About the definition of topological manifold using closed sets
The discussion revolves around the possibility of reformulating the definition of n-dimensional topological manifolds using closed sets instead of open sets. Participants explore the implications of such a reformulation for both topological and smooth manifolds, considering the challenges and limitations that arise from using closed sets in the context of continuity and differentiability.
  • Some participants propose that the definition of n-dimensional topological manifolds could be reformulated using closed sets, suggesting that this approach might provide new insights.
  • Others argue that replacing open sets with closed sets is not fundamentally different, as it leads to complications with continuity and differentiability, particularly concerning singletons.
  • A participant questions the purpose of defining manifolds using closed sets, indicating a desire for clarity on how topological and differential elements interact in such definitions.
  • Concerns are raised about the inability to define continuity or differentiability at points when using closed sets, as neighborhoods are essential for these concepts.
  • Some participants discuss the implications of using closed sets on the notion of dimension, noting that it may lead to inconsistencies in defining manifolds.
  • A method of constructing topological manifolds from closed subsets of Euclidean space through triangulations is introduced, highlighting a potential approach to reconcile the use of closed sets with manifold definitions.
Participants do not reach a consensus on the viability of using closed sets to define topological manifolds. Multiple competing views remain regarding the implications for continuity, differentiability, and the definition of dimension.
Limitations include unresolved questions about the definitions of continuity and differentiability when using closed sets, as well as the implications for bounded manifolds and the concept of dimension.
cianfa72
TL;DR
How to define the notion of topological vs smooth manifold using closed sets.
We all know the definition of n-dimensional topological manifold uses open sets and homeomorphisms onto the image as open set in ##\mathbb R^n##.
It should be possible to reformulate the definition of n-dimensional topological manifold using closed sets on the manifold's topology and on ##\mathbb R^n## ? I'm positive for this.
Perhaps the definition of smooth manifold would be problematic, though.
You can always replace an open set by its closed complement. Of course, this is not really a difference.
All terms in this context are about local phenomena, continuity, and differentiability. These are inevitably connected to open neighborhoods. If you make those neighborhoods closed, then you immediately get into trouble with singletons.
for what purpose, if I may ask?
Nothing. I asked it just to better understand how topological vs differential elements enter the definition of manifold (topological vs differentiable).
Sorry, can you better explain what is the trouble with singletons set ?
How?
A singleton is a one-point set ##\{p\}.## This is a closed set (in the usual topologies that are required to perform calculus). However, there is no way to define continuity or differentiability at ##p## without having a neighborhood of it.
The most basic concept of a manifold uses continuity. But continuity means a function is a morphism in TOP. It says that you cannot gain an open set by a morphism that wasn't already in the topology (of open sets) beforehand. That's why you need open sets. You can rephrase these by closed sets, but that is a void improvement, as it only means to switch to the complements.
You will also get problems with bounded manifolds. The boundary is closed. Again, a problem for continuity unless you restrict the entire setup to the boundary itself. Same with the boundaries of possibly closed neighborhoods. You cannot define continuity there, only one-sided. But how would you patch them if only one-sided continuity is defined?
Felix Hausdorff [12] introduced an axiomatic concept of neighborhoods in 1914 [13].
Source: https://www.physicsforums.com/insights/the-many-faces-of-topology/
where you can find the references [12] and [13].
martinbn said:
How?
Define the topologies involved by using axioms for closed sets (i.e. arbitrary intersections and finite unions instead of vice versa). Define continuous map by using the preimage of closed sets and then homeomorphism, chart accordingly. From a topological manifold perspective I believe it makes perfect sense (basically we're just recasting the definitions using closed sets).
Let's move on to the definition of differentiable/smooth manifold. Consider the representative of a (continuous) function in a chart (that's a closed set in ##\mathbb R^n##). Would it make sense to talk about differentiability for it ?
There many problems. Give the definition that you think is appropriate.
Use this -- Definition using closed sets. The definition of chart ##(U, \phi)## is based on closed sets using homemorphism on the image. The transition maps ##\varphi \circ \phi^{-1}: \phi (U \cap V) \to \varphi (V)## are well defined, i.e. they are homemorphisms (intersection of closed sets is closed and we can use subspace topology on them).
Let's take our topological space to be the plane ##M=\mathbb R^2##. How do you make it a topological manifold using closed sets? Every point in ##M## is contained in closed line segment, which is homeomorphic to a line segment in ##\mathbb R^1##. Does it mean that our space ##M## is a one dimensional topological manifold? The line segments are also homeomorphic to line segments in ##\mathbb R^n## for any ##n##. Does it mean that ##M## is a ##n## dimensional topological manifold?
Ah yes, well spotted. The same issue doesn't occur when using open sets to define neighborhoods. So, by using closed sets, we no longer get a well defined notion of dimension for the manifold.
As far as I can tell, the key point here is that an open set of ##\mathbb R^n## can't be homeomorphic to a subset of euclidean space with dimension ##m \neq n##.
The key point is that you can choose whatever small neighborhood around a point and still have the same behavior. A closed set might immediately put you outside such a neighborhood. An open set has this problem only if we enlarge the neighborhood. However, we are not interested in global properties. We need local properties, i.e., getting smaller neighborhoods, not larger ones. Try to define differentiability in ##\mathbb{R}^2## if we only consider the closed sets ##\coprod_{c\in \mathbb{R}}\{(x,y)\,|\,y=x+c\}.## Good luck!
A way to construct topological manifolds from closed subsets of Euclidean space is through triangulations. For example, one can imagine triangulating a surface then cutting out each triangular region to obtain a set of solid triangles. Each solid triangle is homeomorphic to a closed disk in the plane. By remembering how the edges of these triangles are pasted to each other, one can reassemble the surface. In this way, one imagines constructing surfaces by reshaping closed disks into solid triangles then gluing them together.
This idea extends to triangulable 3- manifolds constructed from closed solid pyramids and in general n-manifolds constructed from the n-dimenionsal analogues of solid triangles.
Most manifolds that one can think of are triangulable. All surfaces can be made from solid triangles. All smooth manifolds are triangulable. But there are exceptions in dimensions 4 and above. So this method of construction isn't completely general.
  • · Replies 20 ·
  • · Replies 61 ·
  • · Replies 43 ·
  • · Replies 17 ·
  • · Replies 20 ·
