Hornbein
- 3,378
Very unusual looking.
It has both metallic and crystalline forms. Does anything else or is this unique?davenn said:Yeah, often found at mineral shows, they are lab grown, they dont normally grow like that in the ground
I have a couple of peices like that here in my collection, if I remember, I will do a photo
Aha. So it's the size of the crystals then. Do any metals aside from Bismuth so easily form large crystals like that.davenn said:Metallic and crystalline are not mutually exclusive
Almost all metals have crystalline forms
Dave
Pure metals? "Like that", like what?Hornbein said:Aha. So it's the size of the crystals then. Do any metals aside from Bismuth so easily form large crystals like that.
I always thought that steel, bronze, and brass were metals. But that's the problem with vernacular language, it all depends on how you learned it. IDK.Hornbein said:Huh, I thought metals had to be made of the elements, not compounds. I thought metals had to be flexible. The dictionaries say otherwise. They say the only requirements are that it be hard and conduct electricity and heat. There's no arguing with dictionaries, but in this case I believe they deviate from actual usage. If I were to use the word in this way I would be misunderstood.
I also learned that a "metalled road" is a road covered with crushed stone.
Steel bronze and brass are alloys entirely composed of the elements (or so I believe anyway). No rule against mixing them.DaveE said:I always thought that steel, bronze, and brass were metals. But that's the problem with vernacular language, it all depends on how you learned it. IDK.
But "flexible"? OK, whatever.
Perhaps you misspoke? Isn't that everything?Hornbein said:entirely composed of the elements
DaveE said:Perhaps you misspoke? Isn't that everything?
Also, I don't think the Carbon in Steel is a metal, but I'm bad at Chemistry and Carbon is weird.
Anyway my point is that common language fails in science when we start splitting hairs.
Anyway Gallium might be a good candidate. Like Bismuth it isn't toxic or very reactive, and has a low melting point.
Hornbein said:It has both metallic and crystalline forms. Does anything else or is this unique?
DaveE said:This has become a very strange thread. Perhaps I'm misunderstanding something.
Steel, bronze and brass are metals and alloys. Alloys are just mixtures of metals. Depending on manufacturing method, there may be impurities of C, N, O, P and S, as well as others.DaveE said:I always thought that steel, bronze, and brass were metals. But that's the problem with vernacular language, it all depends on how you learned it. IDK.
Element is the general term for each unique chemical species listed in the periodic table. Hydrogen, Helium, Lithium, Beryllium, Boron, Carbon, Nitrogen, Oxygen, Flourine, Neon, are the first 10 elements by atomic number (Z); the atomic number signifies the number of protons in the nucleus and the number of electrons surrounding the nucleus of atom, when it is electrically neutral. A loss of electrons yields a positive ion, while a gain of electrons yields a negative ion.Hornbein said:Huh, I thought metals had to be made of the elements, not compounds. I thought metals had to be flexible. The dictionaries say otherwise. They say the only requirements are that it be hard and conduct electricity and heat. There's no arguing with dictionaries, but in this case I believe they deviate from actual usage. If I were to use the word in this way I would be misunderstood.
