When are Markov Matrices also Martingales?
  • Context: Undergrad
  • Thread starter Thread starter WWGD
Markov Chains can exhibit Martingale properties under specific conditions, particularly when dealing with symmetric random walks where the probability p equals 0.5. The discussion highlights that risk-neutral probabilities are martingales, although they do not necessarily equal 0.5. Additionally, the conversation touches on income decile transition matrices and their stabilization behavior, suggesting that the dominant eigenvalues of the Markov matrix M approach the kth root of unity. The correctness of the formula M^k = n^(k-1) * c^k * J, where J is a constant matrix, is affirmed.
  • Understanding of Markov Chains and their properties
  • Knowledge of Martingales in probability theory
  • Familiarity with eigenvalues and eigenvectors in linear algebra
  • Experience with transition matrices in stochastic processes
  • Research the properties of symmetric random walks in Markov Chains
  • Explore the concept of risk-neutral measures in financial mathematics
  • Study the implications of dominant eigenvalues in Markov processes
  • Investigate the application of transition matrices in income distribution analysis
Mathematicians, statisticians, and data scientists interested in stochastic processes, particularly those studying Markov Chains and their applications in economics and finance.
WWGD
Homework Helper
TL;DR
Two con
Are there known conditions under which a Markov Chain is also a Martingale? I know only that the only Random Walk that is a Martingale is the symmetric one, i.e., p= 1-p =1/2.
If you have an nxn Markov matrix the first thing you need to decide is what does expected value mean? You have n discrete observations, are they the numbers 1 through n or something else? If your Markov chain is a random walk on a graph of n vertices the question doesn't even obviously make sense
WWGD said:
TL;DR Summary: I know only that the only Random Walk that is a Martingale is the symmetric one, i.e., p= 1-p =1/2.
Risk neutral probabilities are martingales but <> 0.5
https://en.wikipedia.org/wiki/Risk-neutral_measure
Can arbitrarily create a martingale with any binomial process
Thank you both. Im thinking about income decile transition matrices. If the matrix M tends to stabilize at abouth the kth iteration, I assume the dominant eigenvalues of M would be close to the kth root of unity, right?
Related question: Let M be an ## n \times n ## constant matrix, with constant value ##c## and let ##k ## a positive Integer. Is this formular correct : ##M^{k}=n^{k-1} c^{k} J ##, where ##J## is the constant ## n \times n ## matrix with ##c ==1##?
The formula is correct.
  • · Replies 24 ·
28K
