How high is the tree branch(conservation in energy/kinematics)
  • Thread starter Thread starter supernova1203
    Tree
The problem involves a cantaloupe falling from a tree house and hitting a branch, with the goal of determining the height of the branch from the ground. The context includes concepts from conservation of energy and kinematics.
  • Exploratory, Assumption checking
  • The original poster attempts to calculate the height of the branch using kinematic equations but expresses uncertainty about the interpretation of the height in relation to the tree house. Some participants clarify that the height should be measured from the ground, not just from the tree house.
Participants are actively discussing the interpretation of the problem and the calculations involved. There is a focus on ensuring the correct height is determined, with some guidance provided on how to approach the height measurement.
The tree house is stated to be 5.4 m above the ground, which is a critical piece of information for solving the problem. There is some confusion regarding the height from the branch to the ground versus the height from the branch to the tree house.
supernova1203
45a)
A watermelon with a mass of 2 kg falls out of a tree house that is 5.4 m above the ground. What is the speed of the watermelon just before it hits the ground.
(this part i have solved)
mass = 2kg
Δd= 5.4m
v=?
v1^2 =v2^2+2gΔd
v1^2=0+2gΔd
=0+2(9.8)(5.4)
v1^2=√105.84
v1^2=10.28 m/s
Now on to the part i didnt quite get.
45b) A cantaloupe with a mass of 0.45kg falls out of the other side of the tree house. It hits a tree branch at a speed of 6.3 m/s. How high is the tree branch from the ground?
v1^2 =v2^2+2gΔd
v1^2-v2^2/2g=Δd
45b)
v1=0m/s
v2=6.3m/s
mass = 0.45 kg
v1^2-v2^2/2g=Δd
v1^2-v2^2/2g=Δd
6.3^2-0/2g=Δd
6.3^2/2(9.8)=Δd
6.3^2/19.6=Δd
39.69/19.6=Δd
2.025m = Δd
thats the height i got, if it is not correct, can someone show me how to get the right height? or better yet get the right height and i can analyze and figure out how you got the right height?
Hi supernova1203. That would be the height from the branch to the treehouse, the question asks for the height of the branch from the ground.
http://img15.imageshack.us/img15/5184/58649625.jpg
Just click icon above and you can creat beautiful equations
Example
v then click icon X2 above and filled the exponent intended, between SUB] and[/SUB. Here i put 2.
v2
Tell me how did you come to that conclusion?
ah...so in order to get the height from the branch to the ground, i would have to subtract the 2 heights...max height and the 2nd height i got for part B of the question?
" A cantaloupe with a mass of 0.45kg falls out of the other side of the tree house. " The tree house is 5.4m above the ground from a), so I think by other side of the tree house just means it is dropped from the same height as in a). And yes that is the answer
