Kakashi
- 31
- 1
At constant pressure we have:
$$ dq_{p}=dH=C_{p} dT $$ which implies
The enthalpy change dH reflects the increase in internal energy associated with molecular motions such as rotational and vibrational modes. The atoms, molecules or ions that compose a system can undergo several types of motion including translation, rotation, and vibration. The greater the motion (the higher the temperature), the greater the number of possible microstates and therefore the higher the entropy. A perfectly ordered system with only a single microstate would have 0 entropy. The only system that meets this criteria is a perfect crystal at 0 K in which each component is fixed in place within a crystal lattice and exhibits no motion.
Near absolute zero, the heat capacity approaches zero:
$$ Cp \to 0 $$ as $$ T→0 $$
$$ dT = \frac{dq_{p}}{C_{p}} $$
Because it is impossible to perfectly isolate a system from its surroundings (dq_{p} =/0) (for example due to radiation from the environment), there will always be some small heat transfer. Therefore it seems impossible to keep a system exactly at T=0. Is this reasoning correct for explaining why absolute zero is unattainable?
