Calculate Maximum Momentum of Pelle Cycling up a Hill
  • Thread starter Thread starter Izekid
The discussion focuses on calculating the maximum torque (momentum) Pelle can exert while cycling up a hill. Pelle, weighing 68 kg, applies force through pedals with a radius of 0.18 m. The incorrect calculations presented initially led to a torque value of approximately 667.76 N, while the correct torque should be 120 Nm. The formula for torque, M = r × F, is emphasized as crucial for solving this problem.
  • Understanding of torque and its units (Nm)
  • Basic physics concepts related to force and motion
  • Familiarity with the formula for torque: M = r × F
  • Knowledge of cycling mechanics and body weight distribution
  • Study the principles of torque in rotational dynamics
  • Learn how to apply the torque formula in practical scenarios
  • Explore the effects of body weight on cycling performance
  • Investigate the relationship between pedal radius and torque generation
Cyclists, physics students, and sports engineers interested in optimizing cycling performance and understanding the mechanics of torque in cycling.
Izekid
Pelle who weights 68 kilos, cycles up a steep hill. He stands up and pushes all his weight on the pedals. Pedals moves in a circle with the radie 18cm. Which is the biggest momentum he can affect the pedals with
Well my answer is wrong but this is how I did
Because I don't know the answer I take
m2= 9,82*(0,18)^2 = 0,318168/6,67*10^-11 = 4770134933
Which is the second mass
M1 = His weight 68kg
Then I take 68*4770134933 =3,24691754^10*-11 * 6,67*10^11 = 21,635424
and then I finely dived it which is 21,635424/0,18^2 = 667,76 N
I get but it's not right answer should be 120Nm please help me !
The unit of moment of a force (often called torque) is Nm, and the equation:
[tex]\mathbf{M} = \mathbf{r} \times \mathbf{F}[/tex]
This problem has little to do with gravitation.
  • · Replies 31 ·
