Why has to be M,N be orientable?
  • Thread starter Thread starter Canavar
The discussion revolves around the orientability of product manifolds, specifically addressing the condition that if M and N are manifolds, then the product MxN is orientable if and only if both M and N are orientable. The original poster is exploring the implications of this theorem and is particularly focused on understanding why M and N must be orientable if MxN is assumed to be orientable.
  • The original poster attempts to understand the relationship between the orientability of MxN and the individual orientability of M and N, questioning how different definitions of orientability might connect. Participants suggest examining the volume form on MxN and its relation to forms on M and N, as well as considering the product structure of MxN in relation to atlases on M and N.
Participants are actively engaging with the problem, offering various lines of reasoning and suggesting different approaches, such as using differential forms or exploring the structure of atlases. There is recognition of the complexity involved in proving the orientability conditions, and the discussion is ongoing without a clear consensus on the next steps.
There are mentions of different criteria for orientability, including atlases and differential forms, and the original poster expresses uncertainty about how to demonstrate the non-orientability of MxN if M is not orientable. The discussion reflects the challenges posed by the definitions and the need for clarity in the relationships between the manifolds involved.
Canavar
Hello,
I want to solve this Problem:
If M,N are manifolds then MxN is orientable iff M,N is orientable.
I have solved the direction "<=" This was no problem.
But i have a lot of problems to solve the other direction!
Let us assume that MxN are orientable.
We have defined orientable in different ways. Once per atlases and also with a differential non-vanishing form...
But i could't see a connection.
Can you please help me?
Regards
If MxN is orientable, it has a nonvanishing volume form. Can you relate this form to forms on M and N? Presumably the way you proved the other part of theorem would shed some light on this.
Hello,
There are different äquivalent criteria for a manifold to be orianted.
A manifold is oriented if it has an atlas, s.d. the differential of the coordinate changes have positiv determinant.
Therefore the product MxN has a canonically atlas, which also satisfy this criterion.
I hope you understand me.
We can assume that MxN has an atlas A, s.t. forall maps x,y in A we have
det d(x\circ y^{-1})>0. That is MxN is orientable.
But why has M to be orientable, if we assume that MxN has to be?
Regards
You have to use the product structure of MxN in your proof. Is there any way to write an atlas on MxN in terms of an atlas on M and an atlas on N?
Yes of course there is! But not any atlas has to be in that form! This is a real problem.
For example, if (U_i,f_i) is a atlas for M and (V_i,g_i) is a atlas for N => (U_i x V_i, f_i x g_i) is a atlas for MxN.
But it has not to be in this form. That is f,g can depend on both, the element in M and N.
I mean in general the maps have the form (U_i x V_i, h) with h(x,y).
What can i do?
A single atlas satisfying the correct conditions should be enough to show orientabliltiy.
If it's too hard to construct, you might try using differential forms, which seems simpler.
Oh i think it is a misunderstanding. You are right, we inly need a single atlas, which is oriented, to show that a manifold is oriented.
But I want to show something else. i want to show tha MxN is not orientable, if M is not. That is i have to show that any atlas is not orientable of MxN!
I hope the problem is now clear.
Once again:
I want to show:
If M is not orientable =>MxN is not orientable
I have no idea how i can show this. Neither with atlases nor with differential forms.
Regards
There is a relationship between the volume form on MxN and those on M and N. You can use that.
