A practical way to vaporize fuel for high MPG?
  • Thread starter Thread starter NTL2009
    Engine efficiency
The discussion revolves around the feasibility of achieving high fuel efficiency, specifically 100 mpg, through the vaporization of fuel in a modified 1970 Ford Galaxy with a 427 cubic inch V8 engine. The video referenced suggests that fully vaporized fuel burns cleaner and can operate at a leaner air-fuel ratio, potentially improving mileage, but at the cost of performance due to reduced power output. A proposed solution involves using a pre-combustion chamber to facilitate vaporization while addressing safety concerns and efficiency issues. However, skepticism remains regarding the practicality of such modifications, as achieving high mpg without sacrificing acceleration and power appears challenging. Overall, the conversation highlights the complexities and limitations of fuel vaporization technology in internal combustion engines.
NTL2009
TL;DR
For an automobile ICE, could gasoline be vaporized with a hot plate in a small chamber just before the intake valve to improve mpg at cruising speeds?
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved.
He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been realized. The car appears to vaporize the fuel (versus atomizing in a conventional carburetor or fuel injector). He claims a fully vaporized fuel is homogeneous, which burns faster and cleaner with no pockets of lean/rich, and can theoretically run lean, 40:1 ( versus a conventional ~ 22:1 limit ?). He doesn't mention, but I assume there is much lower throttle pumping loss for better mpg.
While he acknowledges it could be done, he says one drawback is very poor performance. I think because vaporized fuel takes up a large volume, so you can only get a relatively small amount of fuel in a cylinder, so limited power. And I think that is why a large V8 was used. That also makes sense from a Brake-Specific Fuel Consumption (BSFC) viewpoint - that big V8 running near open throttle and near full load (at reduced horsepower) would put the engine at an efficient part of the curve. Of course, you can get high mpg by trading acceleration and using a small conventional engine, but you wouldn't get the claimed advantages of fuel vaporization.
OK, so acceleration would be unacceptable. He goes on to say this could be addressed by using fuel injection to accelerate and start the engine, but he seems to poo-poo this as being too complex, and fuel vapors are unsafe. But I think he overstates this. Could there be a pre-combustion chamber on each cylinder, maybe the same volume of the cylinder, or somewhat larger, to hold a supply of vaporized fuel? I could envision a hot plate in that chamber (before the intake valve), and a fuel injector spraying a fine mist onto the hot plate to vaporize that fuel. It would supply just enough fuel for cruising power, the rest of the fuel for acceleration would be supplied by a separate injector that would not cool the plate. The fuel would have time to vaporize as it would be a continuous process. For a pre-combustion chamber the same size as the cylinder, assume 1800 RPM at cruise, at 2 revs per combustion, so 1800/60 = 30 revs/second, so ~ 1/15th of a second (67 ms) to vaporize the fuel. And at 100 mpg and 60 mph ( 1 mile-per-minute), that's 1/100th of a gallon per minute (let's switch to metric at this point!) or ~ 38 ml, divide by 4 cylinders, round to 10 ml, divide by 60 for 0.167 ml/second. I assume that would be do-able, but don't really know. I don't see where this would be a big safety issue, or overly complex.
A pre-combustion chamber would also address the issue he raises that not all components of the fuel vaporize at the same temperature. He claims these components would build up, and have to be drained collected - which would be impractical. But with the pre-combustion chamber, anything not fully vaporized would just be drawn into the engine in atomized form. I don't see a problem here. He seems to be envisioning a large chamber of vaporized fuel supplying all cylinders.
But, it seems we would still need a large displacement engine to get enough horsepower even for cruising speeds due to the volume of the vaporized fuel. That would be a major disadvantage. As I understand, 0.5 L per cylinder is a sort of practical limit for passenger cars engines, and moving to a V8 would be impractical in cost and size for most cars today. Would a supercharger be able to compensate for this, forcing more air/fuel into the cylinder, so maybe a 4 cylinder or V6 could work? Pollution control is another whole story.
Also, for reference, vaporization was used in some early stationary engines (“surface plate carburetor), so it's far from a new idea. But I also wonder, wouldn't running from propane or methane provide similar benefits as attributed to vaporizing gasoline? It's vapor already, right? And flex -fuel engines exist, but I never heard that they run higher efficiency on vapor?
This is really just a mental exercise / thought experiment. But that video made me very curious. Thoughts?
Lnewqban said:
One problem has been keeping the fuel from reaching the boiling point in hot conditions.
Please, see:
https://www.onallcylinders.com/2015...erstanding-vapor-lock-and-how-you-can-fix-it/
But the vaporization would occur right at the cylinder intake, so really no different from avoiding vapor lock in fuel injected engines today. You keep the fuel liquid up to the injector that would inject fuel onto the hot-plate.
Boomer here.. I've seen countless claims of incredible fuel mileage claims over the years. Most are hyping and selling some sort of gizmo technology that does these amazing things. Classic pitches are that the oil companies bought the patent and have buried or hidden the technology due to greed, etc.. The vaporization claim is a common snake oil pitch. I can assure everybody that 100 mpg with a 427 cubic inch is just not going to happen - maybe if the drive is down hill for miles and miles the the car coasts at 120 mph while the engine idles.
The law of physics apply here.. there's only so energy that can converted into mechanical motion via. a reciprocating four stoke engine and driving several thousand pounds of mass down the road.
Don't fall for the miracle fuel milage gizmo con folks.
However if anybody is interested I can post a solution that could increase your fuel milage by up to 10% - I'll post the solution for free.... Cheap using a common household supplies. please, please ask....
Likes russ_watters
In that case, the solution can't be applied to modern direct injection into the combustion chamber, only to carburetors and injection into intake manifold.
Then, expect a slight increase in the volume and pressure of the heated mix, both of which should be working against the airflow and cylinders filling in natural aspired engines.
Simultaneously, taking thermal energy away from the exhaust gases in the heating device may induce problems with condensation of corrosive vapors in the exhaust system.
There is no much more to squeeze out of this old invention that is the IC engine.
In my personal experience, the surest way of saving fuel has been improving planning, reducing accelerations and speeds, and avoiding unnecessary braking and trips. :smile:
My guess is that the engine employed a gas mixer, like on an LPG fuelled vehicle, but produced the gas by boiling high octane gasoline. It is just possible, that it was economic, but with such poor performance, it would be a hazard on the road. Maybe, isolating half the cylinders was employed to halve the engine capacity, to reduce the fuel required.
"Lean burn" gasoline engines, like diesels, run cool, are low NOx, but they are not pollution free. It could not operate under today's emission control laws.
The art of good story telling, involves releasing a minimum of information, and keeping secrets right up to the end. The inventor kept the secret, he claimed it was worth a million dollars, but then he died following a mysterious gunshot wound.
Likes russ_watters and Lnewqban
digitalghost said:
Boomer here.. I've seen countless claims of incredible fuel mileage claims over the years. Most are hyping and selling some sort of gizmo technology ...
Of course (also a boomer, if that matters?), and if that's all there was to this, I would not have posted it to this forum. The reason I found it interesting is, the youtuber I link says that he does think it was possible, he says the math works. But with caveats (see next post)...
edit to add:
It was a round trip, ~ 100 miles out, 100 miles back on the same route. So that was taken into consideration. Not that there couldn't be other 'cheats' that went undetected, but that's beside the point. Whether the demo was real or not, the author of that video, who seems knowledgeable, feels that it was possible.
Baluncore said:
My guess is that the engine employed a gas mixer, like on an LPG fuelled vehicle, but produced the gas by boiling high octane gasoline. It is just possible, that it was economic, but with such poor performance, it would be a hazard on the road. ...
Yes, this is what the author of that youtube video seems to think as well. That it is possible to do, but with very poor performance. I think all cylinders were needed, just to get enough fuel into the engine to even reach cruising speeds.
I was meaning to do some math - how much vaporized fuel could a 427 cu in engine take in per evolution? Is that enough to power that car at 45 mph (I assume he kept speed pretty low). That's why I think a large V8 was used - you need that much displacement just to process enough fuel/air. I think the key to this boils down (no pun intended) to that lean fuel/air ratio which vaporization allows.
Instead of that math, just thinking in relative terms, if a vapor is ~ 40:1 (mentioned in the video), and a 'normal' engine is running closer to stoichiometric (14.7:1), it is taking in ~ 0.36 less fuel. So the engine would produce ~ 0.36 the power, assuming the same efficiency. In effect, the throttle would be ~ 2.7x more open at cruise than it would be on the 'normal' engine. And, as mentioned above, this would put it closer to the 'sweet spot' on the BSFC map, adding to efficiency.
As stated in my OP, part of this possible 100 mpg comes from, in effect, running a small (say 20 HP) engine at near wide open throttle at near full load. You can get very good mpg, but can't accelerate enough for safe driving, or maintain speed up a grade or into a head wind. Then add in the supposed efficiency of vapor vs atomized fuel, and you just might get 100 mpg. But with vapor, you need that large displacement engine to get even 20 HP (or whatever it takes for cruise speed).
Another viewpoint on my ~2.7 throttle ratio between vaporized and atomized fuel:
Say the 'normal' engine RPM at cruise is 1800. The vapor engine would need 2.7x more fuel/air. That would take 2.7x the RPM (well, I'm not sure how the throttle plays into it - but ignoring that for now), which would be 4860, which is probably near peak HP (and efficiency) for that engine. So just another way to look at how it moves closer to peak BHFC efficiency.
NTL2009 said:
"Of course (also a boomer, if that matters?)
AKA, experienced, been around the block, heard the nonsense before, you can't fool me, etc. It's a introductory qualifier statement - old people understand this...
Let me add - I'm a boomer and a licensed Aircraft Technician (F.A.A Airframe and Power plant licensees) on top of that I'm a Mechanical engineer and License PE as well - 40 years+ experience. Oh ya, and I've done automotive fuel system and exhaust emissions control systems design and engineering.
Complete nonsense - it did not happen they were not getting 100 mpg out of a 427 cubic inch V8 1970 Ford Galaxy in 1977.
Atomize the fuel perfectly it will never happen - the math say no, the physics say no, the engineering says no and conservation of energy says no, and the con and urban story has been told over and over.
So called innovative fuel systems that perform miracles are nothing new. Either there's peer reviewed test results or not - and there NEVER IS VERIFIABLE TEST RESULTS.
digitalghost said:
.... Complete nonsense - it did not happen ...
I think you are missing the point of my post. I don't care if it happened or not, that's not my focus. I'm interested in "driving for answers"'s analysis. The idea that it is at least feasible that a large V8 could approach 100mpg with vaporized fuel (or not) is something I find interesting.
What math would rule it out? First, determine how much HP it would take to propel a vehicle that size at 45 mph. Again, assume the car maintained this slow, constant speed to reduce wind resistance, and assume a path chosen with no/few stops. Are you saying a 427 CI engine simply could not 'inhale' enough vaporized air/fuel to achieve that HP (taking into account the engine is likely running near it's most efficient BSFC)?
And as we have been discussing - in one way, it's not important if it is feasible or not, since the performance would be so poor, it isn't going to be implemented anyway. I'll repeat the lines I closed my OP with:
According to my googling, modern trains get ≈500 mpg per ton. I'm guessing Tom's galaxy weighed about 2 tons, so that would be ≈200 mpg per ton. Less than half as efficient as a train. Next!
There were one or more tricks involved in the 100 mpg demonstration with that big V8. Maybe the wind direction changed midday, so there was a negative air resistance each way. Maybe the tires were inflated to 100 psi.
100 mpg is more easily done outside the USA, because imperial gallons (4.546 litre), contain 20% more energy than US gallons, (3.785 litre).
If the fuel intake is less because it produces less power, then it is not more efficient.
If the "normal" car requires, say, 20 hp, to produce, say, 20 mpg, then for a fair comparison, the modified engine must also produce 20 hp for the 100 mpg claim.
When I drive at 30 mph on the highway, my MPG drops to about half what I usually do at 60 mph, because the power required to fight aerodynamic drag drops drastically. (Yes, I tried it.) There is no need to modify the fuel system to achieve such a claim.
BSFC would be more meaningful than MPG.
That being said, I assume he did not drive the car at 10 mph for his round trip to show everyone his car reached 100 mpg.
So it comes down to that claim:
Let us assume that the new fuel system burns every atom of fuel. If it can achieve a fuel consumption 5 times lower than the original car, producing the same power, then it means the original Detroit engine is burning only 20% of its fuel, with the remaining 80% passing through the exhaust system.
Does that seem logical? Do we believe that a 1977 engine was that inefficient? I don't think so.
Likes russ_watters, Lnewqban, Ranger Mike and 1 other person
I did not miss any point... I worked on teams designing both Compressed Natural Gas (CNG) as well as Propane - both fuels are a gas when entering the combustion chamber and there's a minimal (negligible) increase in fuel milage per unit of heat energy converted into mechanical energy due to the fuel being a "gas". The advantages of those fuels are in the emissions produced however be aware that there are other challenges associated with storage, safety and production costs of those fuels.
The inefficiencies of internal combustion engines are limited to the four and two stroke cycles - four stokes in a perfect world would be 25% maximum efficiency (100%/4) at the power output and reality is closer to 20%. Two strokes are less efficient.
There have been untold million of hours in engineering, design and scientific research and development on internal combustion engines. At this point squeezing more fuel efficiency out of internal combustion engines is like searching the couch for pennies. All strategies for increased fuel milage are smaller displacement and less mass to move around... Hybrids are a different discussion.
Have this conversation --- electric motors range from 75% up to about 95% efficiency in converting unit energy into mechanical power.
I'm done - good luck.
Likes Ken Fabian, OmCheeto and russ_watters
russ_watters said:
I did some simple cals on this once here, but can't find them, so I'll recreate:
Gasoline has an energy content of 33.41 kWh / gal, or 44.8 hp-hr/gal:
... A simple example is 60 mph at 30 mpg = 2 gal / hr or 89.6 hp-h. ...
OK, so I took that and worked backwards from 40 mph (some searching says that rolling resistance and wind resistance ~ equal at that speed), and I found some support for less than (how much less?) 20 HP at that speed, for a typical mid-sized car (probably better tan a 1970 Galaxy though). That 20 HP number seems pretty reasonable. I found one seemingly good source, but for a BMW 8 series, that showed 9 engine HP required @ 35 mpg,
So at 40 mph, that's 44.8/(100/40) ~ 18 HP. So that 1970 Ford, or even a typical modern family car, isn't going to have as low a wind/rolling resistance as a BMW 8 series, and even if it did, that would be better than 50% efficiency, which is around the theoretical limit of a spark ignition engine, and could not be expected w/o other major changes.
I'll re-watch that video, I'm a little surprised the author didn't do that calculation. I think he focused on what he considers a fact that vaporized fuel will increase efficiency over atomized fuel.
digitalghost said:
The inefficiencies of internal combustion engines are limited to the four and two stroke cycles - four stokes in a perfect world would be 25% maximum efficiency (100%/4) ...
I'm not following this. You are simply dividing the energy content of the fuel by 4, because the power stroke is 1 of 4? Seems conventional engines are achieving 25% or better. Under this entry in wikipedia, for Otto Cycle engines, https://en.wikipedia.org/wiki/Thermal_efficiency#Engine_cycle_efficiency
Modern engines have compression ratios in the range 8 to 11, resulting in ideal cycle efficiencies of 56% to 61%
A rule of thumb is that a typical normally aspirated automobile gas engine burns 0.5 lbs of gasoline per horsepower-hour. Since gasoline has a heat content of 20,000 BTU per pound, and one horsepower is 2545 BTUH, that is an efficiency of 25.5%. Modern engines are more efficient. From Wikipedia, which lists this page as the source: https://web.archive.org/web/20061010095104/http://www.epa.gov/otaq/models/ngm/may04/crc0304c.pdf: Engines in large diesel trucks, buses, and newer diesel cars can achieve peak efficiencies around 45%.
This thread, in Post #2, has some real world drag and gas mileage data: https://ecomodder.com/forum/showthread.php/coastdown-test-06-gmc-canyon-20405.html. The actual gas mileage matches the mileage calculated from the measured drag when the engine efficiency is assumed to be 0.5 lbs per hp-hour.
My current truck does a lot better. Highway mileage at 55 MPH in the summer is typically 47 MPG, primarily due to the high efficiency of the engine.
Likes russ_watters
You must have a hybrid.... What the make and model? Wife and I rented a hybrid Mercedes C300 on vacation and it only got 42 pure hwy.
One stroke creates power - the other three do not... they eat power output.
Mechanical power out at the crankshaft = Power out combustion stroke - everything else (friction, heat, fluid restrictions, and a bunch of other stuff)
Power at the wheel = Shaft power - all kinds of friction and heat.
Engines are smaller (displacement) today, precision technology has optimized fuel delivery, variable ignition timing, light materials, less mass to push around, less friction, aerodynamics are better, plastic bumpers vs chrome plates steel, etc..., etc.. these are the pennies I'm referring to.
Seriously I'm done... enjoy and nobody got 100 mpg out of a 427 ever...
NTL2009 said:
TL;DR Summary: For an automobile ICE, could gasoline be vaporized with a hot plate in a small chamber just before the intake valve to improve mpg at cruising speeds?
This thread is more and more reminding me of my very first thread, and the image that inspired it:
The image confused the hell out of me.
Likes russ_watters
It appears to have been a 351, and not a 427.
Two hundred miles on less than two gallons of gas? That’s the spectacular fuel economy Tom Ogle got when he test drove a beat up, 4,600 pound, 351 cubic inch, 1970 Ford Galaxie on April 30, 1977, from El Paso, Texas, to Deming, New Mexico, and back. [ref: Argosy Magazine, August 1977]​
Guessing there were more journalists than motorheads covering the story back then.
Likes russ_watters
In an ideal reciprocating engine, any thermodynamic loss found in the compression stroke is compensated by the gain in the following expansion stroke, effectively requiring - or producing - no work. It means than an ideal reciprocating engine would spin forever at the same RPM once started until you stopped it, no fuel required.
In real life, there is friction, and if you want the engine to spin continuously (idling) you need to burn some fuel to compensate for those friction losses. Those friction losses might require something like 1 hp worth of energy. It doesn't matter how you deliver that fuel: if it you get 1 hp of energy out of that fuel, the engine will idle indefinitely at the same [average] RPM. Once you've burn that amount of fuel, any extra fuel you put in the engine will go towards accelerating the engine or fight some load you put on the engine. It could be an extra 1 hp or it could be an extra 100 hp. That doesn't mean the 101 hp engine has a more efficient combustion that the 2 hp engine.
One of my favorite engine is a Hit-and-Miss engine which is a regular 4-stroke engine with the throttle constantly wide open, and the speed is govern by allowing fuel to go in the power stroke only when required. So they can go on for dozens of strokes without using any fuel, then when the speed drops, you hear one power stroke. Following, is a video that explains well how they work. They are so simple and slow that you can see every stroke and hear every power stroke.
These engine are not less efficient because they have so many "dead" strokes. If you put more fuel, the engine will accelerate. If you add a load on the crankshaft, it will slow it down and more power strokes will be effective until you have a traditional 4-stroke engine, running at wide-open throttle.
When we talk about engine efficiency, we are talking about, first, the efficiency of the thermodynamic cycle (Otto, Diesel, Brayton, etc.) to convert the energy content of the fuel to mechanical work, and second, the capacity of burning completely the fuel before it goes in the exhaust, and finally, the amount of friction lost in the mechanism. The intake, compression and exhaust strokes are not losses per say as there is no fuel going in to be lost in the first place.
Likes NTL2009, Lnewqban, russ_watters and 2 others
https://en.wikipedia.org/wiki/Gasoline_gallon_equivalent#Gasoline_gallon_equivalent_tables
A simple example is 60 mph at 30 gpm = 2 gal / hr or 89.6 hp-h. If the engine is operating at 25% efficiency, that's 22.4 hp.
Google tells me though that a 1970 Ford Galaxie got about 16mpg.
Adding to this: a Mustang Mach-E gets about 3 mi / kWh, almost exactly equivalent to 100mpg, or 12 hp at 80% efficiency. It's in the ballpark of a fair comparison to a modern ICE sedan, since the efficiency of the ICE engine is probably below 25% when it is producing 10% power, and that doesn't include drivetrain losses (electric cars directly power the wheels whereas gas cars lose maybe another 15% between the engine and wheels).
The Galaxie is going to be much less aerodynamic...
There's not a lot of room to improve on the 100mpg-e for an electric and not a lot of room to improve on the fuel economy of a modern gas powered car either, without compromises. The claim in OP requires something akin to 'you're only burning 20% of your fuel', and that just isn't happening.
Likes NTL2009 and Lnewqban
These engine are not less efficient because they have so many "dead" strokes. If you put more fuel, the engine will accelerate. ...
A few years back, I was at a local 'Farm & Heritage' type show, and a number of presenters had these hit-and-miss stationary engines. I'd seen them before, and just figured they ran really poorly at low speeds! I talked to one guy, and he explained it to me, and put on a power belt and loaded it down, and then I could hear it kick in on every stroke until it could hit the governed speed again. Remove the load, and it goes into that odd sounding, single 'putt', until it slows down a few seconds later, then another 'putt' or 'putt'-putt'. Very interesting, and I have a much better appreciation for these now!
Likes russ_watters
So allow me to move this away from whether or not the original 100 mpg claim has merit or not (since it seems clear that it doesn't), and phrase it a different way (which is more along my original intent anyway, but I guess I worded it poorly):
Could vaporizing (versus atomizing) the fuel at cruising and other low-load conditions practically improve MPG for a typical passenger car?
In the video I posted, the author does seem to think there is merit to vaporizing the fuel, but dismisses it as too complex, too dangerous, and a performance killer. OK, but could my suggestion of having a pre-combustion chamber (maybe the same size as the cylinder displacement) right before the intake valve, with an injector and hot plate to aid vaporization make it safe? Performance could be maintained by just injecting more fuel for acceleration - that fuel wouldn't get vaporized, but would be no worse than current implementations. But if the vaporized fuel would improve MPG for cruise, it would bring up the average MPG.
I think this is a pretty good reason to believe there is next to no benefit:
Just being liquid vs vapor doesn't say much - it doesn't change the amount of energy available by more than a few percent (e.g., you could preheat a liquid fuel). In order for there to be much of a performance hit due to the fuel being liquid, it would have to be not burning or burning very late, and that just isn't happening.
You may be interested in a lean-burn engine with pre-chamber combustion.
Another thing is about the flame propagation speed that he talks about at 10:30 in your video:
The flame front does not travel from one molecule to the next. That is way too slow. The airflow must be turbulent and move much faster than the flame front. The following video shows a technique called the tumble flow:
Or the swirl:
Or the quench or squish:
More info: Quench Quest - Squish, Quench, and Piston-to-Head Clearance
I built a 493 CID Chrysler Wedge engine with Quench. I had .060" piston to head clearance. Compression ratio was 11 to 1 running unleaded pump gas. Had cold air intake. Fastest car I ever drove. Estimated 630 HP from similar Stoker 440 cid engine. Cam had .613" lift. Big CID engines love lots of lift. No detonation.
16K
25K
25K
