Symmetry of N-Channel MOSFET: VGD & VGS Thresholds
  • Thread starter Thread starter jrive
    Mosfet Symmetry
The discussion centers on the symmetry of N-channel MOSFETs, specifically regarding the roles of Drain and Source in relation to VGD and VGS thresholds. It is established that while basic 2D models suggest that these roles can be reversed under symmetrical conditions, real-world applications, such as standard trench layouts in power FETs, demonstrate that this is not always the case. The threshold voltages may differ when the geometry is not symmetrical, impacting device performance and robustness.
  • Understanding of N-channel MOSFET operation
  • Familiarity with VGD and VGS threshold concepts
  • Knowledge of MOSFET layout designs, particularly trench layouts
  • Basic principles of semiconductor physics
  • Research the impact of parasitics on MOSFET performance
  • Explore advanced MOSFET layout techniques for improved robustness
  • Study the differences between symmetrical and asymmetrical MOSFET designs
  • Review application notes from manufacturers like IRF for practical insights
Electrical engineers, semiconductor designers, and anyone involved in the design and application of N-channel MOSFETs will benefit from this discussion.
jrive
In an N-channel mosfet, for example, can the roles of the Drain and Source be reversed such that the FET turns on with positive VGD? Will this threshold be the same as the specified one for VGS?
In the basic 2d model of a NFET usually given in most introductory texts, yes. And, if you're controlling the layout and force symmetry [1], then again, yes (obviously I guess due to the forced symmetry).
But there are many examples where this does not hold and the FET is not symmetrical to change parasitics or increase robustness.
An obvious example of a NFET which is not symmetrical is the standard trench layout used in power FETs. See the linked IR app note figure 5. For this layout it is obvious drain and source cannot be reversed. There are many other examples as well.
http://www.irf.com/technical-info/appnotes/mosfet.pdf
[1] The entire geometry, including the base tie, must be symmetrical. If only the base geometry is different then the source and drain can be reverse but the threshold will change.
  • · Replies 42 ·
11K
