Engine Oil Level Sensor Pin Details
  • Context: Automotive
  • Thread starter Thread starter core7916
core7916
Hello, I am testing a engine oil level sensor. in this i dont know the type of the sensor. and pin descripion.
I initially thought the sensor type was analog. Since i dont know the proper pin information i cant confirm it. Can some of you explain how this sensor works, how to test it. Sensor information i will give below.
Thank you
Google AI mode:
"how does the fomoco gk2a-6c624-bb oil level sensor work?"
"The Fomoco GK2A-6C624-BB oil level sensor works using ultrasonic technology to precisely measure the oil level in the engine and sends a pulse-width modulated (PWM) signal to the engine control unit (ECU)."
Chassis and power supply will connect to two of the pins. The third pin has a digital output signal that is Pulse Width Modulated.
To test it, identify the 0V chassis terminal. Identify the B+ 12V or +5V terminal. Connect the identified supplies.
Method 1. Look at the PWM signal with an oscilloscope to observe the pulse width, then lower the sensor into a jug of engine oil and watch the width change in proportion to depth in oil.
Method 2. Connect an LED with a 1K resistor in series, between ground and the PWM signal. Watch the LED brightness change with depth in oil.
Method 3. Make a low-pass filter from a 10K resistor in series with a 100uF capacitor. Connect it between the ground and the PWM signal. Measure the voltage across the capacitor with a voltmeter. Voltage will be proportional to the pulse width duty cycle.
Baluncore said:
Google AI mode:
Method 2. Connect an LED with a resistor between ground and the PWM signal. Watch the brightness change with depth.
But i dont have the information of pin details. i tried with different combination. but at one iteration sensor got spoiled. (observed smoke). now i have new sensor. so i want to make sure the pin details first
Plug the sensor into the vehicle and measure the voltages. One pin will remain at zero volts, another will remain at +5V. The last pin will vary depending on depth in oil.
I asked Google AI for the pinout.
Terminal Pinout Identification
While the specific pin mapping (Pin 1, 2, 3) for this exact connector is usually proprietary to the Ford wiring schematic, this 3-pin sensor structure generally follows this pattern for combined level/temperature sensors:
Pin 1 (Power): 5V Reference Voltage (Sensor Power)
Pin 2 (Ground): Ground (Low-side ground)
Pin 3 (Signal): Output Signal (PWM or Variable Voltage)
I have tried this combination
Pin 1 : 5v
Pin 2 : Ground
Pin 3 : out put.
In output i am observing voltage same as pin 1 (Power), if i change decrese the power propotionally out put also decreses. And current consumed was 1mA.
I am also attaching a image of internal pcb structure of oil level
Keep the ground connected and the power stable at +5V.
You need to dip it in oil to see a change in the output.
There is no Ford Motor Company, FoMoCo, data sheet for the level sensor, because it is an in-house OEM product, not sold on the open market.
I tried this configuration, but the out put always shows 5v.
i have just gone through the pcb structure. the routing is look like below image.
  • · Replies 16 ·
  • · Replies 23 ·
  • · Replies 21 ·
  • · Replies 24 ·
