Why if net force=zero, moment at any point is same?
  • Context: Undergrad
  • Thread starter Thread starter gen x
The discussion clarifies that when the net force is zero, the moment at any point remains constant, as illustrated by the equations provided. For example, with forces F1=10, F2=40, and N=50, the moment at points A and B is +20Nm. Conversely, when the net force is non-zero, such as with F1=10, F2=40, and N=30, the moments differ significantly, with A yielding +20Nm and B yielding +100Nm. The relationship between net force and moment is defined by the equation Mnet,b = Mnet,a + (a - b) × Fnet, which simplifies to Mnet,b = Mnet,a when Fnet is zero.
  • Understanding of basic mechanics concepts, including force and moment.
  • Familiarity with vector mathematics and cross products.
  • Knowledge of how to compute moments using lever arms.
  • Ability to interpret and manipulate equations involving forces and moments.
  • Study the principles of static equilibrium in mechanics.
  • Learn about the application of the cross product in physics.
  • Explore the concept of moments about different reference points in detail.
  • Investigate the implications of non-zero net forces on mechanical systems.
This discussion is beneficial for physics students, mechanical engineers, and anyone involved in the study of statics and dynamics, particularly those focusing on forces and moments in mechanical systems.
gen x
Why as long net force= zero, moment at any point is the same but if net force= non zero, that is not case anymore?
Here is simple example:
Net force=zero case: F1=10, F2=40, N=50
Moment at A= +20Nm
Moment at B=+20Nm
Any point you choose you will get same moment..
Net force = non zero: F1=10, F2=40, N=30
Moment at A=+20Nm
Moment at B=+100Nm
Now, moment is not the same in every point.
Please show the equations that you use to compute the moments, for the cases you present.
If ##\vec{F_{net}}## is the net force, and ##\vec{M_{net,a}}## is the net moment around the point ##\vec{a}##, then the net moment around any point ##\vec{b}## is given by:
$$\vec{M_{net,b}} = \vec{M_{net,a}} + (\vec{a} - \vec{b}) \times \vec{F_{net}}$$
Which for ##\vec{F_{net}}=0## simplifies to:
$$\vec{M_{net,b}} = \vec{M_{net,a}}$$
Moment at A=-10x2+40x1=+20Nm
Moment at B= 10x2-50x4+40x5=+20Nm
Moment at A=-10x2+40x1 =+20Nm
Moment at B= 10x2-30x4+40x5 =+100Nm
How do you get this equation?
##\vec{F}\times(\vec{a}+\vec{b})=\vec{F}\times\vec{a}+\vec{F}\times\vec{b}##
This is basic transfer of moments to another reference point:
Why is vector r a/p (lever arm) not perpendicular to force F?
moment of point P must be: Mp= lever arm perpendicular to force F x force F
  • · Replies 17 ·
  • · Replies 33 ·
  • · Replies 17 ·
