- 7,747
- 3,973
The next fenitized gneiss example:
Fenitized gneiss. I’m not sure what feature was marked in blue pen- I didn’t observe anything unusual in that region. This sample is weak F1 and moderate F2, so alterations preferentially show effects of F2. This second metasomatic event is much less well defined (both in terms of originating fluid(s) and succession of mineral growth) as compared to F1. For example, whereas the source material for F1 is known (fluids and volatiles driven by the ijolite intrusion), the source material(s) driving F2 is unknown and may actually consist of successive pulses of fluids, each with differing metasomatic chemistries.
A later paper (https://www.cambridge.org/core/jour...implications/00AA1631F359FD10A73327CB7BEEB65F) subdivides the Fenitization-2 metasomatic event into discrete fenitization events. “Verschure and Maijer (1984) have distinguished between two metasomatic events in the fenite aureole, the first (here called A1) producing acmite or sodic amphibole, the second (A2) forming stilpnomelane at the expense of these minerals. A third, later metasomatic event of aureole extent (A3), was caused by interaction between rocks and groundwater-derived hydrothermal fluids infiltrating the eastern part of the complex, leading to oxidation of ferrocarbonatite to hematite carbonatite, locally known as 'Rødberg', i.e. 'red-rock’.”
Fenitization-2 (meaning both A2 and A3) is a hydrothermal process resulting in the replacement of Fenitization-1 minerals, primary gneiss minerals, and also minerals of the Fen Complex (Ijolites and carbonatites). Fenitization-2 produced low-temperature crystallization of hydrous minerals (Na-amphiboles, new greenish biotite, new chlorite, sericite and stilpnomelane), carbonates, quartz and opaque minerals. Fenitization-2 minerals are fine grained and seldom exceed 10% of the total rock volume.
These images show “Biotite replaced during Fenitization-2 by radiating needles of bluish Na-amphibole [A2], subsequently partially replaced by fine- grained magnetite and hematite. [A3] The replacement occurred where biotite was in contact with quartz. Other biotites within the same sample appear unaffected or completely replaced. The sample was taken 1750 m south of the Fen Complex, far outside the zone of Fenitization–1. Location of the sample: HSP post M00059, Økonomisk Kart Foreløpig Utgave 1971 (BW 020-5-1) coordinates: 138965-51753. “
Because fenitization is so variable, there's a lot of samples to work through. While the next several samples are examples of F2 (meaning both A2 and A3), there is another whole set of fenitization examples formed at the contact between intrusion and existing wall-rock (so-called "contact fenitization" and denoted C1 through C4), with the majority of contact fenitization occurring in carbonatites.
Lots to learn! #thinsectionthursday
