Heat and Mass Proportionality: Examining the Accuracy
The discussion revolves around the relationship between the time required to convert a given mass of liquid to gas and the mass of the liquid itself, under the condition of constant heat supply. Participants are examining the proportionality of time to mass in the context of heat transfer and phase change.
  • Participants are exploring the relationship between mass and time for phase change, questioning the validity of the original poster's equation and the definitions of the variables involved. There is a focus on clarifying the meanings of specific terms and symbols used in the context of heat transfer.
There is an active exchange of ideas, with some participants seeking clarification on the variables used in the original poster's equation. The discussion is productive, as it involves questioning assumptions and definitions, but no consensus has been reached regarding the accuracy of the original statement.
Participants are addressing potential misunderstandings related to the symbols and terms used in the equations, which may affect the interpretation of the problem. The original poster acknowledges a typographical error in their initial post, indicating a need for precision in communication.
latyph
I NOTICED THAT THE TIME REQUIRED FOR A GIVEN MASS OF A LIQUID IS PROPORTIONAL DIRECTLY TO THE MASS OF THE LIQUID PROVIDED THE HEAT SUPPLY IS CONSTANT,WHICH MAKES t PROPORTIONAL TO m,the heat is constant.now heat is mctheta +ml.which makes t =m^2(l+ctheta).how true is this,is there a fault i this let me know
given mass of liquid to change to gas to be precised,i made a mistake typin
Okay, every liquid has a "heat of boiling" that is the amount of heat required to change 1 gram of the liquid, already at the boiling point into gas. In order to boil x grams of liquid, you must supply a specific number of calories of heat. If you are providing the heat at a constant rate, then the time required to convert all of the liquid to gas is proportional to the mass.
However, having said "THE HEAT SUPPLY IS CONSTANT", you then say "now heat is mctheta +ml". I don't understand that. What are the variables? m, c, theta, l?
or is that ctheta[/b]? I would guess that m is the mass, but what are c and theta (or ctheta[/b]) and is l a separate constant or is ml one amount? Please tell us what your symbols mean.
m mass of liquid,c specific heat capacity,theta change in temp.l latent heat of vaporization
  • · Replies 21 ·
