Rockets in a vacuum for SF story
19 replies · 1K views · last reply
rudybaker
TL;DR
Characteristics of different kinds of rocket engines in a vacuum for SF story.
Hello.
I'm an aspiring SF writer (i.e., I have a few rejection letters, but I've not been published yet). In real life, I'm a retired 8th grade math teacher, so I'm not totally innumerate.
I'm writing a story about a rescue mission in deep interplanetary space. The rescuers are in a enormous cargo ship that doesn't accelerate or change direction well. They have a narratively suspenseful amount of time (about a week) to bring a small but crucial part to a vessel in distress, which is a narratively interesting distance away (maybe a couple of million kilometers). Although the story doesn't take place here, using the Sol system is a good enough first approximation. I'm assuming present-day physics and technology that's more-or-less comparable to late 21st or early 22nd century, so not *too* far from what we know today. I'm basing everything around the Tsiolkovsky rocket equation: ##\Delta v=v_e ln(m_0 / m_f)##.
I'm hoping you might check my math and my understanding of rocket engines. Mostly, I'm hoping that a real rocket scientist will read my story and *not* say, "OH RUDY BAKER NO".
I've been doing some research in rocket engines, but almost all of the sources talk about performance in an atmosphere and under gravity, which complicates things. In my scenario, we're in a vacuum, far away from any source of gravity except the sun, from which all the characters are about 1.5 AU distant (i.e., on route from the earth to the asteroid belt).
The first question is related to the core of the rescue craft. My cargo ship uses a short-range electric steam rocket, with an effective exhaust velocity of about 500 m/s. Much too slow to make a long enough journey to be dramatic. The first question is whether something like this could be reasonably modified in the field to greatly increase the exhaust velocity (say to about 2500 m/s). I'm assuming not, but I want to check this assumption. I did find one reference, Nuclear-heated Steam Rocket Using Lunar Ice, which talks about using steam to achieve specific impulse of 195s (1911 m/s). Of course, that's using a nuclear reactor to heat the steam, and it's unlikely our rescuers happen to have a nuclear power plant lying around.
My second question is to check my current draft plan. The vehicle, including crew and cargo, is 400kg. Our rescuers have "high impulse solid rocket engines": 3300 kg, 3000 kg reaction mass, and an exhaust velocity of 2500 m/s. Strap five of those onto the craft, plus 1000 kg of water and batteries. Accelerate with four of the solid rockets (in pairs) to get to 3089 m/s, coast for about 8 days, then use the fifth solid rocket to decelerate to 397 m/s, and use the water rocket (500 m/s exhaust velocity) to come to a stop, leaving a little something for maneuvering.
Is this reasonable? Am I missing something important? If it would be helpful, I can post more details on my computations. Thank you for all your help.
Have you ever closely examined the scientific validity of Star Wars? Your desire for accuracy in physics is commendable in some ways, but IMO, not required for SF stories.
Young people who read your story, will go on to study physics, then try to implement what was in your story. Nothing in science, technology or engineering, happens without there first being a Science Fiction story employing that concept. You are being implicitly trusted with that responsibility for the future.
  • Haha
That's 'right here' in the scale of space. Very little time to match velocity with the ship in need of the part. You haven't said what the velocity difference is between the two ships. Best is a tiny rocket, just big enough for the part. Worst is trying to accelerate the big cargo ship.
That's about 1/10th the efficiency of today's rocket engines. The exhaust of say the space shuttle is indeed steam though, but not electric, which cannot produce thrust. You are using batteries to head water, producing a steam jet? OK, but batteries are massive. This doesn't sound like a plausible design.
OK, but again, accelerating the big object seems far less efficient than just shooting the part at them with say a rail gun. Not that a typical cargo ship carries those. 2500 m/s is at the low end of typical rocket efficiency, but it's a rating of efficiency, not a rating of power. It's power that produces g forces, and only power that is needed in a gravitational field. Efficiency works best in vacuum, which is why if time is not an issue, ion drives work so well. Very efficient, but not very powerful. A rescue vehicle with ion drive isn't going to be helpful. Power is your friend when time is limited.
rudybaker said:
TL;DR: Characteristics of different kinds of rocket engines in a vacuum for SF story.
That's a typical exhaust velocity of cold gas thrusters. I.e. just a gas tank with a valve. No heating required. Changing that to a completely different engine design while in space isn't feasible, especially not on a small spacecraft.
That is WAY too small for an interplanetary vehicle. Dragon is already 8 tonnes (dry mass) and that's a capsule for a few days in low Earth orbit at most. For an interplanetary vehicle you want tens of tonnes at least.
Where are these coming from?
It's science fiction, it doesn't have to be realistic. But if you want to have something realistic then we first need to look at the overall mission plan, because that doesn't make sense at the moment.
You don't randomly end up just a few million kilometers away at zero relative velocity. Someone made the decision to launch both vehicles into very similar trajectories. If there is any chance you want these vehicles to approach each other, then you would launch them onto almost identical trajectories, and the distance you need to cover will only be a few kilometers. Or zero, because having them dock immediately is probably easier.
I could see some reason for a small but not zero distance (~100,000 km) if you want both vehicles to make e.g. a Jupiter fly-by but in different directions - one passing in front of it, one passing behind it, for example.
Most spacecraft only have a significant delta_v capability if this is strictly necessary for their mission (e.g. to enter an orbit around a planet). You don't randomly have 80% of your spacecraft mass being solid rocket motors just for fun. If this is futuristic technology, give them something like a nuclear salt-water rocket. High thrust, high specific impulse, carrying some excess delta_v capability is acceptable.
Hello.
To be a writer, you need to be literate; numeracy isn't important.
  • Agree
Thank you all for your kind and perspicacious comments!
I've been reading and watching science fiction for more than half a century. Accuracy in fiction is not necessary (and I will use applied phlebotinum as needed), but it's a narrative choice that I'm making. No one chided Heinlein for working out the orbital mechanics in The Rolling Stones. My story is closer to Heinlein than to Lucas.
The two ships are both cargo ships in a "shipping lane" between two well-used places (Earth L4 or L5 to a spaceport in the belt). Cargo ships are strung like beads on similar trajectories from the same origin to the same destination. (See also below.)
The shuttle they're using is designed as a short-range shuttle with a range of hundreds of kilometers. Present-day cutting-edge fuel cells are at around 1 MWh/kg, so I'm comfortable waving my magic SF wand and getting up to an order of magnitude greater energy density.
Indeed. There are other narrative constraints I haven't mentioned: for narrative reasons, I want a crewed mission (and I can manage the in-story justification).
I'm not seeing how 2500 m/s effective exhaust velocity is a measure of efficiency. It's at the high end of (actually a little past) what I've found in today's technology for solid rocket boosters. With a mass ejection rate of 4.5 kg/s, that's 11,250 N of thrust. And yes, time is an issue, so no, the ion drive won't work; in the story, an ion-drive ship is on the way, but it won't appear in time.
mfb said:
That's a typical exhaust velocity of cold gas thrusters. I.e. just a gas tank with a valve. No heating required. Changing that to a completely different engine design while in space isn't feasible, especially not on a small spacecraft.That is WAY too small for an interplanetary vehicle. Dragon is already 8 tonnes (dry mass) and that's a capsule for a few days in low Earth orbit at most. For an interplanetary vehicle you want tens of tonnes at least.
Oh my! I was unacceptably imprecise. My cargo ship uses a short-range shuttle craft with the 500 m/s steam engine. (The idea is to fill the tank with water, heat it up to create pressure, then open the valve to the nozzle and scoot around between the ship and the spaceport when it's docked.) The cargo ship itself has a very large solar sail for its own propulsion. The idea is to use the shuttle craft to rescue the ship in distress.
It's science fiction, it doesn't have to be realistic. But if you want to have something realistic then we first need to look at the overall mission plan, because that doesn't make sense at the moment.You don't randomly end up just a few million kilometers away at zero relative velocity. Someone made the decision to launch both vehicles into very similar trajectories. If there is any chance you want these vehicles to approach each other, then you would launch them onto almost identical trajectories, and the distance you need to cover will only be a few kilometers. Or zero, because having them dock immediately is probably easier.
See above: the two ships are solar-sail powered cargo ships with the same origin and destination. Since they're under continuous acceleration, I'm assuming there's a wide enough launch window that multiple ships can launch for the same destination with some separation in time. When the orbital alignment becomes unfavorable, they pick another spaceport as a destination.
Indeed not! The rescuing ship is carrying the solid rocket boosters as cargo, for some unspecified use in the asteroid belt.
I'm going to use one of those in another story!
Thank you. I'm a retired professional teacher, so I take this sort of responsibility with some gravity.
rudybaker said:
I'm a very big fan of The Expanse!
Woo, yeah. Another Expanse guy. However, Season 4 got way to complicated with the wormhole mechanic and more factions thrown in. But the first three seasons were solid. It becomes hard to follow characters when more are thrown in. Well, I should rewatch it now, as I am in my late 20s, vs being 19 when I watched season 4. I can understand the social aspect of it more.
Yes. Season 4 was not the best. And while the politics were very good, the economics were (typically for most SF) just warmed-over 21st century industrial capitalism. But that's a topic for another day (and probably another forum).
Agreed. Shizz, it would have been cool to get deep into discussing the pros and cons of The Expanse. So rare to find people that like realistic sci-fi. Don't get me wrong, I love Star Trek and Star Wars more, but the Expanse was a breath of fresh air when a lot of other sci-fi has been pushing fake technobabble.
Edit: Using the rocket equation in your story is commendable. A lot of sci-fi writers would hand wave propulsion out of the story with a warp drive or ion drive that has way too much power to be realistic.
I see what you did there. :wink:
And TIL a new word! :smile:
Looks like we've stalled a little. Let me clarify the overall (fictional) mission.
We have two very large solar-sail powered cargo ships, the "victim" and the "rescuer". The rescuer must deliver a small but crucial part within 10 days. They're on similar trajectories, from the same origin and towards the same destination, but with different departure times. Both cargo ships are under low acceleration (not counting the sun's gravity), in the range of a few cm/s^2. In 10 days, the victim will be about 2 million kilometers from the initial position of the rescuer, with a relatively small velocity (hundreds of meters per second) relative to the rescuer's initial position/velocity. For narrative reasons, the rescue must be crewed.
The actual rescue craft is a small, light shuttle, used normally for short trips when the cargo ship is docked. Stripped down and modified for the rescue, the ship + engine + crew member + part is about 400 kg. The shuttle has a simple electric steam rocket: fill up the tank with water, heat it up to get pressure, open the nozzle and scoot off. With an exhaust velocity of only 500 m/s, it cannot possibly reach the victim in time.
But! Our rescuer just happens to have a few containers full of high impulse solid rocket engines. (Because I wouldn't be telling the story if they didn't.) These engines have 3000 kg of reaction mass, 300 kg of casing, nozzle, etc.. The effective exhaust velocity is 2500 m/s, with a mass flow rate of 4.5 kg/s, producing 11,250 N of thrust.
The plan is to have the shuttle take five of these solid rocket engines and 1000 kg of water and batteries, providing extra power for deceleration and maneuvering at the destination. The shuttle first accelerates with two solid rocket engines, discards the casings, accelerates with two more, then coasts for 7-8 days at about 3100 m/s. The shuttle decelerates with the remaining solid rocket engine, then uses about 750 kg of water/batteries to match velocity with the victim, with 250 kg remaining for maneuvering and docking.
The question is, do I have the numbers reasonably close? Am I missing anything that would be obvious to an engineer? (My characters are much better engineers than I am.)
Ironic, because The Expanse does just that. The power output of their magical fusion engines has to be at least a couple of orders of magnitude greater than real-world fusion, and where's the reaction mass? I don't really blame them: they need a lot of applied phlebotinum just to keep the time-frames narratively interesting. I'm putting all my phlebotinum in solar sails that can accelerate a 40,000 metric ton cargo ship (loaded mass) at 3-4 cm/s^2.
The novels (and i guess the series even more so) are careful not to give away direct numbers that could be used to reveal exactly how much magic is needed for the in-story physics, but since they do sometimes reveal acceleration level and duration it is possible to guesstimate the rocket exhaust speed assuming some upper propellant mass fraction of the involved ship and, if I recall correctly, the speed then do come out fairly above speed of light. Or in other words, the acceleration levels and duration does not seem to realistically match the maximum amount of fuel implied by the ship designs. Not that this detracts from the story, really.
I did not know that The Expanse even faked the fusion engine stuff. But one thing I do not trust in any sci-fi film are solar sails accelerating massive ships as you said. So yeah, most sci-fi will never be perfect. It probably takes a lot of effort to make science fiction media as realistic as possible.
