Assumptions of Hawking-Penrose 1970 Singularity Theorem
  • Context: Graduate
  • Thread starter Thread starter Cerenkov
The discussion revolves around the assumptions underlying the Hawking-Penrose Singularity Theorem from 1970. Participants explore the validity of these assumptions in light of contemporary findings and their implications for the theorem's applicability, particularly concerning dark energy and inflation.
  • One participant lists five assumptions they believe were made in the theorem, including the universe being like a Friedmann model, infinitely large, expanding fast enough to avoid re-collapse, the correctness of general relativity, and containing observed amounts of matter.
  • Another participant challenges the first three assumptions, stating they were not part of the 1970 theorem, while confirming the correctness of the assumption regarding general relativity.
  • It is noted that the assumptions related to matter-energy content require the universe to be dominated by ordinary matter and/or radiation to satisfy energy conditions.
  • Dark energy is discussed as not satisfying the energy conditions, which raises questions about the theorem's applicability to a dark energy dominated universe.
  • Inflation is mentioned as also violating energy conditions, making the theorem inapplicable to most inflation models.
  • Questions are raised about whether the singularity theorem could apply to the universe at certain times when it was not dark energy dominated.
  • Participants express a desire for clarification on how inflation violates energy conditions and which specific conditions are involved.
Participants do not reach a consensus on the validity of the assumptions listed, with some affirming certain assumptions and others disputing them. The discussion remains unresolved regarding the implications of dark energy and inflation on the singularity theorem.
There are limitations in the discussion regarding the assumptions made in earlier papers by Hawking and Penrose compared to the 1970 theorem, as well as the implications of dark energy and inflation on the theorem's applicability.
Cerenkov
I've been thinking some more about the Hawking - Penrose Singularity theorem and was wondering if you could help me gain a better understanding of the assumptions they made when they wrote it, in 1970.
In Hawking's book, A Brief History of Time (chapter 3, page 25) he writes....
In 1965 I read about Penrose’s theorem that any body undergoing gravitational collapse must eventually form a singularity. I soon realized that if one reversed the direction of time in Penrose’s theorem, so that the collapse became an expansion, the conditions of his theorem would still hold, provided the universe were roughly like a Friedmann model on large scales at the present time. Penrose’s theorem had shown that any collapsing star must end in a singularity; the time-reversed argument showed that any Friedmann-like expanding universe must have begun with a singularity.
For technical reasons, Penrose’s theorem required that the universe be infinite in space. So I could in fact, use it to prove that there should be a singularity only if the universe was expanding fast enough to avoid collapsing again (since only those Friedmann models were infinite in space).
During the next few years I developed new mathematical techniques to remove this and other technical
conditions from the theorems that proved that singularities must occur. The final result was a joint paper by
Penrose and myself in 1970, which at last proved that there must have been a big bang singularity provided
only that general relativity is correct and the universe contains as much matter as we observe.
Reading this, here are the assumptions that I think they made.
1. That the universe is roughly like a Friedmann model on large scales at the present time.
2. That the universe is infinitely large.
3. That the universe was expanding fast enough to avoid re-collapse.
4. That general relativity is correct.
5. That the universe contains as much matter as we observe.
So, for now I have two questions. Is my list correct regarding what Hawking says was assumed by them? Have any findings made since 1970 rendered the above assumptions false?
Thank you in advance for help.
Cerenkov.
Not in the 1970 theorem, no.
Yes--the technical assumption is that the Einstein Field Equation is correct.
This was Hawking being typically vague in a pop science context. The actual assumptions connected with matter-energy content are, first, that the universe is dominated by ordinary matter and/or radiation, so that the energy conditions are satisfied, and second, that the universe is expanding.
Dark energy does not satisfy the energy conditions, so the singularity theorem does not apply to a universe that is dark energy dominated at all times. Our universe is dark energy dominated now, but it wasn't before about 2 billion years ago, so dark energy being in our best current model in itself does not make the singularity theorem inapplicable to our universe.
However, inflation also violates the energy conditions, so the singularity theorem is inapplicable to most inflation models, since inflation occurs in the very early universe.
Then these three assumptions were proper to papers by Hawking and Penrose prior to the 1970 paper?
Thank you.
Ok, let's be specific here, so that I get this right.
Are you talking about these four energy conditions described in the 1970 paper's abstract?
(i) Einstein’s equations hold (with zero or negative cosmological constant),
(ii) the energy density is nowhere less than minus each principal pressure nor less than minus the sum of the three principal pressures (the ‘energy condition’),
(iii) there are no closed timelike curves,
(iv) every timelike or null geodesic enters a region where the curvature is not specially aligned with the geodesic. (This last condition would hold in any sufficiently general physically realistic model.)
Ok then.
What you say seems to suggest that the singularity theorem does apply to a universe that is dark energy dominated at certain times, but not all times. Is that what you meant to imply Peter?
With this new type 1a supernovae finding, the dark energy-driven acceleration of expansion during the last 2 billion years is called into question. If this holds up then there is no need to invoke dark energy to account for this acceleration. It simply didn't happen.
Which would satisfy the condition of our universe not being dark energy dominated at all times. Which prompts the following questions.
Was there ever a time in the history of our universe when it was dark energy dominated?
And given that our universe was not dark energy dominated at all times, does the theorem become applicable to our universe?
Could you please explain (in terms that I can understand) how inflation violates the energy conditions?
Moreover, which ones?
I realise that this is a lot of questions Peter, but with your help I believe that I am gaining a better understanding of this.
Thank you,
Cerenkov.
Both inflation and dark energy violate the energy conditions and refer to the accelerated expansion of the universe. Is this a coincidence, or could some variable dark energy model explain inflation and the subsequent deceleration?
As far as I know, Hawking and Penrose didn't publish any papers together prior to the 1970 paper. Penrose published a paper in 1965, which is referred to in the excerpt you quoted from Hawking's popular book.
That paper's assumptions were more restrictive than the ones in the Hawking-Penrose 1970 paper, but only in one key respect: the 1965 theorem only works in spacetimes that are spatially infinite (the technical term is spacetimes that have a non-compact Cauchy surface). The theorem is not limited to FRW spacetimes. (Hawking's excerpt that you quoted doesn't say it is, but it can give that impression--which is an example of why you shouldn't try to learn actual physics from pop science sources.)
The "Einstein's equations hold" part is "general relativity is valid". The "zero or negative cosmological constant" is part of the energy conditions.
Yes, this is also part of the energy condition.
Neither of these have anything to do with energy conditions. They are more technical conditions that basically amount to making sure the spacetime is physically reasonable.
Sort of. It can apply to an expanding universe that is only dark energy dominated after a certain time, but not before that.
That is one possible way it could turn out, yes.
If we only consider the accelerated expansion of the last few billion years, our universe already satisfies that condition. That was my point in the previous post of mine that you quoted.
However, none of that has anything to do with inflation, which is in the very early universe, and which is not called into question at all by the Type 1a supernovae re-analysis that was discussed in the other thread.
Inflation has the same implications, and our best current model says the very early universe was in a period of inflation.
Not if our best current model of inflation in the very early universe is correct.
The same way dark energy does: it violates item (ii) in your post #3.
Thank you for this, Peter.
In my defence I'm only using Hawking's book as a starting point for my line of questions.
Cerenkov.
Thank you.
Thank you.
Thank you again.
I suspected this was the case. But thank you for confirming it.
Cerenkov.
Thank you.
Thank you.
Now this needs unpacking.
If the type 1a finding holds, then our universe doesn't satisfy the condition of accelerated expansion during the last 2 billion years. They imply that accelerated expansion never happened. So dark energy is not the cause of that. It never was.
But if our universe satisfies the condition of accelerated expansion during some other epoch in it's evolution
then is inflation the cause?
I understand this. Inflation occurred in the very earliest moments of the universe, long before matter could form the stars that would go on to become type 1a supernovae.
These implications being accelerated expansion? I know from reading Alan Guth's book that inflation, once initiated, accelerates. Exponentially, I seem to recall.
Because inflation violates the energy conditions of the theorem, as you say below.
Is it worth me asking how it violates item (ii) or is that a bridge too far for my Basic-level understanding? I defer to your knowledge and expertise here, Peter. If you think it's better that I just take your word that this violation happens, then so be it. But if you would like to take a stab at explaining the 'how' to me then I'm willing to be guided by you.
Thanks again,
Cerenkov.
Yes.
Not "never". Just not in the last two billion years.
Inflation does cause accelerated expansion, yes. In our best current model, that occurred in the very early universe.
Yes.
In cosmology, we model matter, radiation, dark energy, and the field that causes inflation as fluids with an equation of state ##p = w \rho##. The different words I just used are simply labels for different values of ##w##:
"Matter": ##w = 0##
"Radiation": ##w = 1/3##
"Dark Energy": ##w = -1##
The field that causes inflation, in the simplest inflation model, is just like dark energy: ##w = -1##. In more complicated models, ##w## might not be quite constant and might vary in some range, but it won't be very different from ##-1##.
Any fluid for which ##w < - 1/3## will violate the energy conditions. From the above, we can see that dark energy does, and inflation does as long as ##w## doesn't vary enough to be greater than or equal to ##- 1/3## (and it comes nowhere close to that in any inflation model I know of).
With apologies Peter, I'm not feeling very well right now and will get back to you asap.
Cerenkov.
No worries, post as you can. I hope you feel better soon.
Back again, feeling better and thank you for your patience Peter.
Returning to your last message, what I seem to see is that the values of all three pressures - matter, radiation and dark energy - exceeding the value of w. (Sorry, but I don't know to insert the correct symbol here.)
Which tells me that the H - P Singularity theorem is incompatible with Inflation. Just as you've stated. If that's so, then I'd like to make a comparison, based upon my Basic level understanding of these things.
There is strong evidence in support of inflation, as described here. https://arxiv.org/abs/2407.03577v1 But I don't know of any observational evidence in support of the cosmological singularity described by Hawking and Penrose. If there is, then please correct me, Peter.
Is my comparison valid?
Thank you,
Cerenkov.
Hmm... I've only just noticed this, from the introduction of the paper I cited.
Introduction. The biggest question in science is the origin of the universe. In the hot big bang paradigm, shortly after the singularity, the universe is assumed to undergo an quasi-exponential expansion phase...
Presumably the use of the word singularity here is meant to describe where physics breaks down and not the initial cosmological singularity proposed by Hawking and Penrose?
Not exactly. ##w## is the ratio of pressure to density. For the simplest model of inflation (which works just like a cosmological constant), ##w = -1##, meaning ##p = - \rho##. So all three pressures (since they all are equal to ##p## in this model) are equal to minus the energy density.
Yes.
Note, however, that there is another theorem, the BGV theorem, which does apply to a universe that includes a period of inflation, and which does imply that the universe does not extend infinitely into the past--although it doesn't imply quite the same simple kind of "initial singularity" that the Hawking-Penrose singularity theorem does.
Inflation is our best current model of what happened in the very, very early universe, yes.
There isn't any. The reasons for including an initial singularity in our model of the universe were always theoretical, not observational.
Thank you Peter. However, I'm floundering a bit here.
You could try and explain the symbols and terms if you wanted, but I think I'm unlikely to follow you. Instead, let me say this. For me the core issue is to try and understand (with your help) a little more about the incompatibility of singularity theorem with inflation.
If that's something that can't be done at a Basic level or without going into higher math, then I'm content with all that you've given and explained to me.
For that I thank you.
PeterDonis said:
Yes.
Thank you.
Ah yes, the BGV.
First, thank you for making it clear that the BGV's non-infinite extension into the past (is that geodesic incompleteness?) is not of the same kind of initial singularity proposed by the H -P singularity theorem.
Second, now that you've introduced the BGV into this thread, can I ask further questions about it?
I'm inquiring because I'm unsure if the the BGV is a purely classical theorem or not. If it isn't, then is it outside the remit of the section to ask questions about it? What with Special and General relativity being classical physics.
I await your advice here and will follow it.
Thank you.
I suspected as much about the H -P singularity theorem. Thank you for confirming my suspicions.
Many thanks,
Cerenkov.
I've already explained that: anything with an equation of state ##p = w \rho## where ##w < −1/3## violates the energy conditions that are one of the assumptions of the singularity theorem. Anything that can cause inflation falls into that category.
It's a theorem about spacetime models using General Relativity. Such models can include stress-energy that has an equation of state that can only be accounted for by some kind of quantum theory, but the quantum theory itself doesn't appear in the spacetime model. In other words, even if we're assuming that an underlying quantum theory is needed for whatever matter or energy or fields are in our model, we're using its classical limit (which tells us the value of ##w## to use) in the spacetime model that the BGV theorem is about.
PeterDonis said:
I've already explained that: anything with an equation of state p=wρ where w<−1/3 violates the energy conditions that are one of the assumptions of the singularity theorem. Anything that can cause inflation falls into that category.
Thank you, Peter.
I think it's worth drawing a line under the issue of the incompatibility of singularity theorem with inflation at this point.
Your guidance and explanations are much appreciated.
Cerenkov.
PeterDonis said:
It's a theorem about spacetime models using General Relativity. Such models can include stress-energy that has an equation of state that can only be accounted for by some kind of quantum theory, but the quantum theory itself doesn't appear in the spacetime model. In other words, even if we're assuming that an underlying quantum theory is needed for whatever matter or energy or fields are in our model, we're using its classical limit (which tells us the value of w to use) in the spacetime model that the BGV theorem is about.
Thank you for clarifying this, Peter.
Since the BGV is within the remit of this section I'll return here very soon with my questions.
Thanks again,
Cerenkov.
Why do you think this is "worth drawing a line under"?
Well, I can see some reasons, Peter.
Because you've mentioned the equation of state three times now, along with explanations of the various symbols and technical terms that make it up. Do I follow what you mean and what you're trying to explain to me with them? Honestly, not really.
I can understand ideas and concepts from diagrams, graphs or heuristics like the balloon analogy, but mathematical symbols are just so much hieroglyphics to me.
None of this is any kind of reflection upon you or your guidance, btw. You have been most patient and I appreciate that. It's just that we're just bumping up against my limits and maybe now is the time to accept this and move on.
Perhaps to my questions about the BGV, if that's ok with you?
Thank you,
Cerenkov.
Ah, sorry, I was misinterpreting what you meant by "draw a line under". You meant "no need to discuss any more". I thought you meant "emphasize".
Sure, that's fine.
Apologies for the delay in getting back to you, Peter.
But after much thought I think I've whittled my questions down to just one(ish).
If the BGV is a purely classical theorem, then can it say anything meaningful about universes that are modelled using inflation theorem? I ask because in Guth's book, The Inflationary Universe, he describes inflation as being a semi-classical theorem, which takes into account certain aspects of quantum mechanics.
So, to what extent, if any, is there a relationship between a purely classical theorem and a semi-classical one?
If you could please couch your answer in terms I'm likely to understand that would be appreciated.
Many thanks,
Cerenkov.
Given what you seem to mean by "purely classical", no, it isn't a "purely classical" theorem.
Yes, for the reasons I already gave in post #20.
You're getting way too caught up in meaningless terminology. "Purely classical" and "semi-classical" regarding theorems are just terms you made up. Nobody in the literature actually uses them.
A mathematical theorem is a mathematical theorem. The extent to which you can apply it to a physical scenario depends on whether and how well the scenario satisfies the premises of the theorem. The theorem doesn't know that it's "purely classical" or "semi-classical". It's just math. The physical scenario doesn't know that it's "purely classical" or "semi-classical" either. It's just physics.
With all due respect Peter, I did not make the term semiclassical up.
And I used the expression "purely classical" to distinguish between classical and semiclassical. I may be recalling things inaccurately or misapplying the terms or simply getting confused about matters that are too complex for me, but I did NOT make the term semiclassical up. As these links demonstrate.
https://en.wikipedia.org/wiki/Semiclassical_physics
https://en.wikipedia.org/wiki/Cosmic_inflation
While inflation depends on quantum field theory (and the semiclassical approximation to quantum gravity) in an important way, it has not been completely reconciled with these theories.
https://api.pageplace.de/preview/DT0400.9780429971372_A35115635/preview-9780429971372_A35115635.pdf
Semiclassical Physics by Matthias Brack and Rajat K. Bhaduri
https://ocw.mit.edu/courses/8-06-qu...c35150e1f5d93ef05d4664f406d_MIT8_06S18ch3.pdf
Quantum Physics III Semiclassical Approximation
https://courses.physics.illinois.edu/phys580/fa2013/semiclassical.pdf
https://people.math.harvard.edu/~shlomo/docs/Semi_Classical_Analysis_Start.pdf
https://scisimple.com/en/articles/2...cal-and-response-theories-in-physics--a3w1mel
https://physh.org/concepts/c82a3805-4f41-4d31-97e7-6814e977a7cc
https://journals.aps.org/prd/abstract/10.1103/PhysRevD.37.3522
Semiclassical physics and quantum fluctuations
https://physics.stackexchange.com/questions/141356/semiclassical-limit-of-quantum-mechanics
While I concede that my use of the words, 'purely classical' was wrong and inaccurate and that I'm well out of my depth here, would you please reconsider your claim that semiclassical is a term that I've made up?
Thank you,
Cerenkov.
  • · Replies 20 ·
  • · Replies 17 ·
  • · Replies 16 ·
