Solving a Coin Drop Problem - Need Help
  • Thread starter Thread starter doxigywlz
    Figure
The problem involves a coin with a diameter of 2.4 cm that is dropped on its edge onto a horizontal surface. It starts with an initial angular speed of 18 rad/s and rolls without slipping while experiencing an angular acceleration of 1.9 rad/s². The objective is to determine how far the coin rolls before coming to rest.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the relationship between angular acceleration and time, with some attempting to derive time from the given angular acceleration and change in angular velocity. Others explore kinematic equations to relate angular distance and speed.
Several participants are actively engaging with the problem, offering different methods to approach the solution. There is a recognition of potential errors in calculations and signs, and guidance is provided on how to relate angular and linear quantities. No consensus has been reached on a single method, but various approaches are being explored.
Participants note the importance of understanding angular acceleration and its implications for solving the problem. There is mention of homework constraints and the level of physics knowledge being applied, which may affect the discussion.
doxigywlz
Okay, I have this very EASY question (or so it appears) but I don't know how to figure out the time in this problem:
a coin with a diameter of 2.4 cm is dropped on edge onto a horizontal surface. the coin starts out with an initial angular speed of 18 rad/s and rolls in a straight line without slipping. if the rotation slows with an angular acceleration of magnitude 1.9 rad/s^2, how far does the coin roll before coming to rest?
I know w initial is 18 rad/s and w final is 0
alpha is 1.9rad/s^2 (or is it negative??)
we're looking for theta...
I could figure it out if I had the time.. Can someone help me out?? Thanks
That's one way to do it. So figure out the time. Hint: What's the definition of acceleration?
I'm going to guess here...
Since v = rw, r = 2.4/2 = 1.2, and w = 18rads^-1, so 18(1.2) = v (Not going to calculate, too lazy and tired..)
a = Ar, and A = 1.9rads^-2, r = 1.2, so a = 1.9(1.2)...
Now, we'll consider v to be initial velocity, u...
Use the formula:
v^2 = u^2 + 2as
Where s = distance, plug it in..
0^2 = (18(1.2))^2 + 2(1.9(1.2))s
And solve for s.
I hope I gave the right method, tell me if it worked. :-\
pseudo, no-- it didn't work (unless I did it wrong)...
Acceleration is meters per second squared or, in this case, radians per second squared... so how does that help me solve for time?
1.9=change in w over seconds squared.. i tried to solve for it, but i got it wrong..
please a little more help? i have to go to work now but i will definitely check back later
Hmmm, I seem to have made a mistake writing that...
Change the acceleration to a negative value, thus giving the equation:
0^2 = (18(1.2))^2 + 2(-1.9(1.2))s
Try solving for s now and see if it works.
There's no way it's going to come to rest if it's not deceleration! (Unless I haven't learned about something in Physics which causes something to come to rest, rather than net forces..)
The definition of angular acceleration is change of angular velocity (omega) per unit time. Writing it for rotational motion: [itex]\alpha = \Delta \omega / \Delta t[/itex]. You know the change in [itex]\omega[/itex] and the acceleration, so find the time.
By the way, Pseudo Statistic just solved the problem slightly differently. (That's why in my first response I said that your way is just one way of solving for the angle.) I recommend that you solve the problem both ways, just for the practice. Your way: find the time, then use it to find the distance. His way: Use the kinematic formula relating angular distance and speed to get the answer directly. (For some reason Pseudo Statistic converted from angular to linear speed in writing the kinematic equation--that's not wrong, just unnecessary. Also, as he realized, he made a slight error in signs. In any case, the kinematic equation he used is: [itex]\omega_f^2 = \omega_i^2 + 2\alpha \theta[/itex].)
Hey, atleast I got it right. ;)
We aren't even going to take Angular velocity/acceleration in the Physics course I'm in. :(
