| New Reply |
Static Structural Tool in ANSYS, General Error |
Share Thread | Thread Tools |
| Feb18-12, 09:08 AM | #1 |
Hello everyone
Just a quick question, hopefully someone could shed some light upon what I'm doing wrong here? I'm using ANSYS Workbench to apply a force to what is effectively a cantilever beam, fixed at one end, with a load applied at the other. To be more specific it is a spring strut of a light aircrafts landing gear, where the load is a calculated force at touchdown of landing, so the load bearing end has a wheel assembly attached that I created using Siemens NX. I've defined the materials of each section, produced a mesh and applied the load force and fixed support at either end, but when I run the solution I get the following error message: "An error occurred inside the SOLVER module: general error." Does anybody have any idea what could be causing this? Appreciate any help you can give. Thank you. |
| May14-12, 11:25 PM | #2 |
Hey Burner
I was having the same problem, but i just worked out what was causing it for me. I think I am using an education license, which limits the number of nodes you can have in a model. If you exceed it then it gives you this error. I reduced the size of my model and reduced the number of nodes I was using and the problem went away. The model I am working with at the moment has just under 125000 nodes. A model twice the size didn't run, so id guess the cut off could be between 125000 and 250000 - although I'm not sure. Try reducing your model size. |
| New Reply |
| Thread Tools | |
Similar Threads for: Static Structural Tool in ANSYS, General Error
| ANYS Static Structural, How to simulate 'ground"? | Mechanical Engineering | 1 | ||
| Ansys Rigid Body Motion - Static Structural | Mechanical Engineering | 8 | ||
| Ansys Workbench v.11 in Emag analysis and winding tool | Mechanical Engineering | 0 | ||
| Static tests of timbers in structural sizes (ASTM D198-84) | General Engineering | 12 | ||
| Is Structural Integrity related in any way to Static Friction? Or vice versa? | General Engineering | 7 | ||
