Frequency Comb (Photonics, Optics)
  • Thread starter Thread starter Astronuc
A frequency comb is a unique light source featuring multiple colors arranged in an orderly pattern, resembling a rainbow, with bright frequencies appearing as spikes on a spectrogram. This technology allows for the simultaneous transmission of multiple data streams without interference, as each frequency acts as an independent channel. Recent advancements in Michal Lipson's lab focused on enhancing LiDAR technology led to the creation of frequency combs using high-power multimode laser diodes integrated into silicon photonics chips. The engineering challenges involved in this integration are significant due to the small dimensions of the light pathways. The ongoing research highlights the potential of frequency combs in various applications, including medical devices and precision measurement technologies.
Astronuc
Staff Emeritus
A frequency comb is a special type of light that contains many colors lined up next to each other in an orderly pattern, kind of like a rainbow. Dozens of colors—or frequencies of light—shine brightly, while the gaps between them remain dark.
When you look at a frequency comb on a spectrogram, these bright frequencies appear as spikes, or teeth on a comb. This offers the tremendous opportunity of sending dozens of streams of data simultaneously. Because the different colors of light don't interfere with each other, each tooth acts as its own channel.
https://phys.org/news/2025-10-powerful-precise-multi-lasers-chip.html
All one needs is the right materials, junctions and optics.
A few years ago, researchers in Michal Lipson's lab noticed something remarkable. They were working on a project to improve LiDAR, a technology that uses lightwaves to measure distance. The lab was designing high-power chips that could produce brighter beams of light.
"As we sent more and more power through the chip, we noticed that it was creating what we call a frequency comb," says Andres Gil-Molina, a former postdoctoral researcher in Lipson's lab.
The breakthrough started with a simple question: What's the most powerful laser we can put on a chip?
The team chose a type called a multimode laser diode, which is used widely in applications like medical devices and laser cutting tools. These lasers can produce enormous amounts of light, but the beam is "messy," which makes it hard to use for precise applications.
Integrating such a laser into a silicon photonics chip, where the light pathways are just a few microns—even hundreds of nanometers—wide, required careful engineering.
Andres Gil-Molina et al, High-power electrically pumped microcombs, Nature Photonics (2025). DOI: 10.1038/s41566-025-01769-z
While not a frequency comb, a YouTube video explained how Disney lost a critical optical splitter that enabled them to create some amazing effects (examples include Mary Poppins, where the characters dance in front of fanciful scenery with no blur) that current technology cannot achieve.
The individuals in the video managed to reconstruct the lost technology, which Disney used, featuring sodium lamps that emitted a specific frequency of light.
Essentially, it's related to a single-tooth comb.
How would the individual lines in the comb be modulated with different data streams? As you may know, the technique is used for digital TV and mobile phones. By splitting a high speed data stream into many parallel ones, the system becomes much more robust and insensitive to echo distortion.
tive to
tive to
I imagine a monochromatic source is modulated by a number of sub-carriers, each with its own data stream. It wouldn't be hard to make the subcarrier frequencies harmonically related to produce a comb. That could make demodulation easier, too.
I am trying to understand how transferring electric from the powerplant to my house is more effective using high voltage. The suggested explanation that the current is equal to the power supply divided by the voltage, and hence higher voltage leads to lower current and as a result to a lower power loss on the conductives is very confusing me. I know that the current is determined by the voltage and the resistance, and not by a power capability - which defines a limit to the allowable...
  • · Replies 20 ·
  • · Replies 21 ·
16K
10K
