Galilean Invariance: Determining Invariant Quantities in Newtonian Mechanics
The discussion focuses on identifying invariant quantities in Newtonian mechanics, specifically under Galilean transformations. Participants analyze various physical quantities including position, velocity, momentum, and kinetic energy, with a particular emphasis on the kinetic energy formula, {E}_{k}=\frac{1}{2}mv^{2}. It is established that invariant quantities remain unchanged when observed from different inertial frames moving at constant velocities relative to each other. The discussion encourages applying transformations to these quantities to determine their invariance.
  • Understanding of Galilean transformations in classical mechanics
  • Familiarity with Newtonian mechanics concepts
  • Knowledge of kinetic energy and its mathematical representation
  • Basic grasp of inertial reference frames
  • Explore the implications of Galilean invariance in classical physics
  • Investigate the mathematical derivation of kinetic energy under transformations
  • Learn about other invariant quantities in different physical theories
  • Study the differences between Galilean and Lorentz transformations
Students of physics, educators teaching classical mechanics, and anyone interested in the foundational principles of Newtonian mechanics and their invariance properties.
joriarty
Explain which of the following quantities are invariant in Newtonian mechanics.
  • Position
  • Distance between two points
  • Velocity
  • Acceleration
  • Momentum
  • Kinetic Energy
  • Potential Energy (I presume gravitational)
N/A
I understand that a quantity such as displacement would be invariant if a transformation is applied and that the transformed frame of reference has the same form as the original frame of reference.
However I am unsure exactly how to tackle the problem. Take for example kinetic energy, {E}_{k}=\frac{1}{2}mv^{2}. How would I then determine if this was invariant or not? Can I just invent a one-dimensional transformation such as v'=v+a\cdot t (where a is acceleration, t is time), apply this to the kinetic energy equation, and check the form of the result?
Thank you for your help
the invariant quantities in Galilean relativity are quantities that don't change when viewed from frames moving at constant velocities relative to each other, where the transformation rules are the ones given by the Galileo transformation. Try performing a general transformation on each of the quantities and see if they change or stay the same.
