Tolman-Oppenheimer-Volkoff equation
  • Level: Graduate
  • Thread starter Thread starter Orion1
64 replies · 25K views · last reply
My first attempt to integrate the Adiabatic constant and Adiabatic index with degenerate Fermi pressure.
Adiabatic constant:
[tex]K = P V^{\gamma}[/tex]
Degenerate Fermi pressure:
[tex]P = - \frac{dE}{dV}[/tex]
Degenerate Fermi energy:
[tex]E_f = \frac{\pi^3 \hbar^2}{10 m_n} \left( \frac{3 N}{\pi} \right)^{\frac{5}{3}} \frac{1}{V^{\frac{2}{3}}}[/tex]
Adiabatic constant:
[tex]K = \left( - \frac{dE}{dV} \right) V^{\gamma} = - \frac{\pi^3 \hbar^2}{10 m_n} \left( \frac{3 N}{\pi} \right)^{\frac{5}{3}} \left( \frac{V^{-\frac{2}{3}}}{dV} \right) V^{\gamma}[/tex]
Differentiation identity:
[tex]\frac{V^{-n}}{dV} = -n V^{-n - 1} = \left(-\frac{2}{3} \right) V^{-\frac{2}{3} - \frac{3}{3}} = \left(- \frac{2}{3} \right) V^{-\frac{5}{3}}[/tex]
Integration by differentiation substitution:
[tex]K = - \left( - \frac{2}{3} \right) \frac{\pi^3 \hbar^2}{10 m_n} \left( \frac{3 N}{\pi} \right)^{\frac{5}{3}} \frac{V^{\gamma}}{V^{\frac{5}{3}}} = \left( \frac{2 \cdot 3 \cdot 3^{\frac{2}{3}}}{30} \right) \frac{\pi^{ \left( \frac{9}{3} - \frac{5}{3} \right)} \hbar^2}{m_n} \left( \frac{N}{V} \right)^{\frac{5}{3}} V^{\gamma} = \frac{3^{\frac{2}{3}} \pi^{\frac{4}{3}} \hbar^2}{5 m_n} \left( \frac{N}{V} \right)^{\frac{5}{3}} V^{\gamma}[/tex]
Number density:
[tex]n(r) = \frac{N(r)}{V(r)} = \frac{\rho(r)}{m_n}[/tex]
Adiabatic volume:
[tex]V^{\gamma} = \left( \frac{m_n}{\rho(r)} \right)^{\gamma}[/tex]
[tex]K = \frac{3^{\frac{2}{3}} \pi^{\frac{4}{3}} \hbar^2}{5 m_n} \left( \frac{\rho(r)}{m_n} \right)^{\frac{5}{3}} \left( \frac{m_n}{\rho(r)} \right)^{\gamma} = \left( \frac{3^{\frac{2}{3}} \pi^{\frac{4}{3}} \hbar^2}{5} \right) m_n^{\gamma - \frac{5}{3} + \frac{3}{3}} \rho(r)^{\frac{5}{3} - \gamma} = \left( \frac{3^{\frac{2}{3}} \pi^{\frac{4}{3}} \hbar^2}{5} \right) m_n^{\gamma - \frac{8}{3}} \rho(r)^{\frac{5}{3} - \gamma}[/tex]
Degenerate adiabatic constant with adiabatic index:
[tex]\boxed{K = \left( \frac{3^{\frac{2}{3}} \pi^{\frac{4}{3}} \hbar^2}{5} \right) m_n^{\gamma - \frac{8}{3}} \rho(r)^{\frac{5}{3} - \gamma}}[/tex]
Is this equation solution correct?
Standard SI derivation:
[tex]K = \frac{dE^2 \cdot dt^2}{dm \cdot dL^5} = \frac{dF^2 \cdot dL^2 \cdot dt^2}{dm \cdot dL^5} = \frac{dF^2 \cdot dt^2}{dm \cdot dL^3} = \frac{dF}{dL^2}[/tex]
[tex]\frac{dF}{dL^2} = \frac{dF^2 \cdot dt^2}{dm \cdot dL^3}[/tex]
Newtons second law:
[tex]\boxed{dF = \frac{dm \cdot dL}{dt^2}}[/tex]
Adiabatic constant SI units:
[tex]\boxed{K = \frac{dF}{dL^2}}[/tex]
The SI adiabat is a unit of pressure:
[tex]1 \; \text{adiabat} = \frac{1 \; \text{Newton}}{1 \; \text{meter}^2}[/tex]
[/Color]
Reference:
http://en.wikipedia.org/wiki/Force"
http://en.wikipedia.org/wiki/Entropy"
http://en.wikipedia.org/wiki/Fermi_energy"
http://en.wikipedia.org/wiki/Heat_capacity_ratio"
http://en.wikipedia.org/wiki/Degenerate_matter"
http://www.sfu.ca/~boal/385lecs/385lec18.pdf"
http://www.sfu.ca/~boal/385lecs/385lec19.pdf"
Astronomy news on Phys.org
TOV equation solution:
[tex]\frac{dP}{dr} = -(P(r) + \rho(r) c^2) \left( \frac{4 \pi G r^3 P(r)}{c^4} + \frac{G m(r)}{c^2} \right) \left[ r \left( r - \frac{2G m(r)}{c^2} \right) \right]^{-1}[/tex]
[tex]P(r) = \frac{3^{2/3} \pi^{4} \hbar^2 \rho (r)^{5/3}}{5 m_n^{8/3}}[/tex]
Integration by substitution:
[tex]\frac{dP}{dr} = - \left( \frac{3^{2/3} \pi^{4/3} \hbar^2 \rho (r)^{5/3}}{5 m_n^{8/3}} + \rho(r) c^2 \right) \left[ \frac{4 \pi G r^3}{c^4} \left( \frac{3^{2/3} \pi^{4/3} \hbar^2 \rho (r)^{5/3}}{5 m_n^{8/3}} \right) + \frac{G m(r)}{c^2} \right] \left[ r \left(r - \frac{2G m(r)}{c^2} \right) \right]^{-1}[/tex]
Degenerate Fermi-TOV equation solution:
[tex]\boxed{ \frac{dP}{dr} = - \left( \frac{3^{2/3} \pi^{4/3} \hbar^2 \rho (r)^{5/3}}{5 m_n^{8/3}} + \rho(r) c^2 \right) \left[ \left( \frac{4 \cdot 3^{2/3} \pi^{7/3} \hbar^2 G r^3 \rho (r)^{5/3}}{5 c^4 m_n^{8/3}} \right) + \frac{G m(r)}{c^2} \right] \left[ r \left( r - \frac{2G m(r)}{c^2} \right) \right]^{-1} }[/tex]
Tolman VII density solution:
[tex]\rho(r) = \rho_c \left[1 - \left( \frac{r}{R} \right)^2 \right] \; \; \; \rho(R) = 0[/tex]
[tex]\frac{dP}{dr} = - \left[ \frac{3^{2/3} \pi^{4/3} \hbar^2}{5 m_n^{8/3}} \left( \rho_c \left[1 - \left( \frac{r}{R} \right)^2 \right] \right)^{5/3} + \left( \rho_c \left[1 - \left( \frac{r}{R} \right)^2 \right] \right) c^2 \right] \left[ \left( \frac{4 \cdot 3^{2/3} \pi^{7/3} \hbar^2 G r^3}{5 c^4 m_n^{8/3}} \left( \rho_c \left[1 - \left( \frac{r}{R} \right)^2 \right] \right)^{5/3} \right) + \frac{G m(r)}{c^2} \right] \left[ r \left( r - \frac{2G m(r)}{c^2} \right) \right]^{-1}[/tex]
Degenerate Fermi-TOV equation solution VII:
[tex]\boxed{\frac{dP}{dr} = - \left[ \frac{3^{2/3} \pi^{4/3} \hbar^2}{5 m_n^{8/3}} \left( \rho_c \left[1 - \left( \frac{r}{R} \right)^2 \right] \right)^{5/3} + \rho_c c^2 \left[1 - \left( \frac{r}{R} \right)^2 \right] \right] \left[ \left( \frac{4 \cdot 3^{2/3} \pi^{7/3} \hbar^2 G r^3}{5 c^4 m_n^{8/3}} \left( \rho_c \left[1 - \left( \frac{r}{R} \right)^2 \right] \right)^{5/3} \right) + \frac{G m(r)}{c^2} \right] \left[ r \left( r - \frac{2G m(r)}{c^2} \right) \right]^{-1}}[/tex]
[/Color]
Tolman VII density equation solution:
[tex]\boxed{\rho(r) = \rho_c \left[1 - \left( \frac{r}{R} \right)^2 \right] \; \; \; \rho(R) = 0}[/tex]
Mass integration:
[tex]m(r) = 4 \pi \int_r^R r^2 \rho(r) dr[/tex]
[tex]m(r) = 4 \pi \rho_c \int_r^R r^2 \left[ 1 - \left( \frac{r}{R} \right)^2 \right] dr = 4 \pi \rho_c \left( \frac{r^5}{5R^2} + \frac{2R^3}{15} - \frac{r^3}{3} \right) = \frac{4 \pi \rho_c}{15} \left( \frac{3r^5}{R^2} + 2R^3 - 5r^3 \right)[/tex]
Tolman VII mass equation solution:
[tex]\boxed{m(r) = \frac{4 \pi \rho_c}{15} \left( \frac{3r^5}{R^2} + 2R^3 - 5r^3 \right) \; \; \; m(R) = 0}[/tex]
[tex]\frac{dP}{dr} = - \left[ \frac{3^{2/3} \pi^{4/3} \hbar^2}{5 m_n^{8/3}} \left( \rho_c \left[1 - \left( \frac{r}{R} \right)^2 \right] \right)^{5/3} + \rho_c c^2 \left[1 - \left( \frac{r}{R} \right)^2 \right] \right]...[/tex]
[tex]...\left[ \left( \frac{4 \cdot 3^{2/3} \pi^{7/3} \hbar^2 G r^3}{5 c^4 m_n^{8/3}} \left( \rho_c \left[1 - \left( \frac{r}{R} \right)^2 \right] \right)^{5/3} \right) + \frac{G}{c^2} \left( \frac{4 \pi \rho_c}{15} \left( \frac{3r^5}{R^2} + 2R^3 - 5r^3 \right) \right) \right]...[/tex]
[tex]... \left[ r \left( r - \frac{2G}{c^2} \left( \frac{4 \pi \rho_c}{15} \left( \frac{3r^5}{R^2} + 2R^3 - 5r^3 \right) \right) \right) \right]^{-1}[/tex]
[/Color]
[tex]...\left[ \left( \frac{4 \cdot 3^{2/3} \pi^{7/3} \hbar^2 G r^3}{5 c^4 m_n^{8/3}} \left( \rho_c \left[1 - \left( \frac{r}{R} \right)^2 \right] \right)^{5/3} \right) + \frac{4 \pi G \rho_c}{15 c^2} \left( \frac{3r^5}{R^2} + 2R^3 - 5r^3 \right) \right]...[/tex]
[tex]... \left[ r \left( r - \frac{4 \pi G \rho_c}{15 c^2} \left( \frac{3r^5}{R^2} + 2R^3 - 5r^3 \right) \right) \right]^{-1}[/tex]
key:
[tex]\rho_c[/tex] - neutron star core density
[tex]R[/tex] - neutron star radius
Reference:
http://en.wikipedia.org/wiki/Neutron_star"
[/Color]
Neutron average density:
[tex]\rho_n = \frac{m_n}{V_n} = \frac{3 m_n}{4 \pi r_n^3}[/tex]
Neutron radius:
[tex]r_n = r_0 A_n^{\frac{1}{3}}[/tex]
[tex]r_0 = 1.25 \cdot 10^{-15} \; \text{m}[/tex]
Neutron atomic mass unit mass:
[tex]A_n = 10^3 N_A m_n[/tex]
[tex]N_A[/tex] - Avogadro's number
[tex]\rho_n = \frac{3 m_n}{4 \pi ( r_0 A_n^{\frac{1}{3}} )^3} = \frac{3 m_n}{4 \pi A_n r_0^3} = \frac{3 m_n}{4 \cdot 10^3 \pi N_A m_n r_0^3}[/tex]
Neutron density:
[tex]\boxed{\rho_n = \frac{3 m_n}{4 \cdot 10^3 \pi N_A m_n r_0^3}}[/tex]
[tex]\boxed{\rho_n = 2.0297 \cdot 10^{17} \; \frac{\text{kg}}{\text{m}^3}}[/tex]
Neutron star density function parameters:
[tex]\rho(r) \; \propto \; \int_{\text{1E9}}^{\text{8E17}} \; \frac{\text{kg}}{\text{m}^3}[/tex]
Neutron star average density parameters:
[tex]\rho_t \; \propto \; \int_{\text{8.4E16}}^{\text{1E18}} \; \frac{\text{kg}}{\text{m}^3}[/tex]
[/Color]
Reference:
http://en.wikipedia.org/wiki/Neutron"
http://en.wikipedia.org/wiki/Nuclear_size"
"[URL number - Wikipedia[/URL]
[tex]\boxed{\rho_n = \frac{3}{4 \cdot 10^3 \pi N_A r_0^3}}[/tex]
Neutron star core density:
[tex]\boxed{\rho_c = \rho_n}[/tex]
[tex]\frac{dP}{dr} = - \left[ \frac{3^{2/3} \pi^{4/3} \hbar^2}{5 m_n^{8/3}} \left( \left( \frac{3}{4 \cdot 10^3 \pi N_A r_0^3} \right) \left[1 - \left( \frac{r}{R} \right)^2 \right] \right)^{5/3} + \left( \frac{3}{4 \cdot 10^3 \pi N_A r_0^3} \right) c^2 \left[1 - \left( \frac{r}{R} \right)^2 \right] \right]...[/tex]
[tex]...\left[ \left( \frac{4 \cdot 3^{2/3} \pi^{7/3} \hbar^2 G r^3}{5 c^4 m_n^{8/3}} \left( \left( \frac{3}{4 \cdot 10^3 \pi N_A r_0^3} \right) \left[1 - \left( \frac{r}{R} \right)^2 \right] \right)^{5/3} \right) + \frac{4 \pi G }{15 c^2} \left( \frac{3}{4 \cdot 10^3 \pi N_A r_0^3} \right) \left( \frac{3r^5}{R^2} + 2R^3 - 5r^3 \right) \right]...[/tex]
[tex]... \left[ r \left( r - \frac{4 \pi G}{15 c^2} \left( \frac{3}{4 \cdot 10^3 \pi N_A r_0^3} \right)} \left( \frac{3r^5}{R^2} + 2R^3 - 5r^3 \right) \right) \right]^{-1}[/tex]
[tex]\frac{dP}{dr} = - \left[ \frac{9 \hbar^2 }{4 \cdot 10^6 m_n^{\frac{8}{3}}} \left( \frac{3}{2 \pi} \right)^{\frac{1}{3}} \left( \frac{1}{N_A r_0^3} \right)^{\frac{5}{3}} \left[1 - \left( \frac{r}{R} \right)^2 \right]^{5/3} + \frac{3 c^2}{4 \cdot 10^3 \pi N_A r_0^3} \left[1 - \left( \frac{r}{R} \right)^2 \right] \right]...[/tex]
[tex]...\left[ \frac{9 \pi^{\frac{2}{3}} \hbar^2 G r^3}{10^6 c^4 m_n^{\frac{8}{3}}} \left( \frac{3}{2} \right)^{\frac{1}{3}} \left( \frac{1}{N_A r_0^3} \right)^{\frac{5}{3}} \left[1 - \left( \frac{r}{R} \right)^2 \right]^{5/3} + \frac{G}{5 \cdot 10^3 c^2 N_A r_0^3} \left( \frac{3r^5}{R^2} + 2R^3 - 5r^3 \right) \right]...[/tex]
[tex]... \left[ r \left( r - \frac{G}{5 \cdot 10^3 c^2 N_A r_0^3} \left( \frac{3r^5}{R^2} + 2R^3 - 5r^3 \right) \right) \right]^{-1}[/tex]
[/Color]
Note: physicsforums only allows for 30 minutes for editing posts.
Corrections:
The third factor on post #34 should read:
[tex]... \left[ r \left( r - \frac{8 \pi G \rho_c}{15 c^2} \left( \frac{3r^5}{R^2} + 2R^3 - 5r^3 \right) \right) \right]^{-1}[/tex]
The boxed solution for Neutron density on post #35 should read:
The first third factor on post #36 should read:
[tex]... \left[ r \left( r - \frac{8 \pi G}{15 c^2} \left( \frac{3}{4 \cdot 10^3 \pi N_A r_0^3} \right)} \left( \frac{3r^5}{R^2} + 2R^3 - 5r^3 \right) \right) \right]^{-1}[/tex]
The second third factor on post #36 should read:
[tex]... \left[ r \left( r - \frac{2 G}{5 \cdot 10^3 c^2 N_A r_0^3} \left( \frac{3r^5}{R^2} + 2R^3 - 5r^3 \right) \right) \right]^{-1}[/tex]
[/Color]
The attached image is my first attempt to plot the degenerate Fermi-TOV equation solution VII function based upon this model.
These are the results of a 10 km radius static model test.
The function projects semi-asymptoticly until the core radius is reached and then projects a semi-parabolic curve.
Degenerate Fermi-TOV neutron star properties:
Core Radius:
[tex]m = 1[/tex] - slope
[tex]sgn \left( \frac{dP}{dr} \right) = -1 \; \; \; r < r_c[/tex] - sign
[tex]\frac{dP}{dr} = 0 \; \; \; r = r_c[/tex]
[tex]r_c = .3421 \; \text{km}[/tex]
Shell 1:
[tex]sgn \left( \frac{dP}{dr} \right) = 1 \; \; \; r_c < r < r_1[/tex] - sign
[tex]m = 0 \; \; \; r = r_1[/tex] - peak resonance
[tex]\frac{dP}{dr} = \text{3.638} \cdot \text{10}^{28} \; \frac{\text{N}}{\text{m}^3} \; \; \; r = r_1[/tex]
[tex]r_1 = 4.8673 \; \text{km}[/tex]
Shell 2:
[tex]m = -1[/tex] - slope
[tex]sgn \left( \frac{dP}{dr} \right) = 1 \; \; \; r_1 < r < R[/tex] - sign
[tex]r_2 = 10 \; \text{km}[/tex]
Shell 3: Degenerate Iron crust
Total core pressure:
[tex]P_c = \int_0^R \left( \frac{dP}{dr} \right) dr[/tex]
[/Color]
Reference:
http://en.wikipedia.org/wiki/Slope"
http://en.wikipedia.org/wiki/Sign_function"
Mass integration function equation:
Tolman density equation solution VII:
[tex]\rho(r) = \rho_c \left[ 1 - \left( \frac{r}{R} \right)^2 \right] \; \; \; \rho(R) = 0[/tex]
Tolman mass function equation solution VII:
Total mass function integration:
[tex]M_0 = 4 \pi \int_0^R r^2 \rho(r) dr[/tex]
[tex]M_0 = 4 \pi \rho_c \int_0^R r^2 \left[ 1 - \left( \frac{r}{R} \right)^2 \right] = \frac{8 \pi \rho_c R^3}{15}[/tex]
Total Tolman mass equation solution VII:
[tex]\boxed{M_0 = \frac{8 \pi \rho_c R^3}{15}}[/tex]
[/Color]
Correction:
The declaration equations for slope on post# 38 should be:
[tex]sgn ( m ) = -1,0,1[/tex] instead of [tex]m = -1,0,1[/tex]
[/Color]
[tex]M_0 = \frac{8 \pi \rho_c R^3}{15}[/tex]
[tex]\rho_n = \frac{3}{4 \cdot 10^3 \pi N_A r_0^3}}[/tex]
Core density:
[tex]\rho_c = \rho_n[/tex]
[tex]M_0 = \frac{8 \pi}{15} \left( \frac{3}{4 \cdot 10^3 \pi N_A r_0^3}} \right) R^3 = \frac{1}{2.5 \cdot 10^3 N_A} \left( \frac{R}{r_0} \right)^3[/tex]
[tex]\boxed{M_0 = \frac{1}{2.5 \cdot 10^3 N_A} \left( \frac{R}{r_0} \right)^3}[/tex]
Static model radius:
[tex]R = 10 \; \text{km}[/tex]
Static model mass:
[tex]\boxed{M_0 = 3.4007 \cdot 10^{29} \; \text{kg}}[/tex]
[tex]M_0 = 0.1709 \cdot M_{\odot}[/tex]
[/Color]
Reference:
http://en.wikipedia.org/wiki/Sun"
The TOV equation can only be numerically integrated using Riemann sum rules.
Midpoint Rule numerical integration:
[tex]P_c = \int_0^R \left( \frac{dP}{dr} \right) dr = \int_0^R f(r) dr = \sum_{i = 1}^n f(\overline{r_i}) \Delta r \; \; \; \Delta r = \frac{R - 0}{n} \; \; \; \overline{r_i} = \frac{1}{2} (r_{i - 1} + r_i)[/tex]
[tex]\boxed{P_c = \int_0^R f(r) dr = \sum_{i = 1}^n f(\overline{r_i}) \Delta r \; \; \; \Delta r = \frac{R}{n} \; \; \; \overline{r_i} = \frac{1}{2} (r_{i - 1} + r_i)}[/tex]
Static model test results for R = 10 km.
[tex]\boxed{P_c = -1.8635 \cdot 10^{15} \; \frac{\text{N}}{\tex{m}^2}}[/tex]
[/Color]
Reference:
http://en.wikipedia.org/wiki/Riemann_sum"
Correction, the numerical solution for core pressure on post # 41 is incorrect as a result of incomplete integration.
The correct solution is:[/Color]
[tex]\boxed{P_c = 1.8407 \cdot 10^{36} \; \frac{\text{N}}{\tex{m}^2}}[/tex]
[/Color]
Calculating the maximum mass of a neutron star.
Neutron star total gravitational mass:
[tex]M_G = m(R) = \int_0^R 4 \pi r^2 \rho(r) dr[/tex]
Schwarzschild metric spherical layer differential volume:
[tex]dV = \frac{4 \pi r^2 dr}{ \sqrt{\left[ 1 - \frac{r_s}{r} \right]}}[/tex]
[tex]r_s[/tex] - Schwarzschild radius
Baryon number density:
Neutron star total baryon number:
[tex]N_B = \int_0^R n(r) dV = \int_0^R \frac{4 \pi r^2 \rho(r) dr}{ m_n \sqrt{\left[ 1 - \frac{r_s}{r} \right]}}[/tex]
[tex]\boxed{N_B = \int_0^R \frac{4 \pi r^2 \rho(r) dr}{ m_n \sqrt{\left[ 1 - \frac{r_s}{r} \right]}}}[/tex]
Neutron star total baryonic mass:
[tex]M_B = m_n N_B = \int_0^R \frac{4 \pi r^2 \rho(r) dr}{ \sqrt{\left[ 1 - \frac{r_s}{r} \right]}}}[/tex]
[tex]\boxed{M_B = \int_0^R \frac{4 \pi r^2 \rho(r) dr}{ \sqrt{\left[ 1 - \frac{r_s}{r} \right]}}}}[/tex]
Neutron star total binding energy:
[tex]B = (M_B - M_G)c^2[/tex]
[/Color]
Reference:
http://articles.adsabs.harvard.edu/cgi-bin/nph-iarticle_query?1996A%26A...305..871B&amp;data_type=PDF_HIGH&amp;whole_paper=YES&amp;type=PRINTER&amp;filetype=.pdf"
http://en.wikipedia.org/wiki/Schwarzschild_radius"
Be careful on what radius you use for the neutron.
r = r_0*A^(1/3) is an emperical formula for middle mass nuclei, not a 'law'.
It should be better to use the same radius as for the proton, i.e 0.87fm (charge radius of proton, r.m.s)
See also this thread: https://www.physicsforums.com/showthread.php?t=241465
Also, it is quite naive that a neutron star is 100% neutrons.
Proton charge radius...
Proton charge radius:
[tex]r_p = \sqrt{\left< r^2 \right>} = \sqrt{-6 \lim_{Q \rightarrow 0} \frac{d}{dQ^2} F(Q)}[/tex]
ref. 1 Proton charge radius:
r_p = 0.805 ± 0.011 and 0.862 ± 0.012 femtometer (Stein 1995).
Wikipedia Proton charge radius:
r_p = 0.875(7) fm
I found reference for the Proton charge radius, unfortunately Wikipedia does not cite a reference, which radius is more accurate?
[/Color]
Reference:
Stein, B. P. "Physics Update." Physics Today 48, 9, Oct. 1995.
http://scienceworld.wolfram.com/physics/Proton.html"
http://en.wikipedia.org/wiki/Proton"
http://cnr2.kent.edu/~pichowsk/IntroNuc/hw3.pdf"
Particle data group: http://pdg.lbl.gov/2007/tables/bxxx.pdf
But what you really want is the nuclear matter distribution for nucleons, i.e you want to know the 'size' of the 'quark cloud'. In the first approximation, this should be the same as the charge radius distrubution. Since the neutron is overall neutral, the charge radius is not a good measurement (it becomes negative hehe..), so the first approximation of neutron radius is the same the proton radius.
[tex]r_0 = 1.25 \cdot 10^{-15} \; \text{m}[/tex] - empirical nuclear radius
Empirical neutron density:
[tex]\rho_n = \frac{3}{4 \cdot 10^3 \pi N_A r_0^3}} = 2.0297 \cdot 10^{17} \; \frac{\text{kg}}{\text{m}^3}[/tex]
[tex]r_p = 0.8757 \cdot 10^{-15} \; \text{m}[/tex] - Proton charge radius
Proton charge radius neutron density:
[tex]\rho_n = \frac{3 m_n}{4 \pi r_p^3} = 5.954 \cdot 10^{17} \; \frac{\text{kg}}{\text{m}^3}[/tex]
[tex]\boxed{\rho_n = 5.954 \cdot 10^{17} \; \frac{\text{kg}}{\text{m}^3}}[/tex]
[tex]\rho_n = \frac{3 m_n}{4 \pi r_p^3}[/tex]
Neutron star core density equivalent to Proton charge radius neutron density:
Degenerate Fermi-TOV equation:
[tex]\frac{dP}{dr} = - \left[ \frac{3^{2/3} \pi^{4/3} \hbar^2}{5 m_n^{8/3}} \left( \frac{3 m_n}{4 \pi r_p^3} \left[1 - \left( \frac{r}{R} \right)^2 \right] \right)^{5/3} + \left( \frac{3 m_n}{4 \pi r_p^3} \right) c^2 \left[1 - \left( \frac{r}{R} \right)^2 \right] \right]...[/tex]
[tex]...\left[ \left( \frac{4 \cdot 3^{2/3} \pi^{7/3} \hbar^2 G r^3}{5 c^4 m_n^{8/3}} \left( \frac{3 m_n}{4 \pi r_p^3} \left[1 - \left( \frac{r}{R} \right)^2 \right] \right)^{5/3} \right) + \frac{4 \pi G}{15 c^2} \left( \frac{3 m_n}{4 \pi r_p^3} \right) \left( \frac{3r^5}{R^2} + 2R^3 - 5r^3 \right) \right]...[/tex]
[tex]... \left[ r \left( r - \frac{8 \pi G}{15 c^2} \left( \frac{3 m_n}{4 \pi r_p^3} \right) \left( \frac{3r^5}{R^2} + 2R^3 - 5r^3 \right) \right) \right]^{-1}[/tex]
Degenerate Fermi-TOV equation charge radius equation:
[tex]\frac{dP}{dr} = - \left[ \frac{3^{\frac{7}{3}} \hbar^2}{4^{\frac{5}{3}} \pi^{\frac{1}{3}} m_n r_p^5} \left[ 1 - \left( \frac{r}{R} \right)^2 \right]^{5/3} + \frac{3 c^2 m_n}{4 \pi r_p^3} \left[1 - \left( \frac{r}{R} \right)^2 \right] \right]...[/tex]
[tex]...\left[ \left( \frac{3^{7/3} \pi^{4/3} \hbar^2 G r^3}{5 \cdot 4^{\frac{2}{3}} c^4 m_n r_p^5} \left[1 - \left( \frac{r}{R} \right)^2 \right]^{5/3} \right) + \frac{G m_n}{5 c^2 r_p^3} \left( \frac{3r^5}{R^2} + 2R^3 - 5r^3 \right) \right]...[/tex]
[tex]... \left[ r \left( r - \frac{2 G m_n}{5 c^2 r_p^3} \left( \frac{3r^5}{R^2} + 2R^3 - 5r^3 \right) \right) \right]^{-1}[/tex]
The first attached photo is the static model based upon the empirical neutron radius, the second attachment is the static model based upon the Proton charge radius.
Replacing the empirical neutron density with proton charge radius neutron density in a R = 10 km static model resulted in a peak change in pressure increase by a factor of 8.6. The core radius increased by 15 meters and the first shell radius decreased by 112 meters.
The total core pressure became negative, which I believe is required for a neutron star with a stable core.
[tex]\boxed{P_c = -1.713 \cdot 10^{36} \; \frac{\text{N}}{\tex{m}^2}}[/tex]
key:
[/Color]
Reference:
Orion1: the 'emperical nuclear radius' is only applicable to medium size nuclei... how many times do I have to tell you?
Maybe I'm misunderstanding this but why would the intra-nucleon distance be related to the "charge radius" of a proton? I guess I could see them being both on the order of ~1fm. But shouldn't it be a force balance between the neutrons with the strong interaction and the gravitic pressure that determines the separation distance?
Seems wrong to use anything from a single atom to describe the core of a neutron star.
The nuclear density of nuclei is described by the empirical nuclear radius, which describes the radii of large nuclei, however it does not accurately describe the radii of light nuclei or nuclear particles, because it is not a natural law. The 'charge radius' of a proton is a natural law and used to describe the radius of a neutron in this model. (ref. 3)
Using the nuclear density properties of a single neutron to describe a neutron star nuclear core density is correct.
The neutron star itself is a balance between positive neutron degeneracy pressures generated from the Pauli exclusion principle, which states that no two identical fermions may occupy the same quantum state simultaneously and indicating repulsion between neutrons, and the negative internal and surface gravitational pressures, calculated from the TOV equation of state generated from Relativity.
Neutrons are the most 'rigid' objects known - their Young modulus (or more accurately, bulk modulus) is 20 orders of magnitude larger than that of diamond.
[/Color]
Reference:
http://en.wikipedia.org/wiki/Pauli_exclusion_principle"
https://www.physicsforums.com/showpost.php?p=1789174&postcount=45"
Ok, after looking at some numbers I stand corrected.
I'm currently working on something of the same process, but only in reverse. I'm trying to fit the observed data to a prediction on the rotation degradation. Unfortunately I've only just finished my first year or grad, and am getting stuck trying to come up with a metric for a rotating, compressible fluid. (Like Kerr + Tolman IV).
But then again, I just started.
Schwarzschild metric line element:
[tex]ds^2 = e^{\nu (r)} c^2 dt^2 - e^{\lambda (r)} dr^2 - r^2 ( \sin^2 \theta d \phi^2 + d \theta^2)[/tex]
In General Relativity, if the matter supports no transverse stresses and has no mass motion, then its energy momentum tensor is:
[tex]T_1^1 = T_2^2 = T_3^3 = - P(r) \; \; \; T_4^4 = \rho(r) c^2[/tex]
[tex]G_{\mu\nu} = R_{\mu\nu} - {1\over2} g_{\mu\nu}R[/tex]
[tex]G_{\mu \nu} + \Lambda g_{\mu \nu}= \frac{8 \pi G}{c^4} T_{\mu \nu}[/tex]
[tex]R_{\mu\nu} - {1\over2} g_{\mu\nu}R = \frac{8 \pi G}{c^4} T_{\mu \nu} \; \; \; \Lambda = 0[/tex]
With these expressions for the Schwarzschild metric line element and the energy momentum tensor, and with zero cosmological constant, Einstein's field equations reduce to:
[tex]\tag{3} \frac{8 \pi G P(r)}{c^4} = e^{- \lambda} \left( \frac{1}{r} \frac{d \nu}{dr} + \frac{1}{r^2} \right) - \frac{1}{r^2}[/tex]
[tex]\tag{5} \frac{d \nu}{dr} = \frac{2}{P(r) + \rho(r) c^2} \left( \frac{dP(r)}{dr} \right)[/tex]
How are equation solutions [tex]\tag{3}[/tex],[tex]\tag{5}[/tex] derived from the Einstein's field equations?
[/Color]
You have your metric, you can now calculate the rici tensor and scalar (from the metric). Then you can just write out your 4 equations with the SE-tensor.
there's a mathematica package that will actually do this fairly easily, though its a little outdated.
http://library.wolfram.com/infocenter/MathSource/162/
It takes a metric in (in matrix form) and a corresponding 4 vector and calculates the einstein tensor (Rmn - (1/2) Rg)
You may have to modify a little for cosmo const.
Einsteintensor source code:
In[n]=
Code:
ToFileName[{$TopDirectory, "AddOns", "Applications"}]
<< einsteintensor.m
x = {t, r, theta, phi}
(metric = DiagonalMatrix[{Exp[\[Nu][r]], -Exp[\[Lambda][r]], -r^2, -r^2 (Sin[theta]^2)}]) // MatrixForm
(Einstein = Inverse[metric].Simplify[EinsteinTensor[metric, x]])
EinsteinTensor[DiagonalMatrix[{-(1 - 2 M/r), 1/(1 - 2 M/r), r^2, (r Sin[theta])^2}], {t, r, theta, phi}] // Simplify
out[n]/MatrixForm=
[tex] \left(<br /> \begin{array}{llll}<br /> e^{\nu (r)} & 0 & 0 & 0 \\<br /> 0 & -e^{\lambda (r)} & 0 & 0 \\<br /> 0 & 0 & -r^2 & 0 \\<br /> 0 & 0 & 0 & -r^2 \sin ^2(\theta )<br /> \end{array}<br /> \right)[/tex]
Einstein tensor matrix element:
[tex]G_{1 2} = \frac{e^{-\lambda (r)}}{r^2} \left(r \frac{d \nu}{dr} - e^{\lambda (r)} + 1 \right) = e^{- \lambda (r)} \left( \frac{1}{r} \frac{d \nu}{dr} + \frac{1}{r^2} \right) - \frac{1}{r^2}[/tex]
[tex]\boxed{G_{1 2} = e^{- \lambda (r)} \left( \frac{1}{r} \frac{d \nu}{dr} + \frac{1}{r^2} \right) - \frac{1}{r^2}}[/tex]
TOV tensor matrix element:
[tex]G_{\mu\nu} = e^{- \lambda (r)} \left( \frac{1}{r} \frac{d \nu}{dr} + \frac{1}{r^2} \right) - \frac{1}{r^2}[/tex]
How is equation solution [tex]\tag{5}[/tex] derived from Einstein's field equations?
[/Color]
Reference:
http://library.wolfram.com/infocenter/MathSource/162/"
Intuition? Its sort of a pain. Take a loot at Tolman's book "Relativity, Thermodynamics and Cosmology"
Page 243ish. He has the three equations relating density the solutions that you have.
He says and I quote:
" furthermore, in the case of a perfect fluid, the equality between the radial stress T11 and the transverse stresses T22=T33 makes if possible to derive a very simple expression for pressure gradient. thus equating the two expressions for T11 and T22."
He then puts it as T11-T22=0
Then multiplies through by 2/r
then rewrites it in a form that he says " is seen to be equivalent to"
dP/dr + (rho_00 + P_0) v'/2 =0
where v' is dv/dt ("nu")
converts to your eq.
Tolman said:
...equating the two expressions for T11 and T22.
There is a partial viewing of this book online listed in reference 1, however the reference does not display p. 243 (> p. 49) and the chapter page is unavailable and radial and transverse stresses are not listed in the index.
There are tensors for a perfect fluid on p. 216.
What are Tolman's two expressions for radial stress T11 and transverse stress T22?
[/Color]
Correction, the Einstein tensor in post #54 should read:
[tex]G_{1 1} = e^{- \lambda (r)} \left( \frac{1}{r} \frac{d \nu}{dr} + \frac{1}{r^2} \right) - \frac{1}{r^2}[/tex]
[/Color]
Reference:
http://books.google.com/books?hl=en...6KRE&sig=k8NQ6YmncFm4_VxCof8cm5tS-bI#PPP1,M1"
[tex]G_{\mu \nu} = \frac{8 \pi G}{c^4} T_{\mu \nu}[/tex]
Energy density:
[tex]\boxed{G_{00} = \frac{e^{-\lambda (r)} \left(r \lambda '(r) + e^{\lambda (r)} - 1 \right)}{r^2}}[/tex]
[tex]\frac{8 \pi G}{c^4} P(r) = \frac{e^{-\lambda (r)} \left(r \nu '(r)-e^{\lambda (r)}+1\right)}{r^2}[/tex]
[tex]\frac{8 \pi G}{c^4} \rho (r) c^2 = \frac{e^{-\lambda (r)} \left(r \lambda '(r)+e^{\lambda (r)}-1\right)}{r^2}[/tex]
Pressure radius equivalent to density radius:
[tex]\boxed{r_p = r_{\rho}}[/tex]
[tex]r^2 = \left( \frac{c^4}{8 \pi G} \right) \frac{e^{-\lambda (r)} \left(r \nu '(r) - e^{\lambda (r)} + 1 \right)}{P(r)} = \left( \frac{c^4}{8 \pi G} \right) \frac{e^{-\lambda (r)} \left(r \lambda '(r)+e^{\lambda (r)} - 1 \right)}{\rho (r) c^2}[/tex]
[tex]\frac{\left(r \nu '(r) - e^{\lambda (r)} + 1 \right)}{P(r)} = \frac{\left(r \lambda '(r)+e^{\lambda (r)} - 1 \right)}{\rho (r) c^2}[/tex]
[tex]\boxed{\frac{P(r)}{\rho (r) c^2} = \frac{\left(r \nu '(r) - e^{\lambda (r)} + 1 \right)}{\left(r \lambda '(r) + e^{\lambda (r)} - 1 \right)}}[/tex]
[/Color]
[tex]\boxed{\frac{P(r)}{\rho (r) c^2} = \frac{e^{- \lambda (r)} \left( r \nu ' (r) + 1 \right) - 1}{e^{- \lambda (r)} \left( r \lambda '(r) - 1 \right) + 1}}[/tex]
First he has your two equations but I think a different sign (for 8 pi G P and rho)
You seem to be ignoring T22, which he has as:
[tex]8 \pi T_2^2 = -e^{-\lambda} \left ( \frac{\nu''}{2} - \frac{\lambda' \nu'}{4}+\frac{\nu'^2}{4}+\frac{\nu'-\lambda'}{2 r} \right )[/tex]
That with his
[tex]8 \pi T_1^1 = -e^{- \lambda} \left ( \frac{\nu'}{r} + \frac{1}{r^2} \right ) + \frac{1}{r^2}[/tex]
He says for a stationary perfect fluid:
[tex]T_1^1 = T_2^2 = T_3^3 = -\rho_0[/tex]
So he takes
[tex]T_1^1 - T_2^2 = 0[/tex]
[tex]-e^{- \lambda} \left ( \frac{\nu'}{r} + \frac{1}{r^2} \right ) + \frac{1}{r^2} +e^{-\lambda} \left ( \frac{\nu'}{2} - \frac{\lambda' \nu'}{4}+\frac{\nu'^2}{4}+\frac{\nu'-\lambda'}{2 r} \right ) =0[/tex]
which is also
[tex]e^{- \lambda} \left ( -\frac{\nu'}{r} - \frac{1}{r^2} + \frac{\nu''}{2} - \frac{\lambda' \nu'}{4}+\frac{\nu'^2}{4}+\frac{\nu'-\lambda'}{2 r} \right ) + \frac{1}{r^2}=0[/tex]
He regroups them and multiplies thru by 2/r
[tex] e^{- \lambda} \left ( \frac{\nu''}{r} - \frac{\nu'}{r^2}-\frac{2}{r^3} \right ) - e^{-\lambda} \lambda' \left(\frac{\nu'}{r}+\frac{1}{r^2} \right) + \frac{2}{r^3} + e^{-\lambda} \left ( \frac{\lambda'}{r} + \frac{\nu'}{r} \right ) \frac{\nu'}{2} =0[/tex]
and I quote "which on comparison with 95.3 and 95.10 is seen to be equivalent to"
and 95.3 is just the set of T11 T22 and T44
and 95.10 is the t11=t22=t33=-rho and t44 = P
Where
[tex] 8 \pi T_4^4 = e^{-\lambda} \left( \frac{\lambda'}{r} - \frac{1}{r^2} \right ) + \frac{1}{r^2}[/tex]
He takes the long equation above and says its equivalent to:
[tex]\frac{dP_0}{dr} + (\rho_{00} + P_0) \frac{\nu'}{2} =0[/tex]
which he says is the relativistic analouge to the Newtonian expression.
I guess it just takes some intuition to recoginse that if you differentiate one of the T's and multiply it by this and that its the same equation as what you want.
I don't see it, but I am sure he's right :)
This is the equation for hydrostatic equilibrium:
[tex]\frac{dP}{dr} = \left( \rho + P \right) \frac{d \phi}{dr}[/tex]
My equation for the Schwarzschild metric line element:
[tex]ds^2 = e^{\nu (r)} c^2 dt^2 - e^{\lambda (r)} dr^2 - r^2 d \theta^2 - r^2 \sin^2 \theta d \phi^2[/tex]
The matrix forms of the Schwarzschild metric tensors:
[tex]G_{\mu\nu} = \left(<br /> \begin{array}{llll}<br /> e^{\nu (r)} & 0 & 0 & 0 \\<br /> 0 & -e^{\lambda (r)} & 0 & 0 \\<br /> 0 & 0 & -r^2 & 0 \\<br /> 0 & 0 & 0 & -r^2 \sin ^2(\theta )<br /> \end{array}<br /> \right)[/tex]
[tex]T_{\mu\nu} = \left(<br /> \begin{array}{llll}<br /> \rho c^2 & 0 & 0 & 0 \\<br /> 0 & -P & 0 & 0 \\<br /> 0 & 0 & -P & 0 \\<br /> 0 & 0 & 0 & -P<br /> \end{array}<br /> \right)[/tex]
My equation for the Kerr metric line element:
[tex]c^{2} d\tau^{2} = e^{\nu (r)} c^{2} dt^{2} - e^{\lambda (r)} dr^{2} - \rho^{2} d\theta^{2} - \left( r^{2} + \alpha^{2} + \frac{r_{s} r \alpha^{2}}{\rho^{2}} \sin^{2} \theta \right) \sin^{2} \theta \ d\phi^{2} + \frac{2r_{s} r\alpha \sin^{2} \theta }{\rho^{2}} \, c \, dt \, d\phi[/tex]
[tex]\boxed{e^{\nu (r)} = \left( 1 - \frac{r_{s} r}{\rho^{2}} \right)} \; \; \; \; \; \; \boxed{e^{\lambda (r)} = \frac{\rho^{2}}{\Lambda^{2}}}[/tex]
The matrix forms of the Kerr metric tensors:
[tex]G_{\mu\nu} = \left(<br /> \begin{array}{llll}<br /> e^{\nu (r)} & 0 & 0 & 0 \\<br /> 0 & -e^{\lambda (r)} & 0 & 0 \\<br /> 0 & 0 & - \rho^2 & 0 \\<br /> 0 & 0 & 0 & - \left(r^2 + \alpha^2 + \frac{r_s r \alpha^2}{\rho^2} \sin ^2 \theta \right) \sin ^2 \theta<br /> \end{array}<br /> \right)[/tex]
Would extracting the Kerr metric matrix element [tex]G_{11}[/tex] for pressure from the conceptually equivalent Mathematica source code formulas in post #54, produce an equation solution conceptually equivalent to the Schwarzschild metric matrix element [tex]G_{11}[/tex] for pressure?
[/Color]
Reference:
http://en.wikipedia.org/wiki/Kerr_metric"
Schwarzschild_metric - Wikipedia
