Creating a solenoid with varying magnetic field
This discussion focuses on creating a solenoid with a varying magnetic field, specifically how to design a magnetic field that strengthens from the center to the shell radius. The concept involves using a varying winding pattern of wire coils to achieve this effect. Participants emphasize the importance of defining the radius and the nature of the variation (e.g., linear or inverse square) to effectively design the solenoid. A visual sketch is recommended to clarify the intended design and field variation.
  • Understanding of electromagnetic theory, particularly solenoids.
  • Familiarity with magnetic field concepts and their mathematical representations.
  • Basic knowledge of coil winding techniques and electrical engineering principles.
  • Ability to create and interpret technical sketches or diagrams.
  • Research techniques for designing solenoids with non-uniform magnetic fields.
  • Explore coil winding patterns and their effects on magnetic field distribution.
  • Learn about the mathematical models for varying magnetic fields, such as linear and inverse square variations.
  • Investigate simulation software for modeling electromagnetic fields, such as COMSOL Multiphysics.
Electrical engineers, physicists, and hobbyists interested in advanced solenoid design and magnetic field manipulation.
CMTacoTophat
TL;DR
How would you create a magnetic field within a solenoid that varies with radius?
I'm posing this question because it seems like it should have a simple answer, but I can't for the life of me figure it out. It seems a setup like this could be very useful; if there were charged particles inside, and the magnetic field was stronger going from the center to the shell radius, then they could reasonably be "reflected" to remain inside. I believe this could happen if, should they travel closer to the wall, the turn radius decreases, and they bend back from the shell.
So far, all I've been able to envision is a varying winding pattern of wire coils, but I'm not so sure how it could be achieved in practice, if possible.
Any insight helps - thanks in advance.
CMTacoTophat said:
TL;DR: How would you create a magnetic field within a solenoid that varies with radius?
What radius? Can you upload a sketch of what you want to do? And in what way do you want the field to vary? (linearly, inverse square, etc.)
I don't think the way in which the field varies matters too much (as long it's not, say, a jump at the very end). This sketch should help:
  • · Replies 16 ·
