Is calling fictitious forces "not real" just about terminology?
  • Context: Undergrad
  • Thread starter Thread starter renobueno4153
    Fictitious forces Force
The discussion centers on the distinction between real and fictitious forces in physics, particularly within inertial and non-inertial reference frames. Participants agree that real forces have third law partners, while fictitious forces, such as the Coriolis force, arise from the choice of coordinate systems and do not have third law partners. The conversation emphasizes that fictitious forces are not illusions but rather mathematical constructs necessary for describing motion in non-inertial frames. Ultimately, the terminology used in physics can lead to confusion, and a clearer distinction between interaction forces and inertial forces may be beneficial.
  • Understanding of Newton's laws of motion
  • Familiarity with inertial and non-inertial reference frames
  • Basic knowledge of forces and accelerations
  • Concept of coordinate systems in physics
  • Explore the mathematical derivation of fictitious forces in non-inertial frames
  • Study the implications of the Coriolis effect in meteorology
  • Learn about General Relativity and its treatment of gravity as a fictitious force
  • Investigate alternative terminologies for describing forces in physics
Students of physics, educators, and anyone interested in the foundational concepts of forces and motion in different reference frames.
renobueno4153
TL;DR
- Did I understand this concept right?
- If I hear a force is fictitious I think there is like an illusion making me think there is smth happening for the wrong reasons but fictitious forces like the corioles force have actually consequences in the real world. So my question is "real force vs. fictitious forces" just about differentiating two ideas or can the "illusion" of fictitious forces explained by the influence of real forces?
Hi there, im studying nanoscience at the university in Basel.
Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces.
I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real.
I also understand that if you specifically look at non-inertial reference frames you can observe accelerations/forces which you wouldn't in inertial reference frames. And to satisfy newtons first law of motion (F=ma) you need to mathematically adjust that to keep that statement true. So in order to describe the accelerations and forces appearing in non-inertial reference frames you introduce the concept of fictitious forces.
So my question is:
- Did I understand this concept right? (Feel free to call everything wrong out! I dont care about brutal honesty I really want to know!)
renobueno4153 said:
So my question is:
Yes. I agree with pretty much everything you have written about the distinction between real and fictitious forces. A real force (or "interaction force") is one that has a third law partner. A fictitious force will (in almost every case(*)) not have a third law partner.
Here I disagree somewhat. If you look at it in a certain way, the Coriolis force has no real world consequences. One could, in principle, describe the rotating Earth and the weather patterns on it in terms of a non-rotating coordinate system beneath which the ground and winds are whipping past at hundreds of meters per second. This description would make all the same experimental predictions (for wind, rain, barometric pressure, etc) as the more standard model in which the Earth is regarded as stationary.
We adopt the rotating coordinate system because it is convenient. We do not adopt the inertial coordinate system because it would be inconvenient. The "realness" or "fictitiousness" of the modelled quantities is unimportant to that decision.
It is just a choice of coordinate system. One often picks a coordinate system that makes calculations easier. Sometimes a uniformly accelerating system is convenient. Sometimes a uniformly rotating system is convenient. Sometimes a rotating system with rotational acceleration may be convenient and one then has to factor in the Euler force.
(*) When you learn General Relativity, you will be exposed to the idea that gravity is a fictitious force. Despite it having a third law partner. But one needs curved space time to make that idea work out. In the mean time the Newtonian approximation with gravity as a real interaction force is what everyone uses.
The simplest explanation, IMO, is this:
If you measure an object to be accelerating, then there are two different reasons for this:
1) The object is subject to a real force.
2) You are accelerating (subject to a real force) and the object is not subject to that force.
(Note that, of course, it could be a combination of the two.)
Real forces are real - they can directly be measured; fictitious forces are not real - they are needed to balance the books.
The classic example is the scenario of an accelerating car. You feel the real force that accelerates you from the seat. If you look out the window, in your reference frame, the houses are accelerating "backwards". There are no new forces on those houses causing them to accelerate in the opposite direction from the car. Instead, you need to include fictitious forces to explain the relative motion of the houses, from your accelerating reference frame.
Fictitious forces are completely useless and they just obscure the process of problems solving.
  • Love
PS and, as you are at rest in your own reference frame, you have to add the same (*) fictitious force to yourself in order for Newton's second law to hold in that accelerating frame. I.e. you need to add a fictitious force equal and opposite to the real accelerating force you feel. Then the forces on you are balanced in your reference frame.
(*) Note that the magnitude of a fictitious force generally depends on the mass of the object.
Fictitious forces appear as a result of the following banal mathematical trick.
Consider the second Newton relative an inertial frame:
$$m\boldsymbol a=\boldsymbol F.$$ Assume that we have a non-inertial frame as well.
Then the acceleration is presented in accordance with well-known kinematic formula:
$$\boldsymbol a=\boldsymbol a_c+\boldsymbol a_e+\boldsymbol a_r,$$
here ##\boldsymbol a_c## is a Coriolis acceleration;
##\boldsymbol a_e## is an acceleration of transport;
##\boldsymbol a_r## is an acceleration relative the non-inertial frame.
Substituting one formula to another we have
$$m \boldsymbol a_r=\boldsymbol F-m\boldsymbol a_e -m\boldsymbol a_c.$$
The last two terms in the right hand side are so called fictitious forces.
Possibly enlightening
Frames of Reference (featuring Hume & Ivey)
by Richard Leacock
go to 17:05 for the rotating frame
by Richard Leacock
HOLY SMOKES THATS SICK. Ok this video hooked me so much that I watched the whole 20min.
So I can see now that fictitious forces are depended on the reference frame. But do we have an explanation where that change in motion comes from? To be precise: We use fictitious forces to explain how the change of motion came to be. Meaning in the perspective of a non-initial reference frame, we think a force must have changed e.g. the path of an object. And I want to understand where this change comes from in the first place. Does this question make sense, its quiet late here in Switzerland. I cant let go just yet, I need answers! :D
Thx to all of you guys! Much appreciated!
I would say that nothing physical needs to change its state of motion. It is just coordinate systems. Scribbles on pieces of paper. This part of the coordinate system over here right now is moving differently from that part of the coordinate system over there back then. [There can be complexities with comparing velocities here and now against velocities there and then, but leave that for another day. In the flat space time of Newton and special relativity such comparisons are not problematic]
If you are measuring the velocity of a physical object using a non-inertial coordinate system as a reference, you may see that the coordinates for the object's position may not change evenly even if the object is subject to no interaction forces. Its coordinate acceleration may change in magnitude and direction as the coordinate system shifts beneath it.
Of course, we often choose to use non-inertial coordinate systems because they track the motion of some physical object. Like a car, carousel or planet we are riding in. We may lock the x, y and z axes to that reference object. We may even use curved lines like longitude and latitude instead of straight coordinate axes.
You might reasonably ask about the forces that cause a physical reference object to accelerate and gyrate as it does. But that question must be answered on a case by case basis. What interaction forces act on your chosen reference object?
If you did not use a reference object and instead conjured the coordinate system with pencil and paper, the answer is that the motion of the coordinate system came from your choice to use it.
One of the important lessons in first year physics is that one is not obliged to use a frame of reference in which the experimenter is at rest.
Physists of the past have been brilliant at describing nature using math, but terrible at choosing the right words for it. Both naming conventions: "action vs reaction" and "real vs fictitious" are misleading.
There Is nothing In the math of Newton's 3rd that distinguishes between the action and the reaction.
There is no physical quantity called 'realness'. It's simply a distinction between frame independent interaction forces that obey Newton's 3rd law, and frame dependent inertial forces that don’t.
  • Skeptical
  • Sad
Let's hear your better words for displacement, velocity, speed, acceleration, force, mass, energy, momentum, torque, angular momentum etc.
In what way are these words "terrible"?
I must admit I don't generally use the terms "action" and "reaction". But, "real" and "fictitious" make perfect sense to me. I never understood the idea that somehow if we rename everything, all will be clear. Physics is about concepts, not about words.
Sorry, I should have made clear that not all naming choices are bad. And let's not derail the thread by discussing those that weren't even mentioned in the question.
These create endless confusion and flawed approaches to solving force equilibrium problems based on cause and effect thinking.
Those create endlles philosophical debates about what reality is, and if anything in physics is real. Naming them 'interaction forces' and 'inertial forces' is more descriptive.
Which is exactly why one should tell students not to take terms used in physics literally based on their meaning natural language, because that's often misleading.
The confusion may be independent of the words. Choose whatever words you like and the conceptual difficulty remains. Using "invariant" and "coordinate-dependent" may ultimately be clearer, but using those words requires technical prerequisites that the new student may not have developed. And, entails a level of abstraction that may create greater diffculties for the student than grappling with more accessible concepts such as "real" and "fictitious".
Oh yes. And if I don't have time, I don't teach them.
Where? I mean, I understand this thred is an example, but from my experience, most people are ok with friction being real and Coriolis force being not real.
What's wrong with "interaction force" vs. "Inertial force"?
Using technical terms the students cannot fully interpret yet, might be better than using well known words from natural language, which give them the wrong ideas.
Nothing. They are just different names for the same things. If you taught a class of students using those terms and a class of students using the terms "real" and "fictitious", then I'm skeptical that it would make much difference.
My 2 cents: if you're being pushed in your chair because the train accelerates, it's a frame-independent fact that an engine makes the train accelerating. That's why we call this force "real". Your body with inertia just resists this change of speed. In your frame you describe this as a force because per definition you're sitting still in your own frame of reference. That's why we call it "fictitious", because there's no interaction involved (if you're not a Machian).
I think every teacher knows that words are really important in physics. Physics is also about interpretation, or "ontology", or "concepts" as you put it. And that involves wording, which shapes our understanding of everything, including physics. Ultimately, we don't just use math to understand physics.
I think I get your point, but I just want to add this nuance ;)
I broadly agree. Perhaps this is one of the great things about studying mathematics. That you learn to think in terms of the underlying concepts and not the words. I remember (this was over 40 years ago) someone asking why a group was called a group. Dr Youngson replied that we could call it a "splong", if he preferred that!
Unfortunately, quite often in Physics, words have a different meaning than in ordinary language. This is an additional problem for learners. The idea that fictitious forces are a kinda of illusion is quite widespread. At the core of the problem lies the often-overlooked issue of defining force. Without an explicit definition of what a force is, every statement about forces can be true or false.
Just to be explicit, if forces are defined through $F=ma$, fictitious forces should be considered as real. If forces are considered as a consequence of interactions between bodies, we can look at them as an "illusion" originating from the choice of the reference frame. However, we have to understand that the physical effects of such an "illusion" are perfectly real.
"Interaction force" is clear. "Inertial force" for something appearing only in NON-inertial reference frames sounds like an oxymoron. My favourite choice is "pseudoforce".
Fictitious, inertial, pseudo, what does it matter!
It doesn't matter to somebody, no problem. Other people, mostly those who are involved in teaching Physics, understand the difference.
by Richard Leacock
Possibly interesting:
N3 (at least our modern wording of it) only says "for any action. . . . ." You can choose either of the 'third law pair' to be an action. You could. for instance, use the distortion of the ball or the distortion of the racket to be a measure of the action.
And then the other becomes a 'reaction', which in common uses of those words happens after the 'action'. But that's not the case for a 3rd Law force pair, where the forces act simultaneously.
Inertial force, because it's proportional to the object's inertia (mass).
That's just as non-descriptive as fictitious.
  • · Replies 29 ·
  • · Replies 19 ·
