I Where did the early photons go?
Photons emitted after the universe cooled enough to allow atoms to form became transparent and now contribute to the Cosmic Microwave Background radiation we observe today. The discussion explores the nature of the universe's expansion, questioning whether it has an edge or is infinite, with participants emphasizing that the universe is either infinite or closed and boundaryless. The concept of comoving coordinates is introduced to explain how distances between objects increase over time without actual movement through space. Participants clarify that the expansion of the universe is a function of the underlying spacetime geometry, not the movement of objects through space. The conversation highlights the complexity of understanding cosmological principles and the mathematical frameworks that describe them.
  • #31
John Helly said:
I interpret this as analogous to 'zooming' a view in an image. The coordinates are not changing but user's viewport is.
Except that it is not. Because there are things that do that change. For example: the length of time it takes light to travel from one coordinate to another.
If cosmological expansion were akin to zooming a viewport, then light would take the same length of the time to travel from one galaxy to another, no matter the 'zoom setting'.
Let's say the Virgo cluster is 65M light years way.
Let's say, in a billion years, it will be double that distance: 130M light years away.'
In your "viewport model", instead of the distance doubling, we are simply taking 1 billion years to zoom in by a factor of 2.
But if that were so, then it shoudln't change the lrngth of tiem of light propagtion. Light should still take 65M years to reach us from the Virgo cluster.
But that is not what our observations tell us. As things move apart the propagation of light is invariant. i.e. After a billion years, light really does take 130M years to reach us, and therefore it really is 130M light years away. That tells us the expanasion is real.
And a whole lot of other observations fall, if you assume the "viewport model", such as Doppler shifting and the Observable Universe boundary (there woudn't be a boundary in your viewport model).
Space news on Phys.org
  • #32
Cerenkov said:
given the fact that the early universe was opaque and not open to visual investigation, how do we know anything about the universe's density during the first 380,000 years of its existence?
Because we have other ways of inferring what the properties of the universe were before it became transparent to radiation. For example, we measure the relative abundances of light elements in our present universe, and we apply our knowledge of nuclear reactions to infer what the density and temperature of the universe must have been to make those light elements. We know the density and temperature when the universe became transparent to radiation were way, way short of what's required for those nuclear reactions, so we infer that there must have been an earlier time when the density and temperature were much higher.
Of course that's just one line of reasoning. Overall, the answer is that we apply our knowledge of the laws of physics to back-calculate what must have happened before the universe became transparent to radiation. Those laws of physics include GR, meaning curved spacetime, and we have built a model of the universe's evolution in time, going back to the end of inflation, that makes use of those laws of physics and matches all the data we have. And that model tells us what the density and temperature were as a function of time.
Cerenkov said:
We neither 'know' nor 'observe' what the early universe was actually doing. Instead we extrapolate backwards in time using physical principles we know well.
Not just "physical principles"--physical laws. As above, we have built a model using those laws. It's not just a vague extrapolation. It's much more than that.
Cerenkov said:
Theoretical models of the early universe make certain predictions and some of these have been confirmed through observation.
Yes. I gave an example above (abundances of the light elements).
Cerenkov said:
when scientists discuss the density of the early universe and its decrease through expansion, are they doing so solely on the basis of this kind of extrapolation?
They are doing it based on the model they have built using the laws of physics and the data we have. As above, it's not just a vague "extrapolation".
Cerenkov said:
given the lack of a boundary to yield a frame of reference for density
You don't need a boundary to have a meaningful density. Density is a local concept, not a global one. You can measure the density of air around you without having to know the total volume of the Earth's atmosphere, or whether it has a boundary.
Cerenkov said:
how do we know that the density at one time was different from that of an earlier time?
Because of the model we've built using the laws of physics and the data we have.
Cerenkov said:
In this thread the use of a coordinate system has been discussed as a way of measuring expansion.
No, as a way of describing expansion. And it's not necessary, just convenient. There are invariants, independent of any coordinate system, that describe the expansion--I mentioned the expansion scalar in an earlier post.
Cerenkov said:
what about density, which changes as a function of the expansion of the universe? Is that how this works? That if the universe is deemed to be expanding, then density must also be deemed to be falling?
When you construct a model of an expanding universe using the laws of physics, yes, this is what you find.
Likes javisot and PeroK
  • #33
Thank you. I also take your point about BB nucleosynthesis. For that to happen the temperatures and densities must have been very high indeed. I begin to see the strength of the reasoning being done.
Thank you for correcting my tentative language. I was trying to be as careful as possible when writing and not over-commit myself on matters that are far beyond me.
Agreed.
As mentioned above Peter, any implication of vagueness comes from my cautious wording.
Then the early universe's density is inferred by applying physical laws and running the scenario backwards in time in strict accordance with those laws. Thank you.
And this model makes certain predictions about what we should observe now if the inferred conditions existed then. Predictions which have been well confirmed and which now constitute different, but agreeing, lines of evidence.
I will have to go back and study that specific post. Above you use two terms that need a bit more explanation for the layman, invariant and scalar. After reading your post I'll see if I can discover more about them by myself and then try to put things together.
This may well lead to more questions. Seeing as they will pertain to the early universe, they should (I hope) be considered to be on-topic.
Thank you. I think I see and understand more now.
I appreciate you taking the time to answer my questions, Peter.
:smile:
Cerenkov.
  • #34
Briefly:
An invariant is a quantity that is independent of any choice of coordinates.
A scalar is an invariant that is simply a number--or rather, a number at each point of spacetime, i.e., a scalar function on spacetime.
  • #35
You're welcome! :smile:
  • · Replies 24 ·
  • · Replies 26 ·
  • · Replies 39 ·
  • · Replies 19 ·
  • · Replies 31 ·
