- 1,277
- 1,078
A disk of radius ##r## is wrapped with an inextensible massless string. A particle of mass ##m## is attached to the end of the string. The disk rotates about its center ##O## with angular velocity ##\Omega=const##. The whole system is placed on a smooth horizontal table.
This is a Lagrangian system with one degree of freedom. To study this system take ##x,\quad x>0## the length of the free tail of the string as a generalized coordinate.
It is easy to calculate the Lagrangian
$$L=\frac{1}{2}\frac{m}{r^2}x^2\dot x^2+\frac{1}{2}m\Omega^2x^2.$$
The Lagrange equation has a singularity at ##x=0## . To get rid of this problem introduce a new variable ##\xi=x^2.## The Lagrangian takes the form
$$L=\frac{1}{8}\frac{m}{r^2}\dot \xi^2+\frac{1}{2}m\Omega^2\xi.$$
To understand the dynamics it is convenient to draw a phase portrait that is to draw a set of level lines of the generalized energy integral $$H=\frac{1}{8}\frac{m}{r^2}\dot \xi^2-\frac{1}{2}m\Omega^2\xi$$ in the plane ##(\xi,\dot \xi)##.
It is interesting to note that the system has solutions that first wind up on the coil and then wind off the coil; the particle does not touch the coil.
Also there are solutions ##x(t)## such that ##\dot x\to-\infty## as ##x\to 0##.
