Fra
- 4,404
- 724
I personally think that speaking in terms of "position" and "particle" is not the ideal as it leads to unfavourable mental pictures.Sambuco said:Well, something that I find difficult to understand in Barandes' formulation is the role of the "hidden variables". For example, in Bohmian mechanics, the future position of a particle depends on the wave function and, also, on its current position, since both enter into the guiding equation. However, there is, so to speak, no "guiding equation" in Barandes' formulation. In other words, it seems to me that the current position of a particle has no influence on its future evolution, its position is hidden, not only from observation, but even in the equations of the theory.
As the probability of a transition of the subsystem to a different configuration is a stochastic transition from the previous configuration, that "current configuration" influence the future, the future unravels like a random walk. The walk has a real "path", but this path is not an objective beable, it is contextual to the subsystem itself.
I think "memory effects" are encoded in the structure of the configuration spaces, and the transition matrices. But I think there is a more subtle causal link as well, between the past and the emergence of the spaces and transition matrices. But Barandes correspondence seem to not explain than more than hilbert space formulation does. But this causal link would I think not regard normal dymamics, but the evolution of the constraints. Its like two levels of evolution or two kinds of "time", a problem which we also have already in existing theory in evolutionary time and and parameter time for short timescale phenomena.
When a subsystem eventually interacts with a different subsystem, other systems "configuration history" remains in a kind of superposition to the other system. So it's is hidden because the beable is contextual, not hidden because its an non-contextual beable that everyone is accidently ignorant about. This is how uncertainty and definite coexists in difference contexts. It is not a contradiction. It only gets problematic if you try insist that there at all times must exists a transformation between the contexts that restores equivalence. But that to me is the same as to assume evolutionary steady state. Ie. that the dynamical laws are stable. But then this assumption, leaves us with an overwhelming fine tuning task.
So if we are looking for a "handle" to make progress here, I think Barandes perspective suggests a new handle... but it's still an open problem.
/Fredrik
