Copper Nickel Magnetism: Understanding the Effects of Adding Copper to Nickel
Adding copper (Cu) to nickel (Ni) results in reduced magnetism due to the formation of a substitutional alloy where Ni atoms are replaced by Cu atoms. Nickel is ferromagnetic, while copper is not, leading to a change in the nature of atomic interactions. The interaction between Ni and Cu atoms lacks the necessary ferromagnetic characteristics because the orbital overlap is altered, affecting the valence wavefunctions. Consequently, this results in some near-neighbor interactions becoming paramagnetic, thereby decreasing the overall magnetization of the alloy.
  • Understanding of ferromagnetism and paramagnetism
  • Knowledge of atomic structure and valence orbitals
  • Familiarity with substitutional alloys
  • Basic principles of solid-state physics
  • Research the properties of substitutional alloys in metallurgy
  • Study the effects of atomic interactions on magnetism
  • Explore the role of orbital overlap in magnetic materials
  • Learn about the magnetic properties of other metal alloys
Materials scientists, physicists, and engineers interested in the magnetic properties of metal alloys, particularly those studying the effects of alloying elements on ferromagnetism.
sniffer
why adding copper to nickel result in reduced magnetism of nickel? :confused:
Ni is ferromagnetic. Cu is not. When Cu is added to Ni, they form an isomorphous substitutional alloy. Some of the Ni atoms are replaced by Cu atoms.
To put it simpistically, the interaction between a Ni-atom and a Cu-atom is not a ferromagnetic interaction. For a ferromagnetic interaction between 2 atoms, you must have the right extent of orbital overlap - and this depends on the shape of the valence wavefunctions as well as the separation between atoms. In a substitutional alloy, you are not changing the interatomic spacing, but by changing the atoms, you are changing the valence orbital shapes/sizes. By making some of the near-neighbor interactions be paramagnetic instead of ferromagnetic, you are reducing the magnetization.
  • · Replies 16 ·
  • · Replies 59 ·
