Time derivative of relativistic momentum help
The discussion revolves around taking the time derivative of the relativistic momentum expression ϒmv, exploring the implications of the product rule and the behavior of the gamma factor in the context of relativistic mechanics.
  • Mathematical reasoning, Assumption checking
  • Participants discuss the application of the product rule for derivatives and question the treatment of the gamma factor and mass as separate functions. There is also inquiry into the handling of negative signs in the derivative calculations.
The conversation includes attempts to clarify the derivative process and correct earlier mistakes regarding signs. Some participants express confusion about specific terms and seek further elaboration on the rules applied in the derivation.
There are mentions of assumptions regarding mass conservation and the treatment of constants in the derivative process, specifically regarding the speed of light.
diewlasing
How does one take the time derivative of ϒmv ?
I tried treating gamma and mv as separate functions but it just gets messy and ultimately wrong.
Well, the product rule simply gives:
[tex]\dot {\vec{p}} = \dot {\gamma} m \vec{v} + \gamma \dot {m} \vec{v} + \gamma m \dot {\vec{v}}[/tex]
For systems that conserve mass, [tex]\dot m =0[/tex]. While,
[tex]\dot {\gamma} = \frac{d}{dt} \left( 1- \frac{v^2}{c^2} \right) ^{-1/2} = \left( \frac{-1}{2} \right) \left( \frac{2v \dot {v} }{c^2} \right) \left( 1- \frac{v^2}{c^2} \right) ^{-3/2} = - \gamma ^3 \left( \frac{v \dot {v}}{c^2} \right)[/tex]
And so,
[tex]\dot {\vec{p}} = \gamma m \dot {\vec{v}} -\gamma ^3 m \left( \frac{v \dot {v}}{c^2} \right) \vec{v} =\gamma m {\vec{a}} -\gamma ^3 m \left( \frac{v a}{c^2} \right) \vec{v}[/tex]
Why is [tex]\left( \frac{2v \dot {v} }{c^2} \right)[/tex] not [tex]\left( \frac{-2v \dot {v} }{c^2} \right)[/tex]? What happened to the minus sign?
OOps,. my bad:redface:. Yes I accidentally dropped a negative sign. The correct answer should be
[tex]\dot {\vec{p}} = \gamma m \dot {\vec{v}} +\gamma ^3 m \left( \frac{v \dot {v}}{c^2} \right) \vec{v} =\gamma m {\vec{a}} +\gamma ^3 m \left( \frac{v a}{c^2} \right) \vec{v}[/tex]
Ah yes, thank you
i can't get (−2*v*v/c^2). what rule do we use on this? can anybody show a more detail step on this part?
Chain rule. Since v is a function of t, the time derivative of 1-v^2/c^2 is -2v(dv/dt)/c^2.
https://www.physicsforums.com/showthread.php?t=343032
I posted a similar question a year after this one if you want a second angle.
thanks master newbie, i was confused on the c^2 actually. so we just leave it as it is bcoz we want the derivative of v not c. correct me if I'm wrong.
It is left there because c (and c^2) is a constant.
  • · Replies 16 ·
  • · Replies 0 ·
  • · Replies 0 ·
  • · Replies 28 ·
