Ant on a stretchy rope puzzle
  • Context: High School
  • Thread starter Thread starter DaveC426913
  • #31
In the general case, the time that the ant needs to reach the end of the rope is $$ T=\frac cv(e^\frac v\alpha-1) $$, where ## c ## is the initial length of the rope, ## v ## is the rate at which the rope stretches, and ## \alpha ## is the speed of the ant relative to the rope.
Clearly, any positive real values of ## c ##, ## v ##, and ## \alpha ## will always return the positive real value of ## T ##, which means that the ant will always reach the end of the rope no matter what positive real values are assigned to ## c ##, ## v ##, and ## \alpha ##.
Mathematics news on Phys.org
  • #32
Google is too dumb to solve this. It returns undefined.
(1000 / 1000) * (e^(1000 / .01) - 1) = undefined
  • #33
It's obviously well approximated by ##e^{100000}##. Noting that ##e\approx 10^{0.434}## this is ##(10^{0.434})^{100000}\approx 10^{43400}##. That is rather larger than the maximum value of a double precision variable, which is what Google is probably using.
  • #34
  • Haha
  • #35
Ibix said:
Assuming I made no mistakes, here's a complete answer.
Let the band have initial length ##L##, with one end at rest and the other moving at constant speed ##V##. Thus at time ##t## the band has length ##L+Vt##, and a point at distance ##x## from the stationary end has speed ##\frac x{L+Vt}V##. The ant's speed relative to the rubber is ##u##, so its speed relative to the stationary end is $$\frac{dx}{dt}=u+\frac{xV}{L+Vt}$$Maxima says that this is satisfied by $$\frac xL=\frac uV\left(1+\frac{Vt}L\right)\ln\left(1+\frac{Vt}L\right)$$meaning that the ant reaches ##x=L+Vt## when$$\begin{eqnarray*}
\frac Vu&=&\ln\left(1+\frac{Vt}L\right)\\
t&=&\frac LV\left(e^{V/u}-1\right)
\end{eqnarray*}$$Plugging in ##L=10^3\,\mathrm{m}##, ##V=10^3\,\mathrm{ms^{-1}}##, and ##u=10^{-2}\,\mathrm{ms^{-1}}## this becomes ##t=e^{10^5}-1\approx 10^{43400}\,\mathrm{s}##.
Bear in mind that the universe is less than ##10^{18}\,\mathrm{s}## old. So there is a solution to the maths (assuming I didn't make any mistakes), but it's not realistic.
Yes, I got the same result. You gave an excellent complete solution.
  • #36
My 2 cents:
For the general case where the rope length grows as ##L(t) = L_0 \cdot a(t)##, the ant reaches the end if and only if:
##\int_0^\infty \frac{dt}{a(t)} = \infty##
The critical threshold is ##a(t) = t \ln(t)##: the ant still makes it (barely). Anything growing faster than ##t \ln(t)## and the ant never arrives.
  • #37
Roberto Pavani said:
My 2 cents:
I haven’t checked your iff condition, but taking that to be correct, wouldn’t ##t\ln(t)\ln\ln(t)\ln\ln\ln(t)…## also do?
  • #38
haruspex said:
I haven’t checked your iff condition, but taking that to be correct, wouldn’t tln⁡(t)ln⁡ln⁡(t)ln⁡ln⁡ln⁡(t)… also do?
You're right! f(n) = n·ln(n)·ln(ln(n))·... works too, for any finite number of iterated logs (integral test: each step gives the next iterated logarithm, still → ∞). The ant always makes it. You'd need something like f(n) = n^(1+ε) to actually stop it.
My point was simply that even in the "accelerating rope" case, there are growth rates faster than linear where the ant still arrives.
  • #39
What if we define ##f(x)=1+\ln(x)##, ##g_{n+1}(x)=f(g_n(x))##, ##h_{n+1}(x)=h_n(x)g_n(x)##, with suitable settings for ##g_0, h_0##, for ##x>=1##?
Does ##g_n## converge for all x? If so, is the limiting function slower than ##x^{1+\epsilon}## for all ##\epsilon>0##?
  • · Replies 31 ·
  • · Replies 20 ·
  • · Replies 16 ·
  • · Replies 30 ·
  • · Replies 22 ·
