I The Einstein Clock aka Light Clock
  • Thread starter Thread starter DmitryS
The discussion centers on the interpretation of the Lorentz transforms and the constancy of the speed of light as presented in Einstein's 1905 paper. It contrasts two models: the light clock model, which suggests that the speed of light is absolute for photons relative to an observer, and the spherical light wave model, which posits that the light sphere's invariance leads to different observations for moving observers. Participants argue that the two models cannot coexist without violating the principle of relativity, as they imply different distributions of light intensity. The conversation also touches on the concept of relativistic aberration, emphasizing that different frames of reference yield different angular distributions of light, which is crucial for understanding the observed phenomena. Ultimately, the debate highlights the complexities of reconciling these interpretations within the framework of relativity.
DmitryS
TL;DR
apparent problem of Einstein clock
Hello, everyone, hope someone will resolve my doubts.
I have posted here some two years ago asking for an explanation of the Lorentz transforms derivation found in the Einstein 1905 paper. The answer I got seemed quite satisfactory. Two years after I revisit this derivation and this is what I see.
In the Einstein original paper, the Lorentz transforms derivation included as a premise that light is always propagated along the direction perpendicular to the line of motion when viewed from the stationary system with the velocity sqrt(c^2 − v^2). This expression can be considered the first mentioning of what was to become the model of the so-called light clock, where the light travelling vertically for one observer is moving at the angle arccos (v/c) for the other.
There is also a different derivation of the Lorentz transforms with the help of the spherical flash of light originating from the origins of the two inertial frames of reference when those coincide. The transforms are derived based on the assumption that the expression for the sphere of light must be identical for either observer.
I summarized my doubts as follows.
1. The derivation of the Lorentz transforms through the invariance of the light sphere suggests that postulating constancy of the speed of light should be equal to: ‘Any point of space where light originates is considered motionless relative to the inertial observer’. That is to say, if a spaceship generates a pulse spherical light wave at a certain point, the ship will continue moving staying at its centre, while the on-land observer will see the spaceship moving through this sphere of light while seeing the centre of the sphere static (whence relative simultaneity). Thus, the two spheres, one with the centre at O, the other at O’, are identical in every way. Those rays that go up will go up, and those that are in line with motion will be in line with motion. The flux of rays over the entire surface of the sphere will be the same for both observers.
2. On the other hand, the light clock model suggests an entirely different interpretation of the speed of light’s constancy, namely: ‘Any photon will have the absolute value of the speed equal to the speed of light relative to an inertial observer along the trajectory resulting from the composition of motions of that photon and of the observer moving relative to any other inertial observer’. In short, it suggests that the ray going straight up for Observer O’ and the ray going at the angle arccos(v/c) to the line of motion for Observer O are the same physical object.
3. And that means (if we marry this model to the one with the two spheres of light) that the flux of rays limited by the cone with the angle 2arccos(v/c) with the axis coinciding with the line of motion for Observer O must be the same as the flux of the hemisphere towards the same direction for Observer O’. The angle of 2arccos(v/c) will open up and become 2π in the O’ system. If we consider the flux to be constant over the sphere for Observer O, it won’t be constant for Observer O’: the hemisphere on the right will be not so dense with rays as the hemisphere on the left. That, of course, will mean that there’s an objective difference between the two observers and the relativity principle does not hold.
4. The least we can say is that these two models can’t go together. One of them should be false, and since the light clock model violates the relativity principle, the invariance of the two spheres must be correct.
This is it in a nutshell. I never saw this problem mentioned in literature. Possibly someone here has an answer.
I only have time for a quick reply now, just focusing on some issues with your first bullet:
.. in the ship's inertial frame (assuming the ship moving inertially)
No. Though each a circle in their respective frame, each circle represents a different set of events.
This is fundamentally wrong. Look up aberration of light rays. If the flux is even per angle in one frame, it will not be even in the other frame. The angle of all light rays other than directly forward or back will be different between the two frames.
Likes Dale and PeterDonis
DmitryS said:
TL;DR: apparent problem of Einstein clock
This is not correct and it is not an implication of the light cone (sphere).
The light cone says that if there are rays in every direction in one frame (a sphere) then there will also be rays in every direction in the other (also a sphere). It does not map specific rays in one frame to another. That is done with the Lorentz transform.
Likes PeterDonis
Any point is stationary relative to the observer - this is effectively the definition of a point in this context.
No they aren't. They are different slices through the light cone, and consequently have different angular distributions of light. To see this, draw a Minkowski diagram in x-t coordinates showing a light cone, a plane of constant t, and a plane of constant t'. Since the latter is slanted in this coordinate system you will see that one end of the primed coordinates' sphere is further from the origin than the other in the unprimed coordinates. Thus if the light intensity is isotropic in one set it must be anisotropic in the other.
This isn't different. You will find that the position of any pulse of light lies on a sphere centered on its emission point.
Without checking your maths, yes, you seem to be describing relativistic aberration.
No. The principle of relativity doesn't say all observables are the same, just that the laws of physics have the same form. Measuring a different distribution of light does not require different laws of physics - in fact, you just used those laws to derive different intensities.
Likes Dale
Do you mean the case ##v=0##? You get ##2\arccos{} 0= \pi##, but not ##2\pi##.
It seems that you want to describe the headlight effect.
https://demonstrations.wolfram.com/TheHeadlightEffect/
If they record identical measurements of position and time for the sphere of light, but their measurement systems of position and time are not identical, would you call the two spheres "identical"?
That is the situation. Both are equally valid, but their systems of measurement are not the same.
Friends, thank you for all the inputs, because they allow me to make my position clearer.
I don't think the aberration will apply here. As Ibix said, "Any point is stationary relative to the observer - this is effectively the definition of a point in this context". Right, so, wherever the flash is, we consider its source motionless. How do we observe aberration from a motionless source?
To put an end to the assumption that aberration cures the matter, let's forget about the spaceship. Let's consider only the flash coming from the same point of space at the moment of coinciding O and O'. All of you said that the flux will not be the same for both observers.
I don't think it would be right to suggest that a mirror placed somewhere ahead the motion of O' in the line of motion will reflect more light for Observer O than for Observer O'.
My question is not about small details. I expect there's something graver going on here.
You don't. But you can have a moving source, one which is not always at the same point.
The mirror will reflect the same fraction of the emitted light according to both observers (edit: hmm, not sure, see my next post). But they will have different measures of the intensity distribution and different measures of the distance from emission at which reflection occurs, and hence different measures of the angular subtense of the mirror. The combination of different intensity distribution and different angular subtense of the mirror will lead to the fraction of emitted light striking the mirror being invariant.
It is entirely about understanding aberration and the "headlight effect" mentioned by @Sagittarius A-Star, I'm afraid.
Likes DmitryS and Dale
Aberration always applies. Aberration is a disagreement between two different reference frames about the direction of light. If you have different frames and each frame is describing a direction of travel for light, then there is aberration.
By having different frames describe waves moving away from the source. It isn’t about the source, it is about the waves produced by the source.
Consider a phased array source where the phases are set such that the emitted light is isotropic in a frame where the source is moving. The aberration will be with respect to that frame, the frame where the waves are isotropic, not the frame of the source.
Similarly here. If your single-event source emits light that is isotropic in one frame then it will be anisotropic in other frames due to aberration. It is not avoidable.
Well, your question is about relativistic aberration. So I guess that means aberration is not a small detail. I agree.
Likes Ibix
On reflection (sorry) I'm not sure this is correct, and need to do a bit of maths.
It is definitely true that if the source emits a finite number of rays (perhaps it's a lamp surrounded by a wire mesh) then the number of rays reflecting off the mirror is an invariant, although the frames will not agree about the distribution of the rays. However, the total energy emitted by the source is frame dependant, as is the distribution of that energy between the rays. The amount of energy striking and reflected from the mirror is also frame dependant. So, although I am sure that the fraction of rays striking the mirror is invariant, and I'm sure that the energy carried to it is not invariant, I'm not sure about the fraction of the energy emitted that strikes the mirror.
The maths looks messier than I can do without pen and paper (on the train at the moment, and no table) and a cursory search didn't turn up a textbook formula for the energy distribution. I suspect one can combine my ray model with each ray's energy-momentum four vector to figure things out, but I also suspect there's a nasty integral in there.
However, I already mentioned a Minkowski diagram, which the @DmitryS (and anyone else) should really draw any time he thinks he's found a paradox, because they're great at showing you where your misunderstanding was. Here's a light cone in yellow:
Time is on the vertical axis, as usual, with horizontal spatial axes. The emission event is at the origin. Now we can add a blue plane showing what this frame calls "now" a short while after the emission:
Taking a slightly higher perspective we can see that the intersection of the light cone and "now" is a circle:
Assuming that the light intensity is isotropic in this frame then it is clear that the light will have the same intensity at any angle because it's the same distance from the source.
But we can instead draw a plane of constant t' (red):
Notice that the intersection is elliptical, slanted, and its center is offset from the z axis. This shows you immediately that the light cannot be isotropic in the primed frame, because you can see that some parts of the ellipse are (in the unprimed frame where light is isotropic) closer to the emission event's location than others, and will therefore see brighter light by the inverse square law.
The relativity of simultaneity strikes again.
Likes DmitryS, Dale and cianfa72
Ibix said:
Assuming that the light is isotropic in this frame then it is clear that the light will have the same intensity at any angle because it's the same distance from the source.
Why assume the isotropy of light in this frame (i.e. in the frame where the horizontal blue plane has equation t= const). The light cone (yellow) is invariant and in that frame is isotropic, isn't it ?
Only if I specify it to be so. You can draw the same lightcone and planes in any frame. I want to do it in the frame where the light intensity is isotropic so that I can conclude it is not osotropic in other frames without explicitly doing any maths.
Consider a dipole antenna that emits a brief pulse. The emitted radiation is not isotropic in any frame. But the shape of the wavefront is spherical in every frame.
Likes cianfa72
Yes sorry, only later I realized the point was about isotropy of light intensity and not light propagation process (speed).
Likes Dale
No, you don't. The light source is not a point. It's a worldline--the path through spacetime of an object (whatever object emits the light). The event of emission of the light takes place at a point on that worldline, but the motion of the source is the motion of the worldline--which is different in every frame. There is only one frame in which the source is motionless.
Also, note that @Ibix said that the point is motionless, not that the source is motionless when it is at that point.
Likes PeterDonis and Ibix
That's what I call a discussion.
Right, I want to summarize now what I see, because I can't really reply to all the minor things that matter in all your comments, but I thank you all anyway.
1. Let's return to the very beginning. What matters here, as I think, is the relativity principle, which in my mind does not reduce to simply the invariance of the physical laws. Still, the foundation of it is that we cannot distinguish between the situation of any inertial observer, i.e. we must be unable to say which one 'really' has moved.
That's why I prefer to go on an assumption (withot insisting it be correct for now) that the spherical flash of light taking place at the origins of the coordinate systems the moment they coincide must be the same for both Observer O and Observer O' as they both perceive it as a flash coming from a motionless source in their respective frames. If one should insist that this is not so, that the uniform flux of rays for Observer O shouldn't be such for Observer O', we could always remind them that the situation is symmetrical, or otherwise there is an observer in absolute motion and an observer at absolute rest. Each observer has had that flash in their frame considering its source motionless, and we might as well start the argument from the point of view of Observer O'. The outcome of this argument must not depend on the starting point (that's another possible formulation of the relativity principle). If we start it from the point of view of Observer O', we'll get the thinning of flux on the opposite side, and I don't know how to proceed from here.
The arguments mentioning aberration imply continuous radiation, but what we deal with here is a singular momentary burst of photons at the same moment of time for both observers, and it will be very difficult to substantiate the divergence of their trajectories in either frame, unless we postulate - not quite clear on what grounds - that for one observer the quality of flux was this, ergo, for the other one it should be that (again, dependence on the starting point).
I'm saying it again I will not insist that the above is absolutely correct. My purpose for now is that the participants see my problem as I see it.
2. I'm not quite convinced about the outcomes of the mirror thought experiment. I understand @Ibix couldn't go into detail for the lack of convenience and paper, but I guess I must insist we talk specifically about the flux of photons, physical objects, and not the characteristics of radiation, since we deal with a limited number of oscillators and at the end of the day it's all that matters. The number of photons flying back past Observer O' must be the same as that flying back past Observer O.
3. For the Minkowski diagram, let me start from afar. Not so long ago I watched a YouTube video where the presenter claimed the invariance of the Einsteinian equations (ct)^2 = x^2 + y^2 + z^2 and (ct')^2 = x'^2 + y'^2 + z'^2 was all wrong, and to prove his point he showed some drawings plotted by maths software where there were ellipses not circles. I knew he was wrong. I saw his mistake immediately, because some time before I had fooled around with a maths soft myself and made it draw ellipses from the Lorentz transforms. This mistake was representing not the view of the moving observer, but instead the view of the moving observer as seen by the stationary observer.
I'm afraid you can't prove anything by slicing the light cone belonging to the one observer by the plane perpendicular to a diffent time axis. The equations (ct)^2 = x^2 + y^2 + z^2 and (ct')^2 = x'^2 + y'^2 + z'^2 are not different slices of the same light cone - they are two different light cones. Indeed, those are equations of 4-cone with ct or ct' for the axis, and the sphere of light is its 3D projection. So slicing the light cone with ct for the axis by the plane orthogonal to ct' is the error of the same nature as the afore-mentioned YouTuber made, representation of the view of the moving observer not as it is but as seen by the stationary observer.
@Ibix wrote: "You can draw the same lightcone and planes in any frame. I want to do it in the frame where the light intensity is isotropic so that I can conclude it is not osotropic in other frames without explicitly doing any maths". - I'm afraid not. You draw a non-synchronized plane, and that testifies to nothing but to the view of O' by O, not the view by O' themselves.
Before we go any further and speak about what aberration in my mind really has to do with all that (a somewhat complicated topic), we need to agree that there is a problem with the light clock.
  • Skeptical
  • Sad
Likes weirdoguy and PeroK
The explanation of aberration in the light-clock scenario does not only work with classical particles, but also with EM waves.
The reason is relativity of simultaneity.
Assume, a horizontal electromagnetic wavefront segment of vertically moving light crosses the horizontal x-axis. In the primed rest frame of the light clock, the left and right side of the wavefront segment cross the x'-axis simultaneously, that means
##\Delta t' = 0##.
With inverse LT and length contraction follows with reference to the unprimed frame, that the left and right side of the wavefront cross the x-axis with the following time difference:
##\Delta t = \gamma (\Delta t' + {v \over c^2} \Delta x') = \gamma (0 + {v \over c^2} \Delta x') = {v \over c^2}\Delta x##.
For small angles: When the right side of the wavefront crosses the x-axis, the left side has already moved further across the x-axis by
##\Delta d \approx c \Delta t = c {v \over c^2}\Delta x = {v \over c} \Delta x##.
That means, the small wavefront segment is tilted by
##\Delta d / \Delta x \approx v/c##.
Likes Ibix
What else would be involved?
No, they don't. The source can only be motionless with respect to one of them.
Until you fix this fundamental error, everything else you think will be wrong.
Likes Hornbein, jbriggs444, Ibix and 1 other person
Let's stop right here. We will not get far by insisting that "we all must agree that 2 + 2 = 5". A given flash bulb (for example) has one world line, and at any point in its history, it is at rest in the origin of one family of frames connected by rotation. In all other frames, it is in motion. In a frame where it is at rest, its emission is isotropic in frequency spectrum and intensity (for an ideal flash bulb). In all other frames, its emission is affected by Doppler and aberration and is very much NOT isotropic in either frequency spectrum or intensity. Let's agree on these facts before proceeding.
Likes cianfa72, Ibix and PeterDonis
The light clock is really very simple. If you accept the invariance of the speed of light, then time dilation, length contraction and the relativity of simultaneity follow from a few simple thought experiments.
That said, any simple matter can be unnecessarily complicated by confused thinking.
Likes jbriggs444, Ibix and PeterDonis
Maybe it would help to imagine two flash bulbs, one in motion relative to the other. They both flash when one just passes the other. In all frames, the light from the two flashes is different, even though the flash bulbs are each identical in behavior in their rest frames. And the difference is exactly Doppler and aberration.
Likes Nugatory, Ibix and PeterDonis
It's not symerical, because the light source is at rest in one frame, but not the other.
Motion relative to some random light source isn't absolute motion.
I don't think you understand frames of reference if you think the source is motionless in both frames. This confusion has nothing to do with light clocks and Special Relativity. Under Galiean Relativity you would have the same issues.
Likes Hornbein, cianfa72, PeroK and 2 others
Just think about that for a minute. You are standing by the road and a passing car turns on its turn indicator. How are you and the car's driver both going to be at rest with respect to the indicator lamp unless you are also at rest with respect to each other?
If you prefer a more abstract argument, consider a small piece of matter and antimatter that annihilate. There exists a frame where, just before annihilation, the total momentum of the matter and antimatter was zero. Thus the radiation pattern in that frame must be symmetric so that its total momentum is zero. Spherical symmetry is one such pattern, and let's suppose that's what we get. Now consider any other frame. The matter and antimatter have non-zero total momentum so the radiation must also have non-zero total momentum, so it cannot be spherically symmetric.
Likes Nugatory, jbriggs444 and PAllen
They are not. I strongly suggest you use the Lorentz transforms to express the first equation in terms of primed quantities. You will find you get the second expression. They are identical, merely expressed in different coordinates.
Yes. That was not a mistake, that was exactly what I wanted to do. Because I could use that perspective to show that the light distribution in the two frames must be different. Yes, the sphere seen by the red frame is distorted into an ellipse in that representation, but that does not matter. It isn't the (apparent) different shape that I'm drawing your attention to - rather, it's the implications of the distances of the ellipse perimeter from the origin in this frame.
No - there's a problem in your understanding of special relativity.
Likes Dale
Note that the two halves of this sentence do not say the same thing. The last half says you cannot detect absolute motion. But the first half says you cannot even detect relative motion. That is not correct.
They will both be spheres that expand at ##c##. This is a consequence of the second postulate, not the first postulate. In other words, the principle of relativity does not even require them to both be spheres, let alone identical spheres. Your idea that they must be identical spheres does not follow from the principle of relativity. This is an additional thing that you are adding on. I believe it is related to the issue I mentioned above.
This is 100% false, in both special/general relativity and in standard Newtonian physics. The source can be motionless in at most one frame if the frames are moving with respect to each other.
The point at which a flash occurs is motionless in both frames. But that is a substantively different statement than the claim that the source is motionless in both frames. Hopefully you understand the difference between a point and a source, but if not, please ask.
The situation is only symmetrical in the special case that the source is moving at the same speed (different directions) in both frames. Even in that case there will still be aberration, but the aberration will be symmetrical between the two frames.
Here is where you are repeating the same mistake. What you claim as an indication of absolute motion here is only an indication of relative motion.
Untrue
OK, we see it. But the purpose of this forum is educational. So now that you have explained your starting point we must move on from there. Further repetition of the incorrect assertions is not needed. You can always refer back to here if needed. Now we must go forward.
No, there is not a problem with the light clock and we should not agree with that. What we can agree with is that there is a problem with your understanding of the light clock. Helping resolve such problems is the purpose of this forum.
I think that the key issue is this one:
You kept coming back to this mistake. You appear to be unable to distinguish between scenarios that indicate relative motion and scenarios that indicate absolute motion. Absolute motion is indicated by detecting a difference in the laws of physics in two frames. If you merely distinguish two frames by some distinctive initial condition that is a relative motion. But if the subsequent evolution of the system indicates a difference in the laws of physics then that is absolute motion.
Thought of an easy way to do it.
Change the mirror for an absorber. When it is struck by the light, it absorbs it and gains energy, starting to move away from the source. Work in the frame where the source and absorber are both initially at rest (I assume that there is such a frame - the more general case is left as an exercise 😁). The absorber has mass ##m## and lies on the +x axis and has initial four-momentum ##i=(m,0,0,0)## (in units where ##c=1##). It picks up speed ##u## in this frame after absorbing the light pulse, so its final four-momentum is ##f=(\gamma_um,\gamma_uum,0,0)##, where ##\gamma_u=(1-u^2)^{-1/2}## is the corresponding Lorentz gamma factor. We can immediately read off the energy gain by taking the difference of the 0th components, getting ##A=(\gamma_u-1)m##.
Now we transform to a primed frame moving at speed ##v## in the unprimed frame's +x direction. Four vectors transform via the Lorentz transforms, so we write ##i'=(\gamma_vm,-\gamma_vvm,0,0)## and ##f'=\gamma_u\gamma_vm(1+uv,-u-v,0,0)##, where ##\gamma_v=(1-v^2)^{-1/2}## is the usual Lorentz gamma factor associated with the frame transform. Again, we can immediately read off the energy change, getting ##A'=\gamma_v(\gamma_u-1+\gamma_uuv)m##.
So the absorbed energy is different, as I said. But is it different as a fraction of the emitted light?
Now we turn to the source of light. Let's say that it has initial mass ##M##. It emits energy ##E##, reducing its mass to ##M-E##, but emits symmetrically so that only the 0th component of the four-momentum changes. In the unprimed frame, then, its initial and final four-momenta are ##I=(M,0,0,0)## and ##F=(M-E,0,0,0)##. Transforming to the moving frame, we find ##I'=(\gamma_vM,-\gamma_vvM,0,0)## and ##F'=(\gamma_v(M-E),-\gamma_vv(M-E),0,0)##. Thus the emitted energy in this frame is ##E'=\gamma_vE##.
Thus we can see that in the unprimed frame the fraction of the emitted energy striking the absorber is ##A/E=(\gamma_u-1)\frac mE##, but in the primed frame it is ##A'/E'=(\gamma_u-1+\gamma_uuv)\frac mE##.
So not even the fraction of energy striking the absorber is the same. Note that this entire argument is based on conservation of energy and completely independent of your model of light.
You can do the maths for a reflector instead of an absorber if you wish. I think the only complication is that you have to keep track of the four-momentum of the reflected light as well.
Ladies and gentlemen, I thank you all.
I still think you do not understand my difficulty. I hope you will see this is not filibuster for just wasting your time. Most of you are explaining to me the basics of SR, and that's very much preaching to the choir. What I'm trying to speak of is the basics of these basics.
The closest to the point are those who are talking about the motion of the source of light. Although I never had problems with which lightbulb is moving (I'm not that dumb, believe me), I do have issues with how we define the source of light. Some of you are confusing the actual material device that emitted light and the notion of the source of light in SR. These are NOT the same, whence all my difficulties.
I will once again give it different wording.
1. Let's forget about the sphere of light for a moment. Let there be two lamps each emitting two photons in opposite directions. We place these two lamps in the origins of the coordinate systems the moment they coincide, each lamp motionless in its respective frame. At the same moment, the two lamps emit four photons, two per lamp, two going in the direction of the motion of O', two in the opposite direction.
Now, the fronts of the radiation will coincide for both directions for both lamps, no matter moving or not moving. One lamp is therefore surplus; this system can be reduced to only one lamp attached to no matter which frame. Let it be attached to O. The distance measured from the point of origin of light over time will be equal to c for both O and O'.
This is quite elementary, but I needed to say this to demonstrate that in either frame in this scenario to have the speed c we will need to measure the distance between the wave front and the ORIGIN OF THE COORDINATES. This is so even for O' where at the moment of the measurement will be no material lamp.
That's why I maintain that within the context of SR the material light emitter and the source of light ARE NOT THE SAME THING. The source of radiation is the point of space with its respective coordinates, and it has nothing to do with the fact whether the material device is at rest in this point or not.
Will we agree upon that?
2. Now, let's enhance our two-way lamp and add an emitter on top to let out the photon going straight up. If we stick to the light clock model, the path of this photon is straight upwards and can be traced in the other if we imagine the plain of propagation to be a sheet of paper which we pull along at a speed v: the photon will draw a line inclined at arccos (v/c).
If we go back to the two-lamp model and place in the second frame another identical lamp, we seemingly should deem this upward shots to be identical too - or not?
How do we choose which sheet to pull at speed v?
If the shots are not identical, on what grounds we choose one of the trajectories to be inclined?
Do we agree that there is a problem?
  • Sad
Likes weirdoguy
There is no problem. In the first case, all emissions were in the direction of relative motion of the reference frames. In the second case, the emission was not in this direction. The angle, as measured against 2D coordinate axes, is frame dependent. As it is in Newtonian physics.
There is no absolute "vertical" direction for a moving object. If a beam is vertical in one frame, then it is not vertical in another. This applies to Newtonian physics as well. If someone is passing in a train and you take a snapshot of them as they throw an object up, then (instantaneously) it looks the same as a snapshot of someone on the ground throwing an object up. You cannot distinguish from an instantaneous photograph.
But, the object on the train follows a vertical trajectory in the train's reference frame. And, the object on the ground follows a vertical trajectory in the ground reference frame.
You have to develop the ability to understand this apparent paradox of motion.
Likes Ibix
PS note that it is the speed of light that is independent of the motion of the source. Not the velocity of light, which is a vector and has a different direction in each reference frame.
Likes Sagittarius A-Star, Dale, Ibix and 1 other person
  • · Replies 42 ·
  • · Replies 65 ·
