How to Derive d^* Without Using the Hodge Star Operator?
  • Level: Graduate
  • Thread starter HenryGomes
    Operator
5 replies · 8K views · last reply
HenryGomes
Usually the adjoint to the exterior derivative [tex]d^*[/tex] on a Riemannian manifold is derived using the inner product
[tex]\langle\langle\lambda_1,\lambda_2\rangle\rangle:=\int_M\langle\lambda_1,\lambda_2\rangle\mbox{vol}=\int_M\lambda_1\wedge*\lambda_2[/tex]
where [tex]\lambda[/tex] are p-forms and [tex]*[/tex] is the Hodge duality operator taking p-forms to (n-p)-forms which is defined by the above equation where [tex]\langle\cdot,\cdot\rangle[/tex] is the canonical inner product induced on p-forms by the Riemannian metric g (it is just the tensor p-product of the inverse metric).
It is quite easy to derive [tex]d^*=*d*[/tex]. But does anyone know how to do this without using Hodge star operator, through the g-induced inner product directly?
Any good differential geometry book should have this. One I like, which is for physicist's is John Baes' "Knots, Gauge Theory and Gravity". You might also want to check out Bleecker's " Variational Principles in Gauge Theories". I re-read the post and it seemed a bit badly written. So just to spell out what I meant:
The Hodge star is defined by:
[tex]\langle \lambda_1,\lambda_2\rangle vol=\lambda_1\wedge*\lambda_2[/tex]
Find the adjoint of d without using Hodge star, just the canonically induced metric [tex]\langle\cdot,\cdot\rangle[/tex]
thanks, Henry.
I have R.W.R. Darling's "Differential Forms and Connections". Formal. Not written for physicists. And a 1985 dover reprint, Dominic G. B. Edelen, "Applied Exterior Calculus". Neither one have I read yet.
Perhaps you could tell me if either of these texts might be worth trying.
I don't want to be misleading. I find differential forms fascinating in their application to physics. Sadly, I'm not capable of responding to your past three posts, as yet, but I would surely like to get to that point. From what I've seen over the past 6 weeks, Hurkyl seems to talk of differential forms with some authority. You might try buttonholing him for some input.
-deCraig
Silly question -- if you want to express [itex]* d *[/itex] without the Hodge stars, what's wrong with simply replacing them with a formula that calculates them?
Or... maybe your question is more fundamental? You call it the adjoint, so I assume
[tex]\langle d^* f, g \rangle = \langle f, dg \rangle?[/tex]
Was that what you wanted? Or maybe something like [itex]d^*f[/itex] is the transpose of the tangent multi-vector [itex]\langle f, d \_\_\_ \rangle[/itex]?
Because it is not really the answer I am looking for, but to apply a different method to obtain adjoints when we do not have the Hodge star. Thanks for the answer!
