The discussion centers around the appropriate units for pressure when using the Clausius-Clapeyron equation to determine the boiling point of a substance. Participants explore the implications of different units on the equation and its application, including the relationship between pressure, temperature, and enthalpy of vaporization.
- Homework-related
- Technical explanation
- Debate/contested
- One participant questions whether pressure should be in torr or atm when applying the Clausius-Clapeyron equation, noting that using R=8.314 leads to unit cancellation.
- Another participant clarifies that using P=1 atm results in a solvable equation for temperature, challenging the initial claim of cancellation.
- Concerns are raised about the units of temperature and the intercept 'b' in the equation, with one participant suggesting that the equation may be limited to finding the slope only.
- A participant introduces the concept of activity and its relationship to pressure, suggesting that pressure is an approximation of activity, which is unitless.
- One participant recommends using SI units, stating that pressure should be in Pascals when using R in J/K, and emphasizes that ln(P) remains unitless regardless of the pressure units used.
- There is a discussion about the dimensionality of Hvap/RT, with participants agreeing that it is dimensionless.
Participants express differing views on the implications of using various units for pressure in the Clausius-Clapeyron equation. While some agree on the dimensionality of certain terms, there is no consensus on the best approach to take regarding units or the necessity of using different forms of the equation.
Participants mention potential limitations regarding the assumptions made about pressure and temperature units, as well as the interpretation of the intercept 'b'. There is also uncertainty about the applicability of the equation in different contexts.
