Comets and orbital periods and such
  • Thread starter Thread starter vatechacc
    Comets Orbital
The orbital period of Comet Halley is 75.5 years, while long-period comets can have significantly longer periods due to their distant aphelion, estimated at 8*10^12 km from the sun. Using Kepler's third law, the orbital period for such a comet can be calculated to be approximately 2.68 million years. At perihelion, the comet's speed reaches approximately 44,800 m/s, and the kinetic energy upon impact, assuming a mass of 10^15 kg, is estimated at 1.01*10^25 joules, equivalent to about 2400 megatons of TNT. This energy is substantially greater than the impact event linked to the extinction of the dinosaurs.
  • Understanding of Kepler's laws of planetary motion
  • Knowledge of gravitational physics and constants
  • Familiarity with orbital mechanics and velocity equations
  • Basic concepts of kinetic energy calculations
  • Study Kepler's Third Law in detail for various celestial bodies
  • Learn about gravitational constants and their applications in astrophysics
  • Explore orbital mechanics, focusing on perihelion and aphelion dynamics
  • Investigate the historical impact events and their energy comparisons
Astronomers, astrophysicists, educators, and students interested in cometary dynamics and impact events will benefit from this discussion.
vatechacc
The orbital period of Comet Halley is calculated to be 75.5 years. Many other comets have orbits that extend much farther from the sun, and hence have much longer periods. At aphelion, a typical long-period comet is about 8*10^12 km from the sun; at perihelion, it passes inside the Earth's orbit.
Q:a) Estimate the orbital period of such a comet. Give your answer in years
b) Estimate the speed of a typical long-period comet at perihelion. (Hint: At aphelion, the comet is moving very slowly.)
c) The massive nucleus of a comet contains about 10^15 kg of material. If the Earth were struck by a long-period comet, estimate the kinetic energy the comet would have just before impact. An impact of this kind apparently occurred 65 million years ago in the Yucatan, and is implicated in the demise of the dinosaurs as well as many other ancient species. (Hint: The motion of the comet is due primarily to the gravitational attraction of the sun, not the earth.)
What have you done so far to solve the problem on your own?
a) The orbital period of a comet with an aphelion of 8*10^12 km and a perihelion inside the Earth's orbit can be estimated using Kepler's third law: T^2 = (4π^2/GM) * a^3, where T is the orbital period, G is the gravitational constant, M is the mass of the sun, and a is the semi-major axis of the comet's orbit. Plugging in the values, we get T = √(4π^2/6.67*10^-11 * 1.99*10^30) * (8*10^12)^3 = 2.68*10^6 years.
b) At perihelion, the comet is at its closest point to the sun and is moving at its fastest speed. To estimate this speed, we can use the equation for orbital velocity: v = √(GM(2/r - 1/a)), where v is the velocity, G is the gravitational constant, M is the mass of the sun, r is the distance from the sun (in this case, the Earth's orbit at 1 AU), and a is the semi-major axis of the comet's orbit. Plugging in the values, we get v = √(6.67*10^-11 * 1.99*10^30 * (2/1 - 1/8*10^12)) = 4.48*10^4 m/s.
c) To estimate the kinetic energy of a comet with a mass of 10^15 kg moving at a speed of 4.48*10^4 m/s, we can use the equation KE = 1/2 * mv^2. Plugging in the values, we get KE = 1/2 * 10^15 * (4.48*10^4)^2 = 1.01*10^25 joules. This is equivalent to approximately 2400 megatons of TNT. This amount of energy is significantly greater than the impact that caused the mass extinction event 65 million years ago, estimated to be around 100 teratons of TNT. However, it is important to note that the motion of the comet is primarily due to the gravitational attraction of the sun, not the Earth, so the impact energy would likely be much less than this estimate.
  • · Replies 21 ·
