concepts
  • Study the application of the Poisson distribution in real-world scenarios
  • Learn about advanced probability distributions and their computational methods
  • Explore the implications of large n in statistical calculations
  • Investigate the use of statistical software for complex probability calculations
Statisticians, data analysts, mathematicians, and anyone interested in probability theory and its applications in large sample sizes.
moonman239
Problem: I toss a coin 300 times. What is the probability that I get only five heads in a row?
Solution: The probability of exactly 5 heads in 300 tosses is about 8.8*10^-66, according to the Poisson approximation to the binomial distribution (see below). But, those 5 heads can occur anywhere within the sample set. The probability of the outcomes being ordered so that 1 head is in a given spot in the set = 1 / n! where n is the number of tosses, ! (for those who don't know) is the factorial function (n-1 * n-2 * n-3...n-(n-1)). That number is approximately 3*10^-615.
To get the probability, then, of exactly five heads in a row, simply multiply the two numbers together. That gives me 2.64*10^-680.
Q&A
What is the binomial distribution?
The binomial distribution describes the probability of exactly x successes in a series of n trials. The formula for this distribution is: n!/(x! * (n - x)!).
However, when n is too large and x is too small, this formula is not very computationally efficient. Also, your calculator may throw an error if n is greater than 115, due to the fact that the factorial function can't handle numbers that large. In such cases, the Poisson distribution is more useful.
What is the Poisson distribution?
The Poisson distribution is the probability that, for example, a call center who receives a call every 3 minutes on the average will receive a call 2 minutes after another one.
(E(n)^x * e^-E(n)) / x!
where E(n) is the long-run average ("expected") number of successes, and e is Euler's number (2.71828...).
More info
Binomial distribution: http://en.wikipedia.org/wiki/binomial_distribution"
Poisson distribution:http://en.wikipedia.org/wiki/Poisson_distribution"
You might want to add this to the library. See the menu bar at the top and click the green button that says "library". That is made specifically for these kinds of posts...
Thank you for pointing that out.
  • · Replies 29 ·
  • · Replies 0 ·
  • · Replies 16 ·
