Symmetries of Lagrangian and governing equations
  • Context: Graduate
  • Thread starter Thread starter nickthequick
    Lagrangian Symmetries
The discussion revolves around the relationship between the symmetries of a Lagrangian and the solutions to the governing equations derived from it. Participants explore whether these symmetries provide additional insights into the solutions of the system, particularly in the context of Hamilton's principle and Noether's Theorem.
  • Nick questions how symmetries in the Lagrangian relate to the solutions of the governing equations, specifically whether these symmetries map solutions to solutions.
  • One participant asserts that symmetries in the Lagrangian do map a solution to another solution, citing translation invariance as an example where translations of solutions remain valid solutions.
  • The same participant references Noether's Theorem, indicating that symmetries imply conserved quantities, which can reduce the order of equations of motion and potentially lead to explicit solutions.
  • An example involving two point masses is provided, illustrating how various symmetries lead to conserved quantities and how these can simplify the problem of finding solutions.
  • Nick expresses interest in further exploring the explicit procedure for utilizing symmetries, particularly regarding the delicate nature of symmetries commuting with each other.
  • Another participant recommends resources for learning more about Lagrangians and Hamiltonians, mentioning specific texts that cover the topic, albeit with a note on their varying levels of thoroughness and focus.
Participants generally agree that symmetries in the Lagrangian are related to the solutions of the governing equations, but the discussion remains open regarding the specifics of how these relationships manifest and the implications for solving the equations.
The discussion includes references to specific mathematical procedures and theorems, but the details of these procedures and the conditions under which they apply are not fully resolved.
Readers interested in classical mechanics, particularly those exploring the connections between symmetries, Lagrangians, and solutions to governing equations, may find this discussion beneficial.
nickthequick
Hi,
I have a quick question: Let's say I have a Lagrangian \mathcal{L}. From Hamilton's principle I find a governing equation for my system, call it N\phi=0 where N is some operator and \phi represents the dependent variable of the system. If \mathcal{L} has a particular symmetry, how does that (or does it at all) correspond to symmetries of the solution \phi? ie does this symmetry map solutions to solutions?
Basically the essence of the question is this: Do the symmetries of the Lagrangian give us additional information about solutions to the governing equations?
Any help/references is appreciated.
Thanks,
Nick
Hi Nick,
Here are a couple answers.
1. Symmetries in the Lagrangian do map a solution to another solution. For example, if your system is translation invariant then translations of solutions are still solutions.
2. See Noether's Theorem on wikipedia or in any book on calculus of variations. Symmetries in the Lagrangian imply conserved quantities. If your Lagrangian is symmetric with respect to translation, then linear momentum is conserved. Symmetry in time implies Energy is conserved.
Conserved quantities allow us to reduce the order of the equations of motion and if there are enough conserved quantities we can find explicit solutions. There is an explicit procedure for how to do this, but it is delicate and depends on the symmetries commuting with each other to a certain extent.
Example: Two point masses in space attracted by a Force that is proportional to the inverse square of the distance between the points. This is a 12 dimensional system of ODE because each particle has 3 position coordinates and 3 velocity/momentum coordinates. Let's count symmetries/conserved quantities.
1. translation (linear momentum conserved)
2. rotationally symmetric (angular momentum is conserved)
3. Symmetric w/respect to inertial changes of coordinates (center of mass minus t*initial velocity is conserved)
4. If the Force is inverse square, then there are "hidden symmetries" that imply conservation of the Runge-Lenz vector.
That is 12 conserved quantities. So the solution (your 12 unknown functions) satisfies 12 equations that can be used to explicitly solve the equations.
Here is how you can exploit those things. Using an inertial change of coordinates plus a translation and rotation, you can assume the center of mass is at the origin (for all t) and that the angular momentum is a constant vector pointing in the z direction. That implies the motion is planar in the x,y plane. Using 9 symmetries we reduced the problem from 12 to 3 unknown functions. r1(t), r2(t), and theta(t). Note both masses must move with the same angular velocity since the center of mass remains at the origin. Then you use conservation of Runge Lenz to finish the problem.
Vargo,
Thanks for the reply! It was very helpful.
Do you have a reference for "There is an explicit procedure for how to do this, but it is delicate and depends on the symmetries commuting with each other to a certain extent."?
I would love to dive into this stuff a bit more.
Nick
Almost everything I know about Lagrangians and Hamiltonians I learned from "Mathematical methods of classical mechanics", by V.I. Arnold. Another book which is good is "Calculus of Variations" by Gelfand and Fomin. That is an easier book, but it is a bit less thorough and I dont' think it discusses symmetries as clearly.
They are both by mathematicians. I don't know of any books on the subject that are geared more for physicists, but someone around here must.
  • · Replies 0 ·
