Relativistic version of Newton's second law with parallel force
The discussion centers on deriving the relativistic version of Newton's second law, specifically demonstrating that when force is parallel to velocity, the equation F=γ³ma holds true. The key equations involved are F=dp/dt and p=γmv, where γ is the Lorentz factor. The solution process includes applying the chain rule for differentiation and recognizing that (v/c)² simplifies to 1-1/γ², leading to the desired result. The participants confirm the correctness of the derivation and the application of relativistic concepts.
  • Understanding of relativistic mechanics, specifically Lorentz transformations.
  • Familiarity with calculus, particularly differentiation and the chain rule.
  • Knowledge of the Lorentz factor (γ) and its implications in physics.
  • Basic grasp of Newtonian mechanics and momentum concepts.
  • Study the derivation of the Lorentz factor (γ) in detail.
  • Learn about relativistic momentum and its applications in physics.
  • Explore advanced calculus techniques, focusing on the chain rule and product rule.
  • Investigate other relativistic equations and their implications in classical mechanics.
This discussion is beneficial for physics students, educators, and anyone interested in advanced mechanics, particularly those studying the intersection of classical and relativistic physics.
MasterNewbie
"Given F=dp/dt. If the force is parallel to velocity show that F=γ3ma."
F=dp/dt and p=γmv
Since the force is the first derivative of the momentum with respect to time, and γ and v both vary with time since there is a net force causing both quantities to change, take the derivative of p using multiplication rule: dp/dt = m[γ'v+γa] γ'=γ3*v/c2 so this would change dp/dt to dp/dt = m[γ3(v/c)2+γa] After this I can't think of anywhere to go that could simplify this to the desired equation F=γ3ma.
are you sure about \gamma and its derivative? there must be something wrong about it
Yeah, I did the derivative wrong, I forgot to do chain rule for the v2 so the derivative of γ would be γ3*va/c2
So then dp/dt = γma[γ2(v/c)2+1]. Assuming the math I did was right the only way I could get what I'm looking for is if (v/c)2 is equal to 1-1/γ2 so when you distribute you'd get γ2-1+1, then it would give dp/dt = F = γ3ma what I'm looking for.
I'll have to mess around with this.
[edit]
Coincidentally (v/c)2 does equal what it needs to equal to simplify to what the equation needs to be.
Thank you a lot Pull :)
[/edit]
  • · Replies 0 ·
  • · Replies 26 ·
  • · Replies 27 ·
  • · Replies 16 ·
