Quantum Mechanics: Uncertainty and Commutation relation
The discussion revolves around the uncertainty relation \(\Delta \overline{x}\overline{p} \leq \hbar /2\) and its connection to the commutation relation \([\overline{x},\overline{p}] = i \hbar\) in the context of Quantum Mechanics. Participants are exploring the implications of these concepts and their definitions, particularly in relation to observable quantities.
  • Participants are attempting to understand the meaning of the uncertainty relation and its association with the commutation relation. Some express confusion about the definitions and physical significance of commutation, while others are exploring how these concepts relate to observability of physical quantities.
The discussion is active, with participants sharing insights and clarifications about the relationship between the uncertainty principle and commutation. Some have begun to connect their understanding of these concepts, while others are still seeking clarity on specific terms and their implications.
There is a noted lack of coverage on these topics in the participants' lecture materials and textbooks, which may be contributing to the confusion and need for clarification.
Xyius
I am stuck on one part of my Quantum Mechanics HW. Above the question it says "Try and answer the following question." So I can only assume that he isn't looking for something incredibly detailed. (Ill explain why after the question is given.)
What is the meaning of the uncertainty relation \Delta \overline{x}\overline{p}≤\hbar /2 associated with the commutation relation [\overline{x},\overline{p}]=i \hbar (The bars over x and p are supposed to be hats, as in a unit vector but I do not know how to do them with Latex.)
At this point in time we only had one class and the whole first chapter of the book doesn't delve much into either one of these relations. It says that
[\overline{A},\overline{B}]=AB-BA
That is really all I know about this relation. There is nothing in the lecture notes and nothing about these relations until Chapter 3. Can anyone lead me in the right direction?
The relationship between the uncertainty relation and the commutation relation given is somewhat complex; but I think they're asking more about the uncertainty relation itself---which (happens) to be associated with the given commutation relation.
I think you mean: \Delta x \Delta p_x \leq \hbar/2\pi in terms of [\hat{x},\hat{p}_x]=i\hbar and I think he means the hats to indicate operators.
The 1D x-p commutation looks like:\int_\infty \psi^\star (\hat{x}\hat{p}_x-\hat{p}_x\hat{x})\psi.dx = i\hbar\hat{x}=x \; ; \qquad \hat{p}_x=-i\hbar\frac{d}{dx}
The question is about what the uncertainty relation means - which you can presumably describe OK ... but they want to to describe it in terms of the commutation. The commutation implies Heisenberg's uncertainty - you have to find out how and write it down.
[aside]
\text{\hat{a}} \rightarrow \hat{a}
LaTeX reference - get one of the pdf's (bottom of page).
For PF you only need the chapters on math typesetting, but hey: it's all good.
There's a PFLaTeX guide someplace around here but I keep losing it.
I do not know what commutation means though. This question is throwing me for a loop because this was not discussed at all in our lecture. And there is very little on it in the first chapter of the book. There is a proof that relates the generalized uncertainty principle with the commutation relation but how can I describe what anything means if I do not know what commutation means? I know it is defined as AB-BA, but I do not know the physical significance of this definition and how it relates the the uncertainty principle. :(
Wait! I think I may be getting somewhere! (just did some more reading and something clicked!)
So for two physical quantities to be simultaneously observable then [A,B]=0. But since [A,B]=i\hbar this implies only one quantity to be observable. Relating this to the uncertainty principle, this means that either x OR p can be observable not both.
Am I close?
Close - they are both observable, but the quantities are related in such a way that the uncertainties of the measurements are inversely related. They are not independently observable. The commutator describes and quantifies this.
Exactly you can actually see that quite clearly. Picture applying an operator to a wavefunction as measuring it for the property that belongs to that operator (x is measuring location, p is measuring momentum). The fact that the commutator is not zero means ,measuring first momentum and then location does not lead to the same results as first measuring location and then momentum.
The commutator gives you a description of the difference which then gives rise to the uncertainty relation. So be prepared there is not just one uncertainty relation all non-commuting operators give rise to one.
Cool! Thanks everyone!
  • · Replies 32 ·
  • · Replies 17 ·
