Electric potential due to shell containing a charge at an offset outside
The discussion revolves around the electric potential due to a point charge placed near a conducting spherical shell. The original poster describes a scenario where a point charge is positioned at a distance from the center of the shell, and participants explore the implications of induced charge distributions on the shell's surfaces.
  • Participants discuss the superposition principle to calculate electric potential at a point outside the shell, questioning how to account for the non-uniform charge distribution on the inner surface.
  • Some participants suggest that the electric field lines from the point charge terminate at the inner surface, leading to discussions about induced charges and their effects on potential.
  • There are inquiries about the method of images and its applicability in different scenarios, particularly regarding grounded versus ungrounded conductors.
  • Questions arise about deriving equations for potential at specific points based on charge distributions and the implications of symmetry.
The discussion is active, with participants providing various interpretations and approaches to the problems presented. Some guidance has been offered regarding the method of images and potential calculations, but there is no explicit consensus on the best approach to take for the second question.
Participants note the complexity of charge distributions and the challenges posed by assumptions about uniformity. There is an acknowledgment of the need for rigorous justification in certain interpretations, particularly regarding the induced charge on the inner surface of the shell.
elex
Thread moved from the technical forums to the schoolwork forums.
TL;DR: A point charge q
is placed at distance a
from the centre of an uncharged thin spherical conducting shell of radius R=2a
. A point P
is located at a distance 4a
from the centre of the conducting shell as shown. The electric potential due to induced charge on the inner surface of the conducting shell at point P
is
A point charge $q$ is placed at distance $a$ from the centre of an​
uncharged thin spherical conducting shell of radius $R= 2a$. A point​
$P$ is located at a distance $4a$ from the centre of the conducting​
shell as shown. The electric potential due to induced charge on​
the inner surface of the conducting shell at point $P$ is​
I understand charge distribution on inner surface is non uniform while uniform at outer surface.
to find Vp using superposition: Vp=Vp due to outer+Vp due to inner+Vp due to q.
Vp due to outer is kq/4a, and Vp due to q is kq/5a. What am I to do with inner surface charge distribution?
One of my interpretation:
potential is kq/4a for p as the point p sees only outside uniform charge distribution(I don't know how to justify this rigorously)
but by super position it is kq/4a + kq/5a + vpdue to inner surface.
So can I conclude vp due to inner surface is -kq/5a?
But a similar approach is unable to be applied on a very similar problem:
This is from the second link I mentioned, to find potential at centre a where charge q is in cavity at b inside metal shell(radii r1<r2):
va=va due to q+ va inner+ va outer
so va=kq/b +va inner+ kq/(r2)
But now my non rigorous intuition of first problem doesn't work out in brain. How to get another equation for va like I got earlier?
Can we argue that all the field lines from the point charge must terminate at the inner surface? We need that argument anyway in order to say that the induced charge is -q on the inner surface, so +q on the outer surface.
Looks ok to me, though I have the nagging doubt that we should be using the method of images somewhere.
The useful fact here is that for each spherical surface A is at the same distance from every part of the induced charge.
Thanks, but can you help me a bit more on the second question like so what equation do I get from
to solve the second question fully.
Also, wouldn't method of images need integration or such, I have used method of integration only when the conductor is grounded and the conductor is plane.
Consider a small patch of the inner surface. If it has charge ##\Delta Q##, what potential does that produce at A?
You can use the method for grounded spherical conductors too. See e.g. https://eng.libretexts.org/Bookshelves/Electrical_Engineering/Electro-Optics/Electromagnetic_Field_Theory:_A_Problem_Solving_Approach_(Zahn)/02:_The_Electric_Field/2.07:_The_Method_of_Images_with_Point_Charges_and_Spheres
It depends on the remarkable fact that if you have two point charges of opposite sign then there is a spherical surface at which the net potential is zero.
It can be tied to the flat plane case through inversive geometry.
Wrt the current problem, which is not a grounded sphere, I think it might be possible to fix up by adding a point charge at the sphere’s centre. That is, we start with the given point charge q (ignoring any charges on the sphere), add a point charge q' such that the two result in zero potential at the spherical inner surface, now add q" at the centre of the sphere to produce the desired potential at the surface. So q'+q" produce the same net potential at the sphere’s inner surface as the induced charges on it do.
Whether that helps I'm unsure.
I am not sure what is being asked here.
Is it Assume that the inner surface charge distribution is "pasted" on a shell of radius ##2a##. Find the electric potential at point P ?
If so, I would consider the brute force method.
1. Find the electric field at point ##\mathbf r## from the center of the shell due to charge ##q## at point ##\mathbf r' = a~\mathbf {\hat z}##.
2. Find the inner surface charge distribution ##\sigma(\theta)## from the normal component of the electric field at ##r=2a##.
3. Note that this charge distribution has a monopole term with ##Q=-q## and a dipole term. The dipole moment is given by $$\mathbf p=\int \mathbf r ~\sigma(\theta)~ dA$$where ##dA## is an area element on the surface of the shell. Its direction should come out to be axial because of the symmetry.
4. The potential due to this distribution would be the sum of the two terms $$V(\mathbf r)=\frac{1}{4\pi\epsilon_0}\left(-\frac{q}{r}+\frac{\mathbf p \cdot \mathbf r}{r^3}\right).$$ 5. Evaluate the expression at ##\mathbf r=4a~\mathbf{\hat z}.##
Looks good.
Recall @haruspex 's comment:
If the charge, ##-q##, on the inner surface were uniformly spread, what would the potential at ##A## be due to this charge? Does it matter that the charge is actually not uniformly spread?
  • Agree
  • · Replies 19 ·
  • · Replies 17 ·
  • · Replies 64 ·
10K
