sevensages
- 177
- 38
- TL;DR
- Why does the amperage go real high if there is a low voltage short?
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage short caused the amp draw to go so high that the fuse blew. Why did the low voltage short of the exposed metal of the thermostat wire touching the metal cabinet of the air handler cause the amp draw to go so high?
I'm not an electrical engineer like you people. Please explain this to me like I am a five year old.
