Descartes’ Geometry of Square Roots
  • Context: Undergrad
  • Thread starter Thread starter bob012345
38 replies · 6K views
neilparker62 said:
It's not quite clear why this bears the name of Plato who was a philosopher rather than a a mathematician ...
The word philosophy literally means love of wisdom. In Plato's time, the distinction between a mathematician and a philosopher was not as sharp as it is today. The perceived connection of Plato to mathematics, which in pre-algebra days meant geometry, is illustrated by the traditional belief in an inscription at the entrance of Plato's Academy that read "Let no one ignorant of geometry enter."
Reply
Mathematics news on Phys.org
Note that if ##h## has unit length, ##a## and ##b## are reciprocals.
Reply
I wouldn't put it quite that way. Starting with ##h^2=ab,## which we assume to be known, we can rewrite it in two ways: $$\begin{align} & \frac{h}{a}=\sqrt{\frac{b}{a}} \\
& \frac{h}{b}=\sqrt{\frac{a}{b}}. \end{align}$$ Simply put, it doesn't matter which of ##a## and ##b## you call the unit and which the given segment. Segment ##h## will be the square root of whatever segment you chose as "given" measured with a ruler subdivided in the units of whatever segment you chose as "unit". The two equations above say that "##h## expressed in units of ##a## is the reciprocal of ##h## expressed in units of ##b.## You can see why that is if you multiply the two equations.
The only way for ##h## to have unit length, i.e. equal to one of the other two segments, is if both ##a## and ##b## are unit segments. This is demanded by the construction (see red circle in post #25.) So I would say "Note that ##h## has unit length if and only if ##a## and ##b## are unit segments in which case all three segments are equal to the radius of the unit circle."
Reply
https://archive.org/details/nicolaicopernici00cope_1/page/n7/mode/2up
In the case I just mentioned, neither ##a## or ##b## are unit length except in the case where the semi-circle is bisected. Here, ##a## and ##b## are in a forced relationship so the position of ##h## is fixed. In this example ##a=1/2##, ##b=2##.
It looks like that you lost track of what this construction is all about. It finds the square root of one of the segments, ##a## or ##b## that, together, make up the diameter.
Note that ##\sqrt{1/2}=0.707## and ##\sqrt{2}=1.41.## Clearly, ##h=1## is the square root of neither ##a## nor ##b##.
One of the two segments ##a## or ##b##, must be the unit of length otherwise the construction will not work.
Here is the correct way to look at your construction.
Case I - ##a=## "0.5" is the unit segment.
In this system of units, ##h## is twice as long as ##a##, i.e. ##2## units and ##b## is four times as long As ##a##, i.e. ##4## units.
Clearly ##h## is the square root of ##b##.
Case II - ##b=## "2" is the unit segment.
In this system of units, ##h## is half as long as ##b##, i.e. ##1/2## units and ##a## is one quarter times as long as ##b##, i.e. ##1/4## units.
Clearly ##h## is the square root of ##a##.
See how it works?
See how it works?
We seem to have different perspectives on this thread which is ok. From my perspective, we were discussing Descartes’ problem where the goal is to construct ##h=\sqrt{b}## but also the general case where ##a## and ##b## can be different lengths not considered unity and ##h=\sqrt{ab}## where ##h## is the geometric mean of the lengths as in the Wallis version. The last example I posted was an example of the latter. I agree with your comments above when interpreted as discussing Descartes version. Sorry for any confusion.
I think we can both agree on the following:
1. Using any number of methods, it can be shown that ##h=\sqrt{ab}.##
2. If either one of the segments, ##a## or ##b##, is defined as the unit segment, then ##h## represents the square root of the other segment in the chosen system of units.
Reply
Euclid constructs the arrangement in Book 6, Prop 13 of Elements.
Book 6
Prop 13
To find the (straight-line) in mean proportion to two given straight-lines.
Let AB and BC be the two given straight-lines. So it is required to find the (straight-line) in mean proportion to AB and BC.
Let (AB and BC) be laid down straight-on (with respect to one another), and let the semi-circle ADC have been drawn on AC [Prop. 1.10]. And let BD have been drawn from (point) B, at right-angles to AC [Prop. 1.11]. And let AD and DC have been joined.
And since ADC is an angle in a semi-circle, it is a right-angle [Prop. 3.31]. And since, in the right-angled triangle ADC, the (straight-line) DB has been drawn from the right-angle perpendicular to the base, DB is thus the mean proportional to the pieces of the base, AB and BC [Prop. 6.8 corr.].
Thus, DB has been found (which is) in mean proportion to the two given straight-lines, AB and BC. (Which is) the very thing it was required to do.
Book 3
Prop 31
In a circle, the angle in a semi-circle is a right-angle, and that in a greater segment (is) less than a right-angle, and that in a lesser segment (is) greater than a right- angle. And, further, the angle of a segment greater (than a semi-circle) is greater than a right-angle, and the angle of a segment less (than a semi-circle) is less than a right-angle.
Let ABCD be a circle, and let BC be its diameter, and E its center. And let BA, AC, AD, and DC have been joined. I say that the angle BAC in the semi-circle BAC is a right-angle, and the angle ABC in the segment ABC, (which is) greater than a semi-circle, is less than a right-angle, and the angle ADC in the segment ADC, (which is) less than a semi-circle, is greater than a right-angle.
Let AE have been joined, and let BA have been drawn through to F.
And since BE is equal to EA, angle ABE is also equal to BAE [Prop. 1.5]. Again, since CE is equal to EA, ACE is also equal to CAE [Prop. 1.5]. Thus, the whole (angle) BAC is equal to the two (angles) ABC and ACB. And F AC, (which is) external to triangle ABC, is also equal to the two angles ABC and ACB [Prop. 1.32]. Thus, angle BAC (is) also equal to F AC. Thus, (they are) each right-angles. [Def. 1.10]. Thus, the angle BAC in the semi-circle BAC is a right-angle.
And since the two angles ABC and BAC of triangle ABC are less than two right-angles [Prop. 1.17], and BAC is a right-angle, angle ABC is thus less than a right-angle. And it is in segment ABC, (which is) greater than a semi-circle.
And since ABCD is a quadrilateral within a circle, and for quadrilaterals within circles the (sum of the) opposite angles is equal to two right-angles [Prop. 3.22] [angles ABC and ADC are thus equal to two right-angles], and (angle) ABC is less than a right-angle. The remaining angle ADC is thus greater than a right-angle. And it is in segment ADC, (which is) less than a semi-circle.
I also say that the angle of the greater segment, (namely) that contained by the circumference ABC and the straight-line AC, is greater than a right-angle. And the angle of the lesser segment, (namely) that contained
by the circumference AD[C] and the straight-line AC, is less than a right-angle. And this is immediately apparent. For since the (angle contained by) the two straight-lines BA and AC is a right-angle, the (angle) contained by the circumference ABC and the straight-line AC is thus greater than a right-angle. Again, since the (angle contained by) the straight-lines AC and AF is a right-angle, the (angle) contained by the circumference AD[C] and the straight-line CA is thus less than a right-angle.
Thus, in a circle, the angle in a semi-circle is a right-angle, and that in a greater segment (is) less than a right-angle, and that in a lesser [segment] (is) greater than a right-angle. And, further, the [angle] of a segment greater (than a semi-circle) [is] greater than a right-angle, and the [angle] of a segment less (than a semi-circle) is less than a right-angle. (Which is) the very thing it was required to show.
Book 6
Prop 8
If, in a right-angled triangle, a (straight-line) is drawn from the right-angle perpendicular to the base then the triangles around the perpendicular are similar to the whole (triangle), and to one another.
Let ABC be a right-angled triangle having the angle BAC a right-angle, and let AD have been drawn from A, perpendicular to BC [Prop. 1.12]. I say that triangles ABD and ADC are each similar to the whole (triangle) ABC and, further, to one another.
For since (angle) BAC is equal to ADB—for each (are) right-angles—and the (angle) at B (is) common to the two triangles ABC and ABD, the remaining (angle) ACB is thus equal to the remaining (angle) BAD [Prop. 1.32]. Thus, triangle ABC is equiangular to triangle ABD. Thus, as BC, subtending the right-angle in triangle ABC, is to BA, subtending the right-angle in triangle ABD, so the same AB, subtending the angle at C in triangle ABC, (is) to BD, subtending the equal (angle) BAD in triangle ABD, and, further, (so is) AC to AD, (both) subtending the angle at B common to the two triangles [Prop. 6.4]. Thus, triangle ABC is equiangular to triangle ABD, and has the sides about the equal angles proportional. Thus, triangle ABC [is] similar to triangle ABD [Def. 6.1]. So, similarly, we can show that triangle ABC is also similar to triangle ADC. Thus, [triangles] ABD and ADC are each similar to the whole (triangle) ABC.
So I say that triangles ABD and ADC are also similar to one another.
For since the right-angle BDA is equal to the right-angle ADC, and, indeed, (angle) BAD was also shown (to be) equal to the (angle) at C, thus the remaining (angle) at B is also equal to the remaining (angle) DAC [Prop. 1.32]. Thus, triangle ABD is equiangular to triangle ADC. Thus, as BD, subtending (angle) BAD in triangle ABD, is to DA, subtending the (angle) at C in triangle ADC, (which is) equal to (angle) BAD, so (is) the same AD, subtending the angle at B in triangle ABD, to DC, subtending (angle) DAC in triangle ADC, (which is) equal to the (angle) at B, and, further, (so is) BA to AC, (each) subtending right-angles [Prop. 6.4]. Thus, triangle ABD is similar to triangle ADC [Def. 6.1].
Thus, if, in a right-angled triangle, a (straight-line) is drawn from the right-angle perpendicular to the base then the triangles around the perpendicular are similar to the whole (triangle), and to one another. [(Which is) the very thing it was required to show.]
Corollary
So (it is) clear, from this, that if, in a right-angled triangle, a (straight-line) is drawn from the right-angle perpendicular to the base then the (straight-line so) drawn is in mean proportion to the pieces of the base. (Which is) the very thing it was required to show.
Reply
