Is √5 + √3 Irrational by Contradiction?
The discussion revolves around the question of whether the sum of two irrational numbers, specifically √5 and √3, is also irrational. Participants explore the implications of proving this by contradiction and examine related concepts in irrationality.
  • Some participants suggest proving that if √5 + √3 is rational, then √5 - √3 must also be rational, leading to a contradiction regarding the rationality of √5. Others question the validity of this reasoning by presenting counterexamples.
The discussion is active, with various approaches being explored. Some participants have provided guidance on how to frame the proof by contradiction, while others are questioning the assumptions made in these arguments. There is no explicit consensus on the best method to prove the original poster's question.
Participants are considering the implications of irrational numbers and their sums, as well as the definitions of rational and irrational numbers. There are references to external papers and examples that may not align with the main focus of the discussion.
Millie
we can prove that √5 is irrational through contradiction and same applies for √3.
but can we prove that √5 + √3 is irrational by contradiction?
Show that if [tex]\sqrt{5}+\sqrt{3}[/tex] is rational, then so must [tex]\sqrt{5}-\sqrt{3}[/tex] be rational.
Derive that, hence, [tex]\sqrt{5}[/tex] is rational, a contradiction.
? Are you saying that if x+ y is rational then x- y must be rational? What if [itex]x= \sqrt{5}[/itex] and [itex]y= -\sqrt{5}[/itex]?
Not at all, but:
Let [tex]\sqrt{5}+\sqrt{3}=p[/tex] where p is rational.
We therefore have:
[tex]\frac{2}{\sqrt{5}-\sqrt{3}}=p[/tex], that is:
[tex]\sqrt{5}-\sqrt{3}=m[/tex], m=2/p rational.
That is, since the difference of squares of [tex]\sqrt{5}[/tex] and [tex]\sqrt{3}[/tex] is rational, and [tex]\sqrt{5}+\sqrt{3},\sqrt{5}-\sqrt{3}\neq{0}[/tex] my argument holds.
Is it possible for two irrational numbers to be added together to get a rational number?
I don't know about that, but if you divide pi by phi you get a rational (they share a common irrational factor).
Definitely, HallsofIvy gave an example of that.
And what might that be ?
I mean phi2.
http://members.ispwest.com/r-logan/fullbook.html
The most algorithmic approach I know for these types of problems is to find an integer polynomial with your algebraic number as a root...
apmcavoy said:
I mean phi2.
Are you saying that [tex]\frac{\pi}{\phi^2}\in\mathbb{Q}[/tex]?
Since [tex]\phi=\frac{1+\sqrt5}{2}[/tex] is algebraic and algebraic numbers are closed under multiplication and division, that would mean that pi is algebraic (all rationals are algebraic). The paper you link to, though, admits that "[tex]\pi[/tex] is a transcendental number" and that trancendentals aren't algebraic (by definition).
yes, as has been shown, but more gnerally (I can't recall where i first read this wordy description) but if you are trying to decide if two nasties can make a nice then try thinking if a nice minus a nasty can be nasty. here, obviously the rational minus irrational must be irrational, so anything like
1-sqrt(2) and sqrt(2) add together to give what you want.
the same works for continuous and discontinuous functions, invertible and uninvertible matrices, rational and irrational numbers, algebraic and transcendental numbers and so on.
I looked at the paper referred to above. There are no proofs at all. The author refers to φ2 as a "composite" number with no explanation of what "composite" is supposed to mean for a non-integer number. All he does is show that 15 decimal place computations come out the same, then spends the rest of the paper defining "fraction", "rational", "irrational", etc.
proof: if n is rational and m is irrational set [tex]n + m = l[/tex] is rational then [tex]l + (-n) = m[/tex] is rational, a contradiction
Yes, that was what most bothered me. Normally there's a certain semblance of internal consistency in these pseudoproofs, but this one just didn't define enough to come to a contradiction that I was patient enough to find.
You could also argue by contradiction that if
[tex]\sqrt5 + \sqrt3[/tex] is rational then so must [tex](\sqrt5 + \sqrt3)^2[/tex] and something bad will happen.
show me how by contradiction
Assume [itex]\sqrt{5} = \frac{a}{b}[/itex] for some integers "a" and "b".
Then
[tex]a^2 = 5 b^2[/tex]
The LHS of the above equation has prime factor "5" to an even power while the RHS has prime factor "5" to an odd power. This is an obvious contradiction.
The contradiction arises when you try to proof that sqrt(15) is rational.
