Rigorously understanding chain rule for sum of functions
The discussion centers around the application and understanding of the chain rule in the context of the Euler-Lagrange equation, particularly focusing on the derivative of a functional defined as a composition of functions. Participants explore the nuances of differentiating composed functions and the implications of notation in this context.
  • One participant expresses confusion about the computation of the derivative of a functional and seeks a rigorous proof using the definition of the derivative.
  • Another participant points out issues with the notation used, suggesting that the expression for the derivative should be redefined to avoid confusion.
  • Some participants propose defining a new function to clarify the differentiation process, specifically suggesting the use of the composition of functions.
  • There is a discussion about whether the chain rule applies in this context, with some arguing that it does while others express skepticism about its applicability to the specific case at hand.
  • One participant mentions the potential for misunderstanding due to the definitions of terms involved and suggests providing clearer definitions for better assistance.
  • Another participant notes that many calculus proofs may still hold validity in new contexts, encouraging a step-by-step examination of the original proofs to identify any problematic steps.
Participants do not reach a consensus on the application of the chain rule or the rigor of the definitions used. There are competing views on the clarity of notation and the appropriateness of the derivative definitions in this context.
Limitations include potential misunderstandings arising from the notation and definitions used, as well as the specific context of differentiating functionals versus standard functions.
Avatrin
In my quest to understand the Euler-Lagrange equation, I've realized I have to understand the chain rule first. So, here's the issue:
We have g(\epsilon) = f(t) + \epsilon h(t). We have to compute \frac{\partial F(g(\epsilon))}{\partial \epsilon}. This is supposed to be equal to \frac{\partial F(f)}{\partial f}h(t) when \epsilon = 0. However, this does not make any sense to me. Doing the computations and using the chain rule, I get:
$$\frac{\partial F(g(0))}{\partial \epsilon} = \lim_{\epsilon \to 0}\frac{F(g(\epsilon)) - F(g(0))}{g(\epsilon) -g(0) } \frac{g(\epsilon) -g(0)}{\epsilon} = \lim_{\epsilon \to 0}\frac{F(f(t)+\epsilon h(t)) - F(f(t))}{\epsilon h(t) } h(t) $$
On an intuitive level I can understand it. I can think of f(t)+\epsilon h(t) as f+\Delta f since h can be any arbitrary function, and that allows me to use the other definition of the derivative. However, it does not seem like a very rigorous way of doing it.
How can I show that \frac{\partial F(g(0))}{\partial \epsilon} = \frac{\partial F(f)}{\partial f}h(t) using the definition of the derivative? Or, rather, a definition of the derivative..?
The notation is not quite right, and that can easily cause confusion. The expression ##\frac{\partial F(g(0))}{\partial\epsilon}## has two problems. First, the thing after the ##\partial## in the numerator needs to be a function, but what is there is not a function but a value, ie a number: ##F(g(0))##. Secondly, all the functions you have presented are single-variable functions, so there is no need for the partial derivative symbol ##\partial##.
The second issue is easily fixed by replacing ##\partial## by ##d##. To fix the first issue, let's first define a function that is the 'function of a function' we are interested in. We define single-variable function ##G## such that ##G(\epsilon)=F(g(\epsilon))##. Then we want to calculate ##G'(0)##, where the prime symbol ##'## indicates differentiation.
These things are easier to write and work with if we use the function composition symbol ##\circ##, which plays the role that, if ##\phi,\psi## are single-variable functions then ##\phi\circ\psi## is the single-variable function that, given an input of ##x##, returns value ##\phi(\psi(x))##. With this notation, we have ##G=F\circ g##.
The chain rule tells us that ##\left(F\circ g\right)'=(F'\circ g)g'##, which means that, evaluated at ##x##, this gives ##F'(g(x))\times g'(x)##.
In the OP, it appears we want to evaluate the derivative of ##G## at ##\epsilon=0##. The chain rule tells us that this is:
$$ G'(0) = \left(F\circ g\right)'(0) = F'(g(0))g'(0) $$
Then, differentiating the expression you gave for ##g##, we see that ##g'=h##. Substituting that in, we get:
$$ G'(0) = F'(g(0))h(0) $$
which appears to be the result sought.
No, that is what every resource on the Euler-Lagrange equation tells me. However, since we are differentiating with respect to \epsilon we should have that \Delta g = \Delta \epsilon h.
The issue is that none of those resources tell me why what you are writing is true. I can prove the chain rule. However, none of the proofs I know seem to apply for this particular case, and the notation used by both of us hides that. That is why I specified that I want a proof that uses the definition of the derivative.
Why do you think the chain rule doesn't apply? We have a composed function ##G=F\circ g## and we want to differentiate it. That's exactly what the Chain Rule is about.
Perhaps it would help if you tried to re-express what it is that you have been asked to prove. As per my previous post, the statement in the OP doesn't make sense, as the thing it purports to differentiate is not a function.
Do you have some other definition of the derivative that you prefer? The limit of the ratio of deltas that you used above seems like that original definition and rigorous.
So, you two together make me wonder if my textbook is not misleading me since the derivative of a functional may be defined differently than the definition I have been using above. I am trying to differentiate a functional since this technically falls under the calculus of variations. However, my textbook claims you only need multivariable calculus to understand the equation. Using those definitions, it does not make sense that we do this: \Delta \epsilon g = \Delta f and call it a day.
Like I said in my original post, it makes sense on an intuitive level, but it just doesn't seem very rigorous unless it is defined that way. Skimming through a few articles on functional derivatives online, it does indeed seem to be the case that the functional derivative is defined in a way that computationally makes it equal to \Delta \epsilon g = \Delta f (at least in this case).
Part of the trouble is you have not defined any of your terms. If you still want help, I suggest you post definitions of the terms ##f,g,h,F,\epsilon## and explain what it is that you are trying to prove. It may also help to post an image of the page(s) that you are having trouble understanding.
The very first sentence in my OP says I am trying to understand the Euler-Lagrange equation. So:
F is a functional
f and h are continuous functions
g I did define in my original post
##\epsilon## is a variable
I am just trying to understand a step in the standard derivation of the Euler-Lagrange equation (it is the derivation I see on every website I have been through, including Wikipedia).
It may help to realize that as long as limits and division are defined, many proofs from Calc 1 are likely to be just as valid in a new application. If you have doubts, you should go step-by-step through the Calc 1 proofs and see which specific steps might be problematic in the new context. Then you can address those steps specifically.
In fact, derivatives and calculus can be used an many relatively abstract settings with the same theorems holding.
  • · Replies 16 ·
