Understanding the Commutator [x, p^2]?
  • Thread starter Thread starter Ene Dene
    Momentum Operator
The discussion revolves around the commutation relations in quantum mechanics, specifically focusing on the commutator [x, p^2], where x is the position operator and p is the momentum operator represented as p = -ih(d/dx). Participants are exploring the implications of these operators and their interactions.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants are attempting to calculate the commutator [x, p^2] and are discussing the implications of treating p^2 as the momentum operator applied twice. There are questions about the validity of reducing expressions to zero and the proper application of operators on wavefunctions.
Some participants have provided clarifications on the nature of operators and their application to functions, suggesting that the commutator must operate on a wavefunction. There is an ongoing exploration of the correct distribution of operators and the resulting terms in the commutation relations.
There is a noted confusion regarding the treatment of the momentum operator and its square, particularly in relation to how these operators act on wavefunctions. Participants are also considering the implications of operator order and the effects of differentiation in their calculations.
Ene Dene
I'm having trouble understanding the folowing:
(I'll write h for h/(2Pi))
Momentum in x direction is represented by operator
p=-ih\frac{d}{dx}.
So comutator
[x,p]=xp-px=x(-ih)\frac{d}{dx}-(-ih)\frac{dx}{dx}=0+ih*1=ih.
Now here comes the part that I don't understand. I'll calculate [x,p^2]:
[x,p^2]=xp^2-p^2x=xpp-ppx,
but from:
[x,p]=xp-px=ih
I have:
[x,p^2]=xpp-ppx=(ih+px)p-p(-ih+xp)=2ih+pxp-pxp=2ih
As it should be. But why can't I say:
p^2=pp,
(-ih)\frac{d}{dx}*(-ih)\frac{d}{dx}=-h^2\frac{d^2}{dx^2}
And write:
[x,p^2]=xp^2-p^2x=x*(-h^2\frac{d^2}{dx^2})+h^2\frac{d^2}{dx^2}(x)=0+0=0
I don't know how you are reducing the last line to zero. [x,p^2] in this representation is an operator. It needs to operate on something. Work out [x,p^2](f(x)) for an arbitrary function f(x).
try to apply the comutator on a arbitrary wavefunction\psi. Remember that p^2 is not the p-operator squared, it is performed twice on a wavefunction:
p^2 \psi=-ih\frac{d}{dx} \left(-ih\frac{d}{dx} \psi \right)
Edit: Dick was 5 seconds before me =)
Yes, of course, I understand now! Thank you!
p=-ih\frac{d}{dx}.
So comutator
but from:
[x,p]=xp-px=ih
I have:
the third equal sign is the above equation is incorrect (you didn't distribute the p correctly). The equation should read:
<br /> [x,p^2]=xpp-ppx=(ih+px)p-p(-ih+xp)=2ihp+pxp-pxp=2ihp<br />
In general
<br /> [x,f(p)]=i\hbar f&#039;(p)<br />
and the above is a special case with f(p)=p^2.:wink:
You better also had done the first one that way, as not to get confused by what the differential operator acts on.
Let f denote a function of x, then
[x,p]f = xpf-pxf=x(-ih)\frac{df}{dx}-(-ih)\frac{dxf}{dx}= -i h x f&#039; + i h (f + x f&#039;) = i h f
so dropping the function we see [x, p] = i h.
And this method will give you the correct result for any commutator (just remember, the differentiation operator works as far as possible to the right, so \frac{d}{dx} x f really is \frac{d (x f)}{dx} and not \left( \frac{dx}{dx} \right) \cdot f).
How come there is no h^2 term after we do it this way? Using the definition, I don't see why I only get an h and not h^2.
9K
