File Structure vs Data Structure
  • Thread starter Thread starter aronclark1017
The discussion revolves around the comparison between file structures and data structures, particularly in the context of programming and application development. Participants explore various perspectives on the efficiency, security, and usability of different approaches to data handling, with references to specific programming environments like .NET.
  • Meta-discussion
  • Some participants suggest that saving objects directly may be preferable, questioning the necessity of complex structures.
  • Others argue that file operations are generally slow and can hinder scalability, emphasizing the importance of prioritizing speed in coding practices.
  • A participant mentions the use of a button form in .NET, implying a connection to data handling but does not clarify the relevance.
  • There is a debate about whether file directories can be considered data structures, with some noting the potential for external modifications to files.
  • Concerns are raised about the clarity and intent of the original poster's contributions, with some participants questioning the quality of communication and whether the posts are made in good faith.
  • Participants express uncertainty about the original poster's language proficiency and the implications for their contributions.
  • Some participants speculate on the reasons for perceived poor communication, suggesting that it may not solely be a matter of language skills.
Participants do not reach a consensus on the best approach to file versus data structures. There are multiple competing views regarding the efficiency and security of each method, as well as ongoing concerns about the clarity of the original poster's contributions.
There are indications of missing assumptions and unclear definitions regarding what constitutes a data structure versus a file structure. The discussion also reflects varying levels of understanding and communication among participants, which may affect the clarity of the arguments presented.
Readers interested in programming practices, data management strategies, and the nuances of file handling in software development may find this discussion relevant.
aronclark1017
TL;DR
have been debating for some time now about weither to access data from file or use list across entire application. In some cases it is more convenient to access data from file where only single instance is used. Such as for example creating new object in main form then listing all objects in next form. My first intuition would be to create a new file in the main form then read all the files into a list within the next form. My question if it would be better practice to simply just read the ...
Technology news on Phys.org
Maybe just save the object. Is the structure all because is crook to hide from.
There are as many ways to code a procedure as there are coders. The question is what are your priorities?
I can't speak for your circumstance but, generally reading and writing files are some of the slowest operations a system and language can perform. The more file-writing your system does, the slower it will be, and the less scalable it will be.
Even if those are not priorities for this particular application, speed and scalability are still excellent criteria on which to build your coding philosophy.
Imagine the diagram as a button form. In .net can tag value to button.
Er, what?
I mean, I know how .net works, but what does that have to do with your opening post?
Is a good post trust is. To debate about wether to use data structure or just simply file directory. Similar to a grid, the file directory is a data structure in its self one that often time I use without reading into a data structure especially when working with .net forms. However I suspect such could be criticism with argument such as the files could be possibly modified outside the application.
  • Haha
Toyoda...not to mention a data structure using node for file list and directory is slow as hell
  • Haha
What are you trying to say here?
I think he's asking if its simply for the sake of security.
What's wrong with an open source RDBMS? Or even ODBC against an encrypted .cat file? Is that build into ODBC nowadays? Anyway, I think at least *NIX provides for memory share between processes.
EDITED.
Sounds like something Yoda would have said, although Yoda is quite a bit clearer.
It's a bit difficult for me to tease that meaning out from what he wrote, especially in the two examples above.
Pretty sure English is not OPs first language.
That aside, I'm not sure if the OP is posting in good faith. Their posts don't make much effort to be explanatory, even with prompting.
Some kind of sealioning going on here? (Sorry I just love that word!)
EDIT: And yeah, the light bulb above was a little ironic.
I'm just as sure that it is, at least based on his nick, which may or may not be his actual name, together with the fact that his IP addresses are all in the US.
I don't believe the OP is trolling, if that's what you're implying. OTOH, I'm not sure that he is capable of making the effort to post stuff that is clear and self-explanatory.
I'm not a native English speaker either and I also doubt the OP's nativity. Then again it's pure speculation. There could be a host of reasons for "poor penmanship".
Then all the more reason why they should be urged to be more descriptive - if this thread stays open at all.
  • Agree
Many more problems than mere penmanship. I think the mods should weigh in.
  • Agree
  • · Replies 32 ·
