About the notion of non-standard inertial frame
The discussion centers on the concept of non-standard inertial frames within flat spacetime, particularly how transformations of spatial coordinates can yield frames that are no longer inertial. Participants argue that while inertial frames typically require linear descriptions of motion, there are interpretations that allow for non-linear coordinate descriptions under certain conditions. The conversation highlights the implications of Newton's laws and Einstein's synchronization convention, emphasizing that the definition of inertial frames can vary among authors. Ultimately, the consensus suggests that while traditional definitions lean towards Cartesian coordinates, alternative interpretations exist that accommodate different coordinate systems.
  • Understanding of inertial frames in physics
  • Familiarity with flat spacetime concepts
  • Knowledge of Newton's laws and Einstein's synchronization
  • Basic grasp of coordinate transformations in physics
  • Research the implications of non-linear coordinate transformations in physics
  • Study Einstein's synchronization convention in detail
  • Explore the differences between inertial and non-inertial frames
  • Investigate the role of coordinate systems in general relativity
Physicists, students of theoretical physics, and anyone interested in the foundations of relativity and the nature of inertial frames.
cianfa72
TL;DR
About the notion of nonstandard inertial frame in the context of flat spacetime
I had a DM with @PAllen about the notion of non-standard inertial frame.
Let's consider a (global) inertial frame in the context of flat spacetime. Apply now to it a general transformation of spatial coordinates alone.
Such a transformation yields a frame that is no longer inertial. Although one might say something like “we no longer have a standard inertial frame”. The point being that inertially moving bodies may have a nonlinear coordinate description.
This means that, using the coordinate time ##t## as parameter, the functions ##x(t), y(t), z(t)## describing in that frame a body moving inertially (i.e. zero proper acceleration) might be nonlinear. Hence the sentence "we no longer have a standard inertial frame".
What do you think about, does the definition of inertial frame prescribe that the description of a body moving intertially must be linear in it ?
I think the usual interpretation of "inertial frame" requires that all objects exhibit inertia - i.e. objects that have constant coordinate speed experience no proper acceleration. That means Cartesian coordinates only. (As an aside, it still allows your spatial planes not to be orthogonal to your timelike axis, which is one view on why Einstein had to specify his synchronisation convention as well as specifying that Newton's laws hold good).
I would add that if you actually physically implemented some spatial coordinate system as a frame of rods then put it somewhere in space, the frame itself would be inertial, regardless of its form. A literal inertial frame, and the only implied requirement is that objects at rest in the system will be inertial. So I think it's possible to argue this view, but my understanding is that it isn't the customary usage.
I would not be confused by something like "an inertial frame in spherical polars", but it should probably be understood as shorthand for "take a global inertial frame and apply a coordinate transform to spherical polars".
Now let's see what everyone else says...
Ok, you mean that the requirement that zero proper acceleration has constant coordinate speed allows for spatial planes (spacelike hyperplanes) not orthogonal in spacetime to the timelike axis.
What about any object moving inertially ? I believe there is also the implied requirement that their coordinate speed must be constant as well.
Note that coordinate speed involves derivatives of spatial/spacelike coordinates w.r.t. coordinate time ##t##.
Ok. That would rule out e.g. the coordinate transform ##x'=log(x)## because an object with no proper acceleration moving in the x' direction would not have constant coordinate speed. On the other hand, any combination of translation, rotation, or boost would, of course be ok.
No, as discussed in a recent thread, requiring Newton's laws to hold good requires Einstein synchronization because Newtons laws are isotropic. For example, consider an idealized gun and ideal calorimeter at mutual rest. Invariant is the statement that the calorimeter will have the same reading for any orientation of the set up. However, if you also require that kinetic energy depends only on speed (definitely part of Newton's laws), then isotropic synchronization is forced.
Right, if you only require that objects at rest with respect to an inertial reference object (defined, e.g. by constant radar reflection times) have a constant coordinate position, then you could have an 'non standard' inertial frame such that an object with zero proper acceleration may have non-constant coordinate velocity.
cianfa72 said:
TL;DR: About the notion of nonstandard inertial frame in the context of flat spacetime
I think that the term “inertial frame” means what the author using the term defines it to mean. There are variations in the literature.
Ok, since assuming isotropic laws includes the light propagation process. Isotropy forces Einstein synchronization, i.e. spacelike hyperplanes (slices) orthogonal to the timelike axis.
Dale said:
I think that the term “inertial frames” means what the author using the term defines it to mean. There are variations in the literature.
Yes, I'm aware of. In this context I mean basically inertial "coordinate system/chart".
Same there. Different authors will have different meanings for what charts they consider to be inertial.
For example, some will consider stationary, non-rotating spherical coordinates to be non-inertial and others will consider them to be inertial. There is no hard and fast rule for what everyone calls "inertial".
You can do this, but you can't do it by only transforming the spatial coordinates from a standard inertial frame. In fact, the simplest way to do it transforms only the time coordinate--the spatial coordinates are left unchanged.
As I said, I don't think that represents the usual meaning of an inertial frame. It's a defensible definition, I think, just not the usual one.
I think also scaling, even anisotropically as long as it is globally the same, would be fine. But yes, I think that definition restricts "inertial frame" to uniformly scaled axes.
Perhaps more precisely, I think it restricts your coordinate basis vectors to being parallel to a timelike Killing field and three of the spacelike Killing fields that correspond to translational symmetry. If the only requirement is that all inertial objects have constant coordinate speed, I don't think it requires the basis vectors to be mutually orthogonal or normalised, merely that their magnitude is constant. I see your point about "Newton's laws hold good" in a more general sense being a tighter restriction, one that does require orthonormality.
So for instance in Minkowski spacetime that has 10 independent symmetries, pick 4 independent translational KVFs (they define a frame field/tetrad) and coordinates such that their (coordinate) basis vectors are parallel to those frame field's vectors at any point. Then "all inertially moving objects have constant coordinate speed" doesn't require mutual orthogonality but just constant magnitude for coordinate basis vectors.
Can we extend the construction given in #11 to any spacetime, e.g. even to non maximally symmetric spacetimes ?
I'm not positive about that, since a frame field may not define a coordinate basis (i.e. there is no guarantee that coordinate lines exist such that the associated basis coincides with the frame field's vectors at any point).
Yes it does, because a tetrad by definition has four mutually orthogonal vectors.
Ah yes. The definition of frame field/tetrad/vierbein requires pointwise mutual orthogonality of frame's vectors fields evaluated at any point. Therefore, according to @Ibix, "all inertially moving objects have constant coordinate speed" doesn't require mutual orthogonality or the normalization condition.
Yes.
I'm not sure where your "therefore" here comes from; this statement is completely unrelated to the previous one. There's no logical connection between them.
Right, the latter is unrelated to the former. I just restated the conditions @Ibix put forward in post #10.
Ok, so your "therefore" should not have been there.
As far as I can tell, by picking a pointwise non-orthogonal basis vector fields (one timelike and three spacelike) with constant magnitude representing the 4 translation symmetries of Minkowski flat spacetime, we get the result "all inertially moving objects have constant coordinate speed" however, for instance, light propagation process is no longer isotropic in the associated coordinates/chart (note that in this specific case such basis vector fields actually define a coordinate basis, i.e. a chart).
Another point related to post #18. For a given spacetime suppose there is a set of 4 (algebraically) independent vector fields of constant magnitude (one timelike and three spacelike) with vanishing Lie brackets (i.e. they commute).Then there exist local charts with the property that their coordinate basis's vectors are the same as those 4 vector fields evaluated at any point.
Suppose now the spacetime global topology allows for a global chart. From what said in this thread, this implies the chart being defined is classified as inertial and since extends globally, it follows the underlying spacetime is flat Minkowski.
On a second thought, I believe my post #19 isn't entirely correct.
For a given spacetime, assume there exists a Lorentzian frame field (one timelike and three spacelike mutually orthonormal vector fields) with the additional property that its vector fields commute (i.e. zero Lie bracket). The 4d manifold is locally Minkowskian and the frame field defines locally a coordinate (holonomic) basis.
Suppose now the topology of the spacetime allows for a global chart (i.e. the local charts implied by Frobenius' theorem happen to extend globally). Does this imply the underlying 4d manifold is Minkowski flat ?
cianfa72 said:
Given these assumption, the spacetime turns out to be just locally Minkowski flat
For your first assumption, that's true.
For your second assumption, that the topology allows for a global inertial chart, why do you think that doesn't require the spacetime to be globally Minkowski?
Ah yes, you're right (I edited my post #20).
Coming back to what @Ibix said in post #10, I've not a clear understanding why a non orthonormal frame field (one timelike and three spacelike) with constant magnitude basis vectors should result in "all inertially moving objects have constant coordinate speed" claim.
Because the inner product of an inertial world line's four velocity and any of the Killing fields is constant.
  • · Replies 78 ·
  • · Replies 18 ·
  • · Replies 54 ·
  • · Replies 61 ·
  • · Replies 23 ·
  • · Replies 101 ·
  • · Replies 144 ·
9K
