What is this metal insert for in a desk?
  • Thread starter Thread starter Swamp Thing
The metal inserts in the engineered wood table are identified as Cam Lock fasteners, which serve to securely hold the wood pieces together. Each board of the table is 10 mm thick, and the inserts are strategically placed on the side and back boards, as well as on the chest of drawers, without being visible from the outward-facing side. These fasteners are commonly used in furniture assembly, particularly in products from IKEA, although modern versions may not always be metal.
  • Understanding of furniture assembly techniques
  • Familiarity with engineered wood materials
  • Knowledge of fasteners used in furniture construction
  • Experience with IKEA-style assembly methods
  • Research the different types of Cam Lock fasteners and their applications
  • Explore engineered wood manufacturing processes
  • Learn about alternative fasteners used in modern furniture
  • Investigate assembly techniques for flat-pack furniture
Furniture designers, DIY enthusiasts, and anyone involved in furniture assembly or manufacturing will benefit from this discussion.
Swamp Thing
Insights Author
This engineered wood table has metal inserts like this one fitted on the side and back boards, near the corners. Each board is 10 mm thick and the insert doesn't show on the other side of the board (the side facing outwards). I can also see an insert on the board that forms part of the chest of drawers, on the side supporting the drawers.
They don't seem to be fasteners holding anything together.
What would be the purpose of these?
renormalize said:
Actually they do hold the wood pieces together. They're called Cam Lock fasteners:
Very familiar to anyone who puts IKEA stuff together (except that in recent years they often aren't made of metal anymore).
Note metal Cam lock dowels may even be double-ended, for joining panels end-on.
A range of lengths available...
Discovered such when needed to 'Frankenstein' two flat-pack kitchen units as '50' + '40' cm, when range did not include a '90' cm and '100' cm would be 'Just Too Long'...
Yes, appropriate reinforcements affixed 'out of sight'...
  • · Replies 37 ·
  • · Replies 42 ·
11K
15K
  • · Replies 46 ·
